Question about Welding Tools
How can i open a door handle plsss. my mom is inside it huryyyyyyyy!!!!!!!!!!!!!!!!
  • 15,935 Answers
Turn it to the left.
If that does not work - turn it to the right.
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 05, 2010
What part do I need? It opens from the inside. The handle is not snapped.
Are you saying the inside door handle isnt snapped,but the door wont open by pulling on the inside door handle or is it the outside door handle thats not working??Both the inside and outside door handle has a spring and other components on the backside of the handle which cant really be seen unless you remove the whole door handle assembly.One of these components are most likely broken or the rod that attaches between each handle and the locking mechanism(part that locks into the door striker to keep the door closed and releases it too)might have come loose from the back of the handle.The outside handle is usually mounted to the door by pop rivets or bolts/nuts.The inside handle is usually mounted with screws,but it really depends on what kind of car youre driving.Youll probably have to remove the handle to inspect it for damage.Open the door and watch the locking mechanism for movement while youre pulling on the door handle.If it doesnt move when you pull on the handle,the handle is definitely broke or the rod has come loose from the back of the handle.
Mar 09, 2015 | Cars & Trucks
Back door won,t open on my 02 avalanche
door handle broke depends on what door handle it is.if door cant be open on out side out side door handle broke.if cant open door on inside inside door handle broke.door handle clip that connects to latch rod broken.when you try open door handle not engage to latch rod.door not going open.have to replace door handle with new clip holds latch rod in place.
Jan 09, 2013 | 2002 Chevrolet Avalanche
88 jeep cherokee. Auto Window won't go up,Single mom needs help!
Mine has the same problem. I tapped lightly on the motor, which is inside the door panel directly below the arm rest-door handle. It went up ok. I was told by a friend this morning you can take the electric motor out, open it and clean the brushes inside and it would work like new. I am in the process of doing that now.
Apr 27, 2010 | 1988 Jeep Cherokee
Inside door handle stopped working
the inside door hanger came off you need to remove inside door panel a couple of screws and need to pop off panel to replace hanger
Mar 14, 2010 | 2006 Ford Fusion
Cant get the door open because the door handle is broke inside and out
You should be able to with a pair of pliers perhaps open door from inside -- otherwise you'll need to gain access from the inside panel.
Once the panel is off you should be able to pull the lever to open the door .......I hope this helps you.
Nov 06, 2009 | Cadillac Eldorado Cars & Trucks
Front driver side door wont open from outside.
Sounds like its the bar that goes from the latch in the side of the door up to the handle. It will need to be reattached. If that dosent seem to be the problem you may want to replace handle and all bars in the door with parts from your local junkyard.
Jul 06, 2009 | 2001 Hyundai Tiburon
BMW X5 2001 -DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR.
DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR. FROZE UP IN ICE STORM AND APPEARED TO BREAK WHEN TRIED TO OPEN DOOR. INSIDE HANDLE STILL WORKS. IS DIY REPAIR FEASIBLE?
Jun 23, 2009 | 2001 BMW 5 Series
Drivers side door handle won't work
Some linkage maybe broken on the door handle. Door panel removal instructions are availablel on line www.carstereohelp.com/strford.htm but determining the problem will have to be found on your own.
Nov 12, 2008 | 2000 Ford Focus
Door handle
Door inside hande may is disengaged Remove door inside panel to inspect.
Jul 07, 2008 | Hyundai Motor 2002 Elantra
Welding Tools Logo
29 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
