Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
F-DL problem I've been reading below, but it doesn't tell me this: If I am getting "F DL" error, but I can drain and spin, then what? My door locks just fine when I go to drain and spin. Is this a computer problem? Is it coincidence that my HE3t dryer just blew out last week? Is there anyone besides Sears that can fix these?
  • Anonymous Aug 24, 2008
    The machine started throwing f11 codes a few weeks ago and not letting us cancel and unlock the door. Now we are getting f dl codes and the door will not lock.
    Please help
  • Anonymous Oct 31, 2008
    I have figured out that lifting the door up while closing it while slamming really hard will usually fix the problem. The door hangs lower then the latch, and they don't meet up properly. I usually have to cancel the load, wait about an hour, and try the above method. Eventually, it works. And NEVER EVER EVER cancel a load in the middle-this is ALWAYS when it happens!
    Sergeant:
    Champion:
  • 324 Answers
Sounds like the control board
Posted on Oct 31, 2008
F-dl
If the door fails to lock after six (6) attempts "Fdl" will display. The "Fdl" error code indicates a bad lock assembly. Here is the lock to order.Below is a video to show you how to replace the lock assembly.
The part comes with a 365 day, any part, any reason return policy.
Nov 09, 2012 | Washing Machines
Door locked error code dL/F
If your door is already locked and you get an "F" error press and hold the cancel button, and select drain/spin. If this still doesn't work and your clothes are trapped inside do not resort to getting out the crow bar and a sledge hammer. (Though you may really feel like doing just that). You can manually unlock the door by following these steps:
- Unplug washer or disconnect power.
- Remove the lower kick panel.
- Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
- Located on the bottom of the door switch/lock unit is a teardrop shaped tab.
- Gently pull the tab down about a 1/4˝ or until a click is heard.
- The door may be now opened.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Check page 46 and 51 in tha manual given in the above link
May 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our Kenmore Elite HE3 Model prefix is 110 stops during the rince and spin cycle,beeps, and desplays F dL or F 11. The door light is not on, but the door is locked. We were able to start and complete the...
wash another load and see what happens the f-dl code means door lock problem and f-11 means communication error between top control board and the bottom control board if you can wash a load completly everything will be ok but you can't let me know and we see where to go from there
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet washer has error code f dl. there is a buzzing sound and the washer won't drain nor spin.
Hi there
I hope this helps you.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Ty for writing to fix ya.
Best regards Richard
Dec 08, 2009 | Whirlpool GHW9150 Duet Washer
I am getting dl /f message, What do I do.
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
Replace failed component.(Door lock assembly)
Sep 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F/dl code comes on - machine doesn't run
failed door lock error, i would first unplug the unit for about 5 minutes this will reset the board. if that doesnt work you may have a bad door latch. .inspect latch that the piece on the door that when you close door piece on the door makes contact with the latch. hope this helps
Sep 16, 2009 | Kenmore Elite 45986 Front Load Washer
I have the F11 and dL code. There is water and
Hi
Error F11 means Serial Communication Error i.e. communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. You need to:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
  • Error code dl is a Door Lock Error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error. You need to check:
  • Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    Jul 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    What do I do for dL and F error message?
    same problem..for a couple months I could get it to work intermittently but finally gave in and the repair guy is here putting in a new control panel. expensive sorry to say.
    Jul 17, 2008 | Kenmore Elite 45986 Front Load Washer
    Error code f and dl won't drain or spin
    "Fdl" is a Door Lock error. This is usually an indication of a failed door latch mechanism. To access and/or replace the door latch, click on the following link:
    http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
    A replacement latch can be located at searspartsdirect.com. Just type in your model number in the "Search" window. You can locate it under the "Door and Latch Parts" heading as item number 7 (part #8181700). This is an easy repair job if you wish to accomplish on your own and avoid the added cost of labor.
    If you do not wish to order the part online, use the part number provided and go to your nearest applaince parts retailer. I hope this helps you. Please post back if you need further assistance.
    May 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    51 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
