Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I believe we have a low temp. lock up problem with our GE gas range. The time shows "lockrd door" and the stove is making a crackling and popping sound, but the door does not lock. Any suggestions? Thanks L. Williams
  • wilmailu Sep 06, 2010
    No mice. Blew out area behind extended latch for door and tried closing the door with electricity restored to range. Popping and crackling sounds continued, reading door locked.
    Tried to reset cleaning cycle, showed 4:00 min. on timer and showed "clean", + locked door, but door was not locked and popping and crackling persisted.
    Is there a way to reset the control panel?
    Thanks
    LW
  • 10,515 Answers
There is not a bypass or a reset. What you have is an obstruction or a bad switch on the door lock assembly itself. Sometimes mice like to crawl up there and make a bed. This will cause a false reading and do exactly what yours is doing. You may want to check that out before anything else.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 05, 2010
  • taran_2005
    taran_2005 Sep 06, 2010
    Thanks for your response!!
    The only way to reset the control board is by disconnecting the power supply for few minutes, say 30 minutes.
    Hope i helped you.
GE JBP79 door locked, no led readout after self clean
Hello- Control is about 250$. Could save 100$ by installing yourself, but the popular "self-destruct" cycle can cook other switches and what-not. Find a tech and inquire up-front if completed repairs are too high, they keep parts, you pay trip charge.- Hope this helps- ED
Mar 01, 2010 | GE Spectra JBP78 Electric Kitchen Range
GE Profile Gas Range oven light doesn't work even after changing
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Electric Stove Broiler doesn't stay on
If the door is closed the broil element will cycle off an on normally. It should stay on most of the time if the door is in the broil position (partially open). If your range has an electronic control it will probably also have a hi and low broil setting. On low broil it will cycle off an on even with the door open but more with the door closed
Dec 31, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge true temp stove top burner wont stay on
dont know how old unit is or how familiar you arewiththe unit, but the burner will need to heat up and cycle off/on. no matter how high or low you set the setting it will heat to a specific temp and cycle off, if hte burner remained RED all the time the glass would crak( so dont go by appearnce of burner, the glass should dictate the temp
Nov 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 gas range...door is registreing as locked when it si not
try cancel if that doesnt do it try unplugging it for three mins
Feb 13, 2008 | Kitchen Ranges
Ge Profile XL44 - Everything works except the Oven, it just stopped
please give suggestions for the oven not working. the ignitor is working fine
Dec 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra glass top stove.
Two possible reasons come to mind.  1. There most likely was a short circuit that activated the top unit. Was any part of the top glowing when you looked at it while it was crackling?
2. Be aware that glass tops CANNOT take as heavy a load of pots and pans as a STANDARD range can. The glass will crack. The stress can accumulate over a period of time and you will be left with the 4 am  madness dim experienced.
If anyone out there finds themselves in a similar situation, don't wait when  you hear the crackling. Pull the the range plug, or find the ranges circuit breaker in your electrical box and turn it off.
Nov 24, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
