Question about Dell Dimension 3000 PC Desktop
Video driver needed
I want a video driver for my dell 3000,because the video is not working properly,the screen always fuzz out
    Champion:
  • 230 Answers
What OS are you using?
Posted on May 12, 2008
    Scholar:
  • 125 Answers
Assuming the video card was not changed since the system was made, go to this web site:
http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=drivers&cat=all&x=3&y=7
click the drivers&downloads link under 'Recommended" and enter your model. Use the service tag number on the back of your computer (or just follow the prompts to narrow down your pc) and download the driver for your video card.
If it is not the original card, you must go to the new card manufacturer's website to get drivers there.
Dell n5050 grey static screen
Sounds like the GPU has over heated and is causing video driver issues. Usually the GPU needs re balling as the solder has melted underneath the BGA chip. A specialized repair is required. Take a look on flea bay for prices.
Oct 26, 2013 | Dell Computers & Internet
Replaced video card in Dell Dimension 3000 with NVIDIA GeForce FX 5500. Can't find video controller driver
Hi.
Click on the link below and download the driver for the card, if you are unsure then click on the Supported Products tab and you will see that the FX 5500 card is supported in the download.
http://www.nvidia.com/object/winxp_175.19_whql.html
Regards.
Feb 04, 2013 | Dell Dimension 3000 PC Desktop
Installed Dell Dimension audio and video drivers in worng order. Now, no sound amonng other things. How can I unistall and reinstall the drivers and start over. The chipset and network drivers were in the...
Try re-installing them in the correct order over the top first and see if that sorts it.
Normally though, it shouldn't matter in which order you install the sound and video drivers, they should still work.
if you are using windows xp you can go into control panel, system properties, device manager and delete the incorrect drivers from there.
Aug 27, 2010 | Dell Dimension 3000 PC Desktop
Dell Inspiron 1545. When booting to vista the screen goes black. When booting to safe mode the screen works normally.
Please reinstall the Video Driver and check if the same issue persists. If the issue started within last 90 days, you can try the System Restore
Jul 01, 2010 | Computers & Internet
I put a new harddrive in my dell dimension 3000. and once the OS was done and windows started up i could not adjust the resolution or go on the enternet. also no sound? what is am doing wrong
You need to get ethernet,graphics and audio drivers
to get internet , screen ,sound to work!
Get the right drivers and it will work!
Please vote!
May 13, 2010 | Dell Dimension 3000 PC Desktop
Dell dimension 3000 has onboard video there is no video card on it.when check device manager i've seen yellow exclemition mark in "others" and it say "video controller vga". that's why i download video...
beckup your all data then install a fresh win XP, compatible with your driver you download from the dell website,,,,
change the RAM Memory to other slots onBoard..
it shell solve the problum..
good luck
shafky
Jul 06, 2009 | Dell Dimension 3000 PC Desktop
Dell dimension 3000. Just Black Screen no Windows XP.
From your description, you were able to boot the machine properly in Safe Mode. While in Safe Mode, change the video resolution to the lowest possible (color depth does not matter at this point). You should also check that you are configured for single monitor operation if your video card supports multiple monitors. Reboot the machine normally. If all goes well, you can readjust your video settings for a higher resolution again.
Dell m170 pixelated screen on start up will only boot up safemode
The video card could be going out, this happens alot where i work. Are the pixels that are out always in the same spot or does it change as you navigate around windows?
If the pixels are always in the exact same place, its the LCD, If not, its the video card.
Be sure to have the proper drivers, get any updates from www.support.dell.com. select the model number or enter the TAG number off the back or do search for DELL M 170 or Latitude M170 or whatever model it is.
Try this out and if no go, then get back to me.
Good luck
Feb 03, 2009 | Dell Latitude D800 Notebook
Sound windows xp dimension 3000
hi if your motherboard have you install sound properly....Or not your sound driver you Go to driver Zone.com then download it
Jun 06, 2008 | Dell Dimension 3000 PC Desktop
New Hard Drive Dell Dimension 3000
Theres a problem with your driver installation.your computer is newly formated and wiyh a new harddrive but still theres a problem.check your monitor if it can support up 1024/768 pixel so that you can adjust your screen resolution to a smaller icons.also check your vga.and rollback device driver for sound device.
May 29, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
35 people viewed this question
Alun Cox
