Question about Husqvarna Mcculloch Riding Lawn Mower 185 Hp 42 Inch Cut
I need to change the cluch cable on my McCulloch self propelled lawn mower
2 Suggested Answers
SOURCE: V Belt problem
It has been taken care of.
Posted on Apr 09, 2009
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
How to replace the self propelled
Make sure the cable to the transmission moves freely. If all the cables and lever s move freely than it more than likey is an internal gear needs replacing.
Jul 15, 2014 | Poulan Pro 22" Self Propelled High Wheel...
My self propell lawn mower stop propell
the cable needs tension to engage the belt tensioner
Sep 23, 2012 | Garden
Limited self propell
The self propel cable needs to be adjusted. This can be done with a 7/16 wrench. loosen the nut that holds the self propel cable in place. You may need to pry this open with a screwdriver. Don't overdo it or you could break the plastic. Once the cable is loose pull it toward the mower deck, once the slack is out of the cable press the self propel handle in about a half of an inch. This should be close to what it was from the factory. Then re tighten the nut. And check the self propel to make sure it is engaging properly. If you hear a grinding noise when trying to engage the transmission then you will need a new transmission. Depending on if it is a front or rear self propel the part alone is either $60-$75 retail. Most repair shops will charge an hour to do this repair. I hope this answers your question.
Mar 24, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Self propelled mower no longer propells
SOUND LIKE THE TRANS IS WORE OUT
Oct 01, 2009 | Garden
Honda harmony self propelled cable snapped at end
Get a replacement cable, part number should be in your user manual...when you get the cable it should have directions on how to replace.
Sep 08, 2009 | Troy Bilt 5.5hp Self Propelled Mower
My craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Sep 04, 2009 | Garden
Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Aug 05, 2009 | Garden
Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Apr 29, 2009 | Garden
SELF PROPEL FAILURE ON YARD MAN MOWER
hello
check the drive cable as not come adrift or broken
you can usually adjust the tension on top of the drive cable
also check drive belt is on the two pulleys
hope this helps
Mar 13, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Husqvarna Mcculloch Riding Lawn Mower 185 Hp 42 Inch Cut Logo
27 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
