Question about CTX P772 17" LCD Monitor
CTX P772 17" LCD Monitor Problem
Could you be more specific in the location of the IC you thinkis the problem? Also do you know of any suppliers of the replacement part?
Thanks
  • markbose Dec 05, 2008
    BZZZZZZZ not even close to a right guess. If you read the question it goes in and out on its own. There is no hidden magic feature that changes the refresh rate in the background secretly in my os.
    Scholar:
  • 87 Answers
This is caused by sending a video signal to the screen at a refresh rate higher than 60hz. A LCD Doesn't refresh the image by scanning from top to bottom like a traditional CRT or picture tube. They are hard set to 60hz and can not understand anything else. Setting it to anything else will cause it to not display a video signal, picture tearing (little blocks with horizontal movement), Offset video or convergents issues (colors appear offset giving it the 3d movie look with out glasses on)
To fix it you need to go into your operating systems display settings and pick out a LCD monitor with a refresh rate of 60hz
Hope that helps
Posted on Dec 05, 2008
  • Jay Brooks
    Jay Brooks Dec 05, 2008
    Sorry Posted to the wrong question... Please excuse my lame mistake.
  • Jay Brooks
    Jay Brooks Dec 06, 2008
    As I stated. I answered the wrong post. The solution I posted was for a offset image. Sorry for the confusion. Fixya should have a way to edit a post.
    If your screen is fading in and out it is most likely a failing power supply, ballast or a capacitor. If it is a "bad IC" like someone else posted... You would most likely not be able to turn it on at all. Most IC's in modern electronics are programmable logics like a PIC or a AVR.. In this case you are screwed and you may as well throw it out unless you have the means and experties to remove/copy/replace the current micro controler. IC's rarely fail. Microcontrolers do fail but not because of a bad chip.. they fail from poor programmers writing operating logs to flash instead of memory.
Ctx pv720a monitor goes blank
This is what inverter board looks like:
http://www.shopjimmy.com/catalogsearch/result/?q=CTX%20PV720
Look for bad caps also, more likely to need new inverter board, warning, you can have bad lamp assembly also.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 27, 2010 | CTX PV 720 17" LCD Monitor
I'm missing the power adapter for the CTX Monitor S500. Where can I find one?
http://www.google.com/#hl=en&source=hp&q=power+adapter+for+the+CTX+Monitor+S500&btnG=Google+Search&aq=f&aqi=&aql=&oq=&gs_rfai=&fp=ff274912d96214e6
Jun 24, 2010 | CTX S500BA (Black) 15 in. Flat Panel LCD...
I have a ctx moniter says undectected mode
CTX 15"1024x768 TFT LCD-Black Monitor · i have a ctx moniter says ... Answer. i have a ctx moniter and wen i plugnitin to pc tower itsays undeceted mode watdoes this mean. Close Close. ASUS Eee PC 1000H
Dec 03, 2009 | CTX 15"1024x768 TFT LCD-Black Monitor
Ctx monitor
try lowering the screen resolution
Oct 19, 2009 | CTX S762A 17" LCD Monitor
Looking for AC power Adopter for CTX LCD monitor
Check it on Radio Shack maybe they got something
Jun 03, 2009 | CTX SV900MD 19" LCD Monitor
ACER Lcd monitor model AL1521 ic part no?
do you have the answer already? if not i will put it here by tomorrow, i think is C5706. i check it again
Feb 27, 2009 | Acer AL1521M (Silver) 15" LCD Monitor
Ctx pv 720 lcd monitor backlight drops post plus 30 seconds!
Hi...there,
The problems on the backlight inverter power supply. Open it up and check all the capacitors, it look like a tiny battery cap on the side had writing on it. (Example 1000uf 16v ) if you are lucky you can spot it right away...with a bulged on top of each caps. If not, just replaced all of the caps... Good luck!
Dec 06, 2008 | CTX PV 720 17" LCD Monitor
CTX VL701 16" Monitor
I made contact with US supplier and am waiting for part reference number.
Thanks
Geoh
Jul 24, 2008 | CTX VL701B (Black) 17 in.CRT Conventional...
Executable driver download for CTX S761 lcd Monitor
Searched the CTX site found the device in discontinued products but no link.
This one actually has 761 in the name -- you did not list what you have found so I hope this is new.
http://members.driverguide.com/driver/detail.php?driverid=517451
Dec 20, 2007 | CTX S761 17" LCD Monitor
CTX P772 17" LCD Monitor Logo
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
