Question about Hampton Bay HBLG5004 Air Conditioner
FAN TURNS ON FINE BUT COMPRRESSOR DOESNT CLICK ON. HOW DO I FIND AND REPAIR THE PROBLEM?`
  • 674 Answers
The problem could be the capacitor for the compressor motor or the compressor motor. Use a multimeter with the capacitor test function to check it or take the capacitor to a heating and air supply and they can check it for you. If the capacitor looks swollen then it is bad. If the capacitor is good then use an ohmmeter to check the compressor motor windings. Connect one lead to common then the other lead to Run then Start, reading the meter when you connect the lead. The capacitor is a common failure.
Posted on Sep 05, 2010
Electric fireplace #230811 model no. fl 23-r has no heat and no fan. doesnt say sunbeam or dimplex anywhere on it. resistance readings on thermostat and switches seem fine. It has a circuit board on it....
These models have thermal fuses in them. You can hear them click when the fan isn't turning. Mine needed the fan axle to be greased up. Once I disassembled it and greased it up with some High-Temp grease it ran like new. No more clicking off.
Oct 24, 2011 | Heating & Cooling
Compressor not engaging how can I check to make sure that it is not the freon or the compressor?
You could temporarly short out the low pressure switch to see if the comprressor comes on ... if it does ... you are low on freon. You will have to find and repair the leak and recharge.
Jun 23, 2010 | 1999 Pontiac Bonneville
The compressor fan not properly working.
You need to replace the fan. It doesn't use an external starter. Part 24 on this diagram is your motor. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=502485&diagram_id=124933#d124933
May 13, 2010 | Whirlpool Gold® GC5SHEXNQ
So my split fridge and freezer broke. the freezer works fine but the fridge doesnt get cold enough, even if i turn the knob to 7 (the highest).
first clean and remove dust and debris from under unit and make sure fan is working properly--next check the fan in freezer section for icing ,damage ,blockage ,or failure repair or replace as necessary the fan supplies the fridge with cold air from freezer
Nov 26, 2009 | Kenmore Refrigerators
Dell D600 when powering, leds blinking
Its a motherboard problem. check all the flashing codes here.
CLICK HERE
it will give you all the information about the codes.
Sep 26, 2009 | Dell Latitude D600 Notebook
Fan relays
All you have to do is run the car untill the fan turns on while waiting touch the top of each relay with your fingers, and the one that clicks will tell that it is the relay for the fan.
Jun 30, 2009 | 1999 Mazda 626
Compressor will not start all the time. unit is new, less than a week old
if the fan is working when you turn down the temp on your thermostat, all is good. many new high efficiancy units do not always run the comprressor all the time like the old ones. house is cooling all is good
Jun 21, 2009 | Goodman CKL30AR30 Air Conditioner
92 FORD TAURUS COOLING SYSTEM FAN NOT WORKING
Fan Relay. In the fuse box under the hood
Jun 04, 2009 | 1992 Ford Taurus
Heating & Cooling Logo
125 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
AJMAL KHAN
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
