Question about Compaq Presario CQ60-220US PC Laptop
While replacing the LCD screen on a cq60, I removed two plugs from the LAN card. What are they connected to? I lost them.
    President:
  • 2,600 Answers
These plugs are connected to a black and a white (tan) wire. These wires lead through the hinges of the screen assembly and attach to metal clips at the top of the display under the bezel. These are the wireless antenna leads. The card itself will have the words main and aux. on it along with a small triangle that is either black or white, this is color coded to the proper wire at its connection.
Posted on Sep 05, 2010
Compaq presario cq60 the caps lock blink constantly
You may try this fix. No guaranties though. Remove the battery and unplug power cable. Then hold down the "power" button for about 10 seconds. After that plug it back in and try turning it on. Again, this may NOT work but it has for others.
Sep 08, 2014 | Compaq Presario CQ60-220US PC Laptop
White Screen Compaq Presario CQ60
Regarding ; White screen , I flipped my notebook over and removed the power source(s) , power cord and battery. I then removed the three screws in the battery cavity and the two outside corner screws to gain access to the connection for the LCD and found a loose connection. It seems that the wire that connects to the screen was being moved every time I opened and closed my computer. So very glad to find that bulb and inverter board was not bad. Prior to this , I did try external monitor and found that all was okay as far as operation of start-up.
Aug 20, 2012 | Compaq Presario CQ60-220US PC Laptop
My computer fell out of the car on its bottom closed. got it home plugged it in it started up great when it got to running the screen went dark. not sure what could be wrong
Seems that the LCD screen cable went loose at either its connection with the inverter board or the LCD screen itself. You need to disassemble the LCD screen panel & check the cable connections at both ends. I would also recommend to disassemble the whole laptop & check all connections. The fall might have caused any of the connections to become loose.
Oct 11, 2010 | Compaq Presario CQ60-220US PC Laptop
Compaq cq60 - screen black - laptop on
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Sep 08, 2010 | Compaq Presario CQ60-220US PC Laptop
Screen does not light up
1-Turn off your computer. Remove the battery , plug the charger and try to turn it back on.
2- Connect your laptop to an external monitor. If it displays, then your screen needs replacement. If not you might have a graphic card problem. The latter is hard an expensive to fix. The fix might not be permament. Most technicians will tell you to replace the motherboard. Find someone on craigslist that can reheat the Graphic card unit for unit. this generally fixes the problem
Apr 12, 2010 | Compaq Presario CQ60-220US PC Laptop
Replacement Screen for a Compaq CQ60
There are replace LCD screens on the Internet. Have a look at LCD Parts WEB site. Use this link ;-
www.lcdparts.net
Aug 24, 2009 | Compaq Presario CQ60-220US PC Laptop
Removing the LCD from a Compaq CQ60-215DX
I have a CQ60-220US HP Compaq and access to the LCD screen was different than others I have disassembled and replaced the display. The bezel is snapped on, the lid does not lay back flat to access the two hinge screws, but there are 2 screws with rubber covers down by the hinges, not all the way around.
I used a right angle phillips screw driver and was able to remove the bottom screws, popped off the bezel the remainder of the way around the screen, it is different, but don't be fooled there are a few screws just not the amount you might be used to, and then gaining access to one of the hinge screws on each side can be an issue as the lid did not lay back flat, but with a good right angle screw driver you can get it done, I did. I am not sure if the proper method is to not just remove the entire top cover and hinges, but the right angle screw driver and finding that this model had only a couple bezel screws made it much easier to tackle.
Jun 16, 2009 | Compaq CQ60-215DX Notebook
We have a hp pavillion dv7-1240us & we need directions on how to replace the screen ???
LCD Panel removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery, wireless LAN Minicard, keyboard, switch cover, display panel, display bezel, and inverter.
  1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
  2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Lift the LCD panel out of the display panel enclosure.
LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
  1. Place the LCD panel into the display panel enclosure.
  2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery.
  1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
  3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
    Important! Use care when disconnecting the wireless antenna cables from the wireless LAN Minicard. Damaged cables or connectors can degrade notebook performance.
    Note: If three antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to terminal 1, the cable labeled 2 connects to terminal 2, and the cable labeled 3 connects to terminal 3. If two antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to the MAIN terminal and the cable labeled 2 connects to the AUX terminal.
  4. Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  5. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  6. Place the wireless LAN Minicard in a static dissipative bag.
Keyboard removal Caution! Observe all precautions when removing and replacing components.
  3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  5. Turn the notebook right side up and open the display panel fully.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
  7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the ZIF connector and ribbon cable.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the keyboard ribbon cable.
  2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
  9. Tighten the two captive P1 Phillips-head screws.
May 17, 2009 | HP Computers & Internet
Compaq Presario CQ60-220US PC Laptop Logo
163 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
