Question about Kenmore 43389 Electric Double Oven
We just purchased a Kenmore Elite double oven (model # C970-600131); we don't like the intensity of the neon clock light; too bright to read the time from the next room; is it possible to turn this intensity down a bit ??
  • 15,935 Answers
No it is pre-set and not adjustable.
perhaps some auto-tint over the display will help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Faulty lights and timer bleeper on neon clock display on front of electric oven.
It is very possible the control board is going bad. Before replaceing the control board pull the connectors and reinstall them. There could be a bad connection causing the display not to lioght up completly. If that doesn't work then it looks like control board time.
Nov 17, 2014 | Stoves 720EF Electric Double Oven
Kenmore c-970 setting clock
Tap Clock sign (cooktop lockout) then ->
Enter time 8 - 3 - 7 for 8h37 ->
Tap "Start"
Done...
Mar 24, 2014 | Kenmore Elite C970 440935
Kenmore elite model 790.4671 the front right hot surface light stays on all the time
There are a few more numbers in that model but I think if it is the largest burner not including the double part number is 318297805 always turn of the electricity before attempting any repair
Sep 30, 2012 | Ovens
Set clock on an old thermador double convection oven
Turn the main knob counter clock wise until the display reads "clock", then turn the same knob clockwise to set the time. When done, push the select button.
Feb 25, 2012 | Thermador SMW272 Electric Double Oven
Kenmore Elite Gas range, model # 790.79363401 The range works but the oven does not seem to heat up. It appears to ignite, just not get hot.
the problem should be from the heating element of your Kenmore Elite Gas range. The heating element is either defective or may have loosed contact as a result of heat coming out of the Oven. The heat coming from the oven may have melted the wire connected to the heating element which might not make it heat up.
Disassemble the oven and check if its actually the wire connected to heating element that got melted, or its time to replace the heating element.
Good luck.
Dec 15, 2010 | Kenmore Ovens
Kenmore double wall oven keeps beeping
I have a whirlpool stove and when I try to clean it after awhile it starts beeping and comes accross with E1 & F5 the oven when its to clean dosen't seem like its locking. How can I fix this problem. Ive missplaced my book somewhere and can't seem to find it. My timer and clock is digital. Can you help me solve this problem? Thanks!
Aug 22, 2009 | Kenmore Ovens
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Oven
There may be a fuse gone the oven works on 230 volts there also may be another fuse box under the oven behind a drawer or behind the oven. if all of that checks out ok, it sounds like you may need a new E.R.C. that would be the clock and control board. If all of your fuses and breakers are ok it would be best to have someone from Sears to look at it.
Dec 17, 2007 | Kenmore 47732 / 47734 / 47739 Electric...
Kenmore 43389 Electric Double Oven Logo
345 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
