Question about Dell Dimension 4700 PC Desktop
Dell 4700 reboot error diver 3 not found unidrv.dll needed parallel ata pata-1 pri ide slave f-1
  • Dell Master
  • 4,924 Answers
In this case the ide bus driver is missing and I dont really think it will be possible to rebuild it in this operation system ..Usually need to reinstall if the Hard disk is on a Ide -ata bus..(the wide ribbon plug ..)
but ..you can try to get into Bios by pressing the del button on start ,,and in there select the optimal factory default and save changes by pressing f10...reboot and see if this will put it on the right track again ..
If your hdd is on the Sata bus...it means the issue is simpler..cause the computer will announce you the driver is missing but will boot..and once in there all you need is to insert a cd with the operation system and from the device manager (right click on computer ..than properties..and hardware ....device manager ..)
In there ..look for ide chanels ..and look for the ones tha ar ein yellow with a ask sign ...and click right on them ..and update driver ..
The driver is built in windows..and it will install it automatically ..if not..just download the driver and run it..
If the hard disk is on Ide..and the computer do not want to boot...open the computer ..and move the hdd for a few minutes on the other ide controller....the secondary ...maybe this one as the driver and will work ..
pay attention that if you change the position ..from master to slave ..you have to change the jumper configuration according with instructions on the hdd..
if it works in another position ..just boot...install the missing driver ..and put it back like it was..
The solution that will not make you have to open it or ..slalom between the functions and cables..is to insert the recovery cd ..or the boot-able installation cd ..and make a repair to the operation system ..or a total reinstall..
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_P4_4700&os=WW1&osl=en&catid=&impid=
here are the drivers for xp ..on this model...It seams that if you boot it and the automatic update to the driver do not fix it ..the driver is not available on the suport site cause it is built in windows..and you will need to reinstall it after all ..or if you want to keep the files and the configuration ..just make a repair using the recovery cd ..or the installation cd with the operation system ..
the best will be if it asks to insert the windows XP cd when you boot it ..in this case you could insert the cd ..and just repair the boot ..
Posted on Sep 05, 2010
What's your problem?a way to turn the SATA ports to ON in the BIOS
You can go into the bios and on those drives that are not found you can turn them OFF or N/A. They are probably set to AUTO or ON.
If that does not work I would say remove the power cord, remove the cover, then remove the main power to the motherboard then plug the main power to the motherboard back it. The main power will run from the power supply and the end of it will be about a 2 inch strip that plugs into the board. Press and hold the little catch on it then pull it out of the socket on the board. Put it back in firmly. Reboot and see what happens.
Apr 04, 2012 | Dell Dimension 4700 PC Desktop
Error Message: Drive 2 not found: Parallel ATA, PATA-0 (PRI IDE MASTER)
Anonymous,
Did you set the jumper on the drive to cable select? Check to what the jumpers on the back of the drive is set to. You should have 3 selections. primary,secondary and cable select.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 21, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
On a dell dimension 3100c, i am getting the error when i boot up of Drive 1 not found, parallel ATA, PATA-0 (Pri ide master) When i press F1 the system boots up normally. My hard drive is SATO 0, and...
The DVD drive is having a problem. Ensure the Jumpers are set to Cable Select, and both the data and power cables are seated well
if the drive still doesn't work right, boot to BIOS, turn on caps lock, scroll Lock and num lock, press ALT +E then ALT+F then ALT+B and let the system reboot and re-detect the drives
If still no go, you can try a different drive and or a different cable
May 31, 2010 | Dell Dimension 5100C (D51CL1) PC Desktop
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Dell Dimension 5510
Normally you would set it up to boot from:
1. CD/DVD drive
2. Hard Drives
There may also be a floppy drive to add in whereever you want it.
This problem sound like some kind of drive controller or the drives are not being recognized in BIOS...check and make sure you see the hard drives when setting the boot order.
Mar 15, 2009 | Dell Dimension E521 PC Desktop
IDE Drive not found on startup
I am assuming that the cd and DVD drives are on the Ide right ?? thats because one of the drives jumper is set wrong. If you take a look at the back you will find it saying master / slave / Cable select with eighter a 6 to 10 pins. basically one needs to be set to master and connected with the top piece of the cable and the other set to slave and connected with the middle of the cable. and the other jacks into the main board. If i misunderstood you please respond correcting me as soon as possible so i can be of further help.
Nov 13, 2008 | Dell Dimension E310 PC Desktop
Drive 2 and 3 not found
I keep on receiving the follwoing message "drive 2 not found parallel ATA PATA 0". How to solve this?
Sep 20, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Can i Install PATA hdd on Dimension 4700
I'm sorry, but I couldn't wade through this bunch responses, so I'm going to give you my own.
You have 2 sata drives installed, already, so you cannot add an additional one w/o a bunch of wonky adapters, so use the IDE channel. You say you have an IDE rom drive. Well, there's a reason there are 3 connections on an IDE cable. One side goes into the motherboard, the other 2 into your drives. The motherboard side is the one furthest away from the center connector. I assume you have the primary connector connected to your rom drive. the 2ndary one would be on your hdd. Why people asked you why you're doing this is beyond me. It works, you'll have an extra drive, your preference. Whatever.
Let me know if you have any more inquiries.
To answer your questions from your original post directly, the other 'ide' channel is specifically for a floppy disk You CANNOT connect an IDE cable to it. And yes, you can connect an  hdd to the slave port on the ide cable.
Jan 23, 2008 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
