When i open my pc says back up your data and replace your hard disc driver and f1 to continue but if i see any you tube allways gone sos please my pc is compac Presario c300
  • 358 Answers
From what I can deduce here, it seems that you the hard drive probably has had a bad sector on it.
Or there is a problem with the read/write head inside the hard drive as a result of the shock caused maybe by dropping it or hitting it on something by mistake.
In this case, what I would advise you to do is, unscrew the hard drive case and remove the Hard disk from the case, get an external hard drive case, (remember to choose the approriate type (i.e either SATA or IDE) then connect it directly to another system, through USB 2.0 this time around.
After it is being detected by the system, Perform a scan on it by:
Right-Clicking on the icon representing your hard drive, go to properties, then select tools, then select check for errors on hard drive.
After performing this, if it successfully finishes the repair, I would advise you to backup All your data from it, in case it fails later.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, "Again" I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
Posted on Sep 08, 2010
My Toshiba satellite with a mk2555gsx won't boot up no messages, tried recovery discs to no avail.
SMART FAILURE PREDICTED on HARD DISK 2: TOSHIBA MK2565GSX-(S1)
Warning: Immediately back-up your data and replace your hard disk drive.
Press F1 to continue.
What is that problem?? and how to troubleshoot this my computer, the model is neo M1110 noteboke.
Sep 10, 2013 | Toshiba MK2555GSX 250GB SATA/300 5400RPM...
Bad hard disk message back up and replace message
If the hard drive is failing it will need to be replaced and then you can use the recovery disc to re-install windows. If this computer is newer than 2005-6 then it most likely uses a 3.5" SATA drive.
Dec 18, 2012 | E-Machines eMachines Desktop PC
Hp elitebook 6930p keyboard not working properly, I used to get hard disk warining message which I used to bypass by F1, but now F1 also stopped working, any workaround?
Hard drive has probably failed completely now. Fit a new hard drive, buy a windows OS disc, reinstall all of your programmes, restore your backed up data files and set up your new disc.
Oct 08, 2012 | HP EliteBook 6930p Notebook PC
When i turn on my laptop a warning notice comes on screen immediately saying smart failure predicted on hard disc 0:ST9160310AS-(PM). Warning immediately back up your data and replace your hard disc drive....
It means exactly what the message says.
The hard drive is going to fail in the near future. I recommend you back up your data before the hard drive fails completely.
When the hard drive fails, replace the hard drive, and use your Compaq recovery disk to install Windows and the device drivers plus your programs to get the laptop working again.
May 01, 2011 | Acer Computers & Internet
Smart failure predicted on hard disk. Warning: immediately backup your data and replace your hard **** drive. A failure may be imminent. Press F1 to continue
Problem :
Hard Drive Fail
--Solution:
Your system are telling you that soon the hard drive will be gone, so do a complete back up of your files and buy a new hard drive to replace the faulty one.
please rate my soution
Aug 23, 2010 | Computers & Internet
Acer Aspire 5100: SMART Failure on Hard Disk 4
Hello there,
As per experience, SMART Utility will check your HDD for any errors that may occur.
I backed up everything and replaced a new HDD and got rid of the error.
Opened up the problematic HDD and noticed a very light scratch on its "platters".
As for me. Never ignore this warning before something might happen to your HDD and lost important data.
Mar 08, 2010 | Acer Aspire 5100 Notebook
SMART FAILLURE PREDICTED ON HARD DISK O:WDC WD800BEVS-22RSTO-(S1) WARNING: IMMEDIATELY BACK-UP YOUR DATA AND REPLACE YOUR HARD DISK DRIVE. A FAILURE MAY BE IMMINENT. PRESS F1 TO CONTINUE
Well this error message means that the automatic drive checking software that runs all the time has detected that the drive is failing, either the electronics or the media. You need to backup any data to a DVD or external drive. The press F1, is so you can continue on and do so. You can burn/copy the data to DVD or copy to a USB hard Drive. Then you will need to get a new drive and reinstall your Operating System & data again.
Jan 29, 2010 | Acer Aspire 3680 Laptop
Sony VAIO Z1WAMP3 PC Notebook
 Boot to get rid of the problem or repair your HDD.
Jan 26, 2008 | Sony VAIO Z1WAMP3 (PCGZ1WAMP3) PC Notebook
Motherboard password
The password your sone has forgooton exists in a window set up only as long as it it operative. When a drive is formatted and the data expunged the password goes with it. Reinstalling windows and you need to create a new password if you feel that need at all. The Monther board has not password need via the Bios unless you choose to create one. It youignore the request for a pss word and it keeps coming back - think up a new one.
Sep 27, 2007 | Acer Aspire SA20 PC Desktop
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
