Question about HP LaserJet 2840 All-In-One Printer
Fuser Error 50.1 Fuser is hot. What is a fuser?
My hp laser jet 3500 is showing an error message in the dispaly window. It says "50.1 Fuser Error. Fuser is hot. Press both sides of fuser to ensure it is fully seated." What is the fuser and where is it located? my all in one displays error 50.1 fuser
  • 25 Answers
MAKE SURE THE PRINTER IS OFF AND INPLUGED BEFORE YOU START! The fuser is located in the back of the printer. You should see two blue pads where your index finger and thumb (on both hands) should pinch together then pull the fuser out. Re-seat the fuser back into its original position and wait 20 minutes before turnging Unit back on. If you do not wait 20 mins then the 50 error will appear again even if the problem is fix. Once you wait 20 minutes and it still gives you a 50 error you must replace the fuser. I have a great place to purchase fuser so let me know if you nee contact info!
Posted on Jul 16, 2009
Posted on Jun 14, 2008
  • Luis_2008 Jun 14, 2008
    Repair
    Scholar:
  • 125 Answers
The fuser bonds the ink powders onto the paper. It is usually located behind the cartridge in the paper path. There may be several reasons why this error shows. (Bad fuser or bad power supply). It looks like this:
http://printerworks.com/Catalogs/hp-supplies/Q3655A-CLJ-3500-3700-supplies.htm
Here is some useful info:
http://www.fixyourownprinter.com/forums/laser/42184
http://www.coldreset.com/modules.php?name=News&file=article&sid=200
Posted on May 12, 2008
3 Suggested Answers
Cops
  • 64 Answers
SOURCE: Fuser Error 50.1 Fuser is hot. What is a fuser?
50.1
A low fuser temperature error has occurred, possibly due to an inadequate external or internal power supply.
this basicaly means that either the dc controller board is on its way out (expensive) or that there is a drain on the power line.
if you have it plugged into an extension lead try plugging it directly into the wall socket. if this fails also try using a different power lead (very easy to get hold of and are normaly called kettle leads)
Hope this helps
Cops
Pete@wedotoners.com
Posted on Oct 10, 2007
Maanita
  • 1142 Answers
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
Posted on Aug 17, 2008
My printer hp laser pro 400 show message 50.3 fuser error
hello ,,
50.x Fuser Error
Description
The product has experienced an error with the fuser.
Recommended action
Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize.
Turn off the product, wait at least 25 minutes, and then turn on the product.
If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product power on.
If the message persists, contact HP support.
Oct 21, 2013 | HP LaserJet Pro 400 M401DN Laser Printer
Each time I try to print envelopes on the HP Color Laser Jet CP3505x printer, I am gettig a Fuser 50.2 error message
It's unfortunate Janice but your fuser cannot get hot enough to print on an envelope and the only thing you can do is buy another fuser... sounds like the fuser is still able to heat up enough for regular prints on regular paper so you may want to keep it around for a spare but companies usually sell cheaper when you have a core to return to them... Click Here for Fuser
Oct 03, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
50.1 fuser error not fixed by instruction on machine; HP color laserject 3500
17 posts - 8 authors - Last post: 23 MarWe are getting a 50.1 fuser error with our Colour Laserjet 3500 printer ... fuser from HP in the UK, but was told that they are not currently available ... hi I have the same problem error 50.1 with two machine 3500/3550 ...
www.fixyourownprinter.com/forums/laser/31146
Dec 04, 2009 | HP Color LaserJet 3500 Printer
Our HP Color Laser Jet Printer keeps saying 50.2
Hi ellenf971:
Here is your problem.
50.X FUSER ERROR
50.2 error - Fuser Failure (Abnormal Warmup).
Perform the following steps:
1. The connector between the fuser and the
printer is not connected properly. Reseat
the fuser. Check the connector J5013
between the fuser and the printer. Replace
it if damaged.
2. Break in the main thermistor. Turn the
printer off and remove the fuser. Measure
the resistance between the fuser
connectors J5013LA-2 (MAINTH) and
J5013LA-1 (GND). If it is not within the rage
of 330k ohms to 50k ohms (at ambient
temperature), replace the fuser.
3. Break in the fuser heater. Measure the
resistance between the fuser connectors
J5013L-2 (FSRH) and J5013L-1 (FSRN)
with the fuser removed. If it is not within the
rage of 12 ohms to 52 ohms (at ambient
temperature), replace the fuser film unit.
4. Faulty DC controller. PCB Replace the
DC controller PCB
you will have to get an HP certified technician to replace the fuser assembly.
Hope this helps
Jul 17, 2009 | HP Office Equipment & Supplies
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
HELP! 3 year old HP color Laserjet 3500 Installed first fuser kit...error message 50.2 fuser is hot message. Worked through directions; same message appears repeatedly.
The connecter between Fuser and printer is not connected properly. Reset the fuser.
To remove the fuer fuser and measur resistance between the fuser connectors J50132A-2(mainth)and J50132A-1 (gnd) if it is not within the range of 330k ohms TO 50k ohms at (abient temp) Replace the fuser.
Oct 08, 2008 | HP Computers & Internet
Aug 17, 2008 | HP Color LaserJet 2600n Printer
I think the fuser is in your **** part. This problem can be corrected by sitting in a tub of salt water. Make sure the printer is plugged in and is powered on. Is the display lit? If it is place the printer in the tub of water you are sitting in. You sould now be able to realize nobody cares and it no longer matters
Oct 16, 2006 | HP Color LaserJet 3500 Printer
HP LaserJet 2840 All-In-One Printer Logo
3,737 people viewed this question
Ben Johnson
