I need driver sq h40b - Computers & Internet
Add my facebook ema_ervana@ymail.com , i have the driver , i cant upload the driver to megaupload , etc i dunno why, its always crash , i will send the driver to your email okay? thnkz btw
Posted on Sep 05, 2010
I need to know how much stone in tons I need to fill 8.5 acre at 1.5 ft depth
Stone is approximated at about 2700 lbs. per cu. yd.
An acre is 43560 sq. ft.
8.5 acres is 370260 sq. ft.
There 9 sq.ft. per sq. yd., thus there are 41140 sq. yds. in 8.5 acres.
A cubic yard is 3 feet by 3 feet by 3 feet (LxWxH).
Since you are only going to be at 1.5 feet, each square yard is equal to 1/2 cubic yard, so to figure the cubic yards divide sq.yds. by 2, thus you get 20570 cu. yds. of stone.
20570 x 2700 = 55539000 pounds. Divide by 2000 to get tons:
55539000/2000 = 27769.5 tons.
Nov 16, 2016 | Office Equipment & Supplies
How many yds is in 35 sq.ft
two different measurements that are not compatible
there are 3 feet in a yard but to get sq feet you will need another measurement so that the two measurements can be multiplied together
for example 3 feet by 11.666 feet will give you 35 sq feet or in your question 1 yard by 3.88 yards = 35 sq feet or 3.88 sq yards or any number of combinations of dimensions
Mar 27, 2015 | Heating & Cooling
How to measure air conditioning tonnage to square feet of hom
Read size of air conditioner you need , each ton of air conditioning will keep cool 400 square.so higher ton yo pick you feel cool.please read below square feet to ton chart.
1 ton on 400 sq. ft.
2 ton on 800 sq. ft.
3 ton on 2000 sq. ft.
5 ton on 2570 sq. ft.
May 28, 2014 | Computers & Internet
Top 5 national parks in India according to area?
Top 5 national parks in India are given below
. Kanha National Park (1945 sq kms)
. Ranthambore National Park (1,334 sq kms)
. Sunderban National Park (1330.10 sq kms)
. Corbett National Park (1318.54 sq kms)
. Bandhavgarh National Park (400 sq kms)
Jun 07, 2013 | Cars & Trucks
30 sq meters = how many sq ft?
1 sq meter=10.7639104 sq feet
30 sq meter=30x10.7639104 sq feet
Therefore,
30 sq meters=322.917312 sq feet
Jun 29, 2011 | Cell Phones
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
To convert 443 sq ft to sq m and 315 sq ft to sq m
443 is 41.15 sq m and 315 is 29.26 sq m regards Phil
Apr 14, 2011 | Garden
NEEDS SOUNDCARD DOWNLOAD
though i need to know the os u r using..
considering that u r using win xp or vista..
howevr, u may try searching the internet for ur audio/snd driver by locating itz make n no (eg CMI***/ADI***/ALC***/RTL*** so on, where * indicates model no.), itz a .5 sq in. to 1 sq in, in dimension, situated in a place nr the pci(s)[see infront of the slot] n the back-panel audio port(s)..
along wid the company, there will b a list of such site n driver download links if u search by the model name on a search engine like google..
download them onto a location; if the driver is in a zip format, unzip it,if itz in .exe form, just run it; if done manually it'll ask for the correct driver and location; relocate the path and a.inf file (wat it'll ask for)..
try downloading..
http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/ECS-G31T-M-V10-Audio-Driver-192.shtml
but always better to consult ur system admin/vendor....
Nov 05, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
8 inch woofer blown need specs...OHM, Impedence and wattage
John,
Checkout JL Audio's 8" subs I'll leave specs at the bottom, if you want to look around for something cheaper check out this install I did on a Jaguar X-Type. The sub here is a good example of a free air application and you can look for a sub with the same features. Keep in mind however this setup is using a high power Coustic 10" sub and you only need to handle the stock amp- 25 watts. So you may not need such a beefy sub, but something close would be good. If your sub uses a small enclosure go with something like the JL listed below. Good luck and let me know if you need anything else.7a2e6d4.jpg -Dynami
12855.jpg Reviews W1v2 Technologies Recommended Power Chart Tutorials 12856.jpg 8W1v2 DRIVER SPECIFICATIONS 8W1v2-4 8W1v2-8 buyitnow.jpg buyitnow.jpg Free Air Resonance (Fs): 34.55 Hz 36.60 Hz Electrical “Q” (Qes): 0.508 0.612 Mechanical “Q” (Qms): 6.260 6.000 Total Speaker “Q” (Qts): 0.470 0.555 Equivalent Compliance (Vas): 0.66 cu. ft. / 18.801 liters 0.63 cu. ft. / 17.87 liters One-Way, Linear Excursion (Xmax)*: 0.3 in. / 7.6 mm 0.3 in. / 7.6 mm Reference Efficiency (no): Efficiency (1W/1m)**: 83.86 dB SPL 83.58 dB SPL Effective Piston Area (Sd): 32.67 sq. in. / 0.0211 sq. m. 32.67 sq. in. / 0.0211 sq. m. DC Resistance (Re): 4.00 ohm 7.84 ohm Nominal Impedance (Znom): 4 ohm 8 ohm Thermal Power Handling (Pt): 150W 150W Driver Displacement: 0.02 cu. ft. / 0.571 liters 0.02 cu. ft. / 0.571 liters Net Weight: 6.3 lbs. / 2.9 kg 6.3 lbs. / 2.9 kg * Xmax specifications are derived via one-way voice coil overhang method with no correction factors applied.
** Efficiency (1W/1m) is not an accurate indicator of a subwoofer’s output capability and should not be used as a comparison to other subwoofers to determine which one is “louder”.
acrobat.gif Click here to download the owner's manual (PDF). Click Here For Recommended Enclosure Specifications 8W1v2 DRIVER PHYSICAL SPECIFICATIONS
12819.jpg Nominal
Diameter
Overall
Diameter (A) Mounting Hole
Diameter (B)
Bolt Hole
Circle (C)
Magnet
Diameter (D)
Mounting
Depth (E) 8.0 in. / 200 mm 8.54 in. / 217 mm 7.09 in. / 180 mm 7.85 in. / 199 mm 4.54 in. / 115 mm 3.85 in. / 98 mm 12864.jpg
Apr 06, 2009 | OEM Systems Car Audio & Video
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
