Question about Pentair Minimax NT Heater
I have a pentair minimax that the display will not light up or come on. I only have 15 VAC coming from orange 24 VAC line from the transformer. If I tested it correctly, it only has 75 VAC coming into the transformer. Need help
  • jeffgillis Sep 05, 2010
    How much voltage needs to be coming out of the transformer to light the display? I could not find any loose or chaffed wires in the power box.
  • jeffgillis Sep 06, 2010
    The service manual states that the the lights on the display light in order. The power light does not come on, which leads me to believe that I have a power concern. What should the VAC read coming into the transformer?
  • 3,740 Answers
If you only have 75VAC coming into the transformer I would be looking at the power supply and the fuse / circuit breaker.
If you are direct wired and your unit is 220VAC cycle BOTH breakers OFF and then back on. Measure voltage at the CB connection checking for 220 - 230VAC on the CB line out terminals. Having one breaker tripped can cause the 75 VAC to the transformer.
The transformer has 4 inputs red to black = 120 VAC
Black/Wht - Red/Wht = 120 VAC
You should read the Orange and White wires on P4 = 24VAC
Since you did not include the model number I do not know if yours is the dual voltage or single voltage unit.
Everything I passed to you is the single voltage version. See this manual link below. There is a retrofit kit for some reason applicable to this heater. See the parts list in section G. / page 10 of the file.
http://www.pentairpool.com/pdfs/MiniMaxNTSingleVoltageTempControllerRetrofitKitIG.pdf
I do not know why there is a retrofit kit available. You may want to find out if this a warranty or recall issue.
Pentair Contact info:
Pentair Pool Products, Inc.
1620 Hawkins Ave., Sanford, NC 27330 • (919) 774-4151
10951 W. Los Angeles Ave., Moorpark, CA 93021 • (805) 523-2400
Thanks for choosing FixYa.
Kelly
Posted on Sep 06, 2010
  • 857 Answers
There are a lot of things you can do, please find the manuel below go to this link read the manuelsee section 4,5 and 6.
http://www.pentairpool.com/pdfs/MiniMaxNTLNIG.pdf
Posted on Sep 05, 2010
I have a Minimax 250 heater that will not turn on
Check power from breacker or timer then to Rocket switch in bottom the heater where the elect power go in ,after that chech for 24 to 28 vac caming out the transformer going into back circuit board .
Aug 18, 2014 | Pentair Minimax NT Heater
Hello, I have pentair minimax 250 pool heater. When turning on the temperature, ddtc cycle to off. Nothing happen, no clicking noise, blower doesn't turn on , no error code on LCD. No led light in the back...
check main power supply for proper voltage, check primary and secondary sides or transformer, 24 vac getting to display screen???? 120 vac getting to blower???
Nov 27, 2013 | Pool & Spa
Minimax NT.. Shows green power light on control panel, but will not start up when turned on remotely. If i turn the main power switch on the unit off the on the fan comes on for about 15 seconds then...
I would call the Pentair technical support line because they may be able to help you figure this thing out. I hope this helps.
Please vote on this answer. Thank You.
Aug 24, 2011 | Pentair Minimax NT Heater
Purex Triton MiniMax Plus 400 power light is not turning on nor is unit. Checked for power going to unit and no fuses appear to be blown. Thoughts on what might be the issue? Thanks, Dan
if you have incoming power, you may have a bad transformer. those systems run on 24-28v. you can check from yellow wire to yellow wire coming off the transformer to see if you have anything coming out. must check wires coming out of the transformer to each other, it won't register if you check each one individually to ground. hope this helps...
Aug 11, 2011 | Pentair Minimax NT Heater
Pentair MiniMax NT pool heater not working
check breaker maybe popped check ignitor
Sep 29, 2017 | Pentair Minimax NT Heater
No power, display lights nothing seems to light up, not sure, there is power in the unit though?
Check power into and out of the transformer. You should have either 115 or 230 VAC in and 24 VAC out. If no power out but power in, replace the transformer. If no power in look for tripped GFI, breaker, etc.
Dec 27, 2009 | Pentair Minimax NT Heater
Err light on on pentair nt minimax. pushed power button, won't go off. any suggestions?
24 v at the transformer ? if yes unplug thesmostat probe if 888 change t probe if err change t board
Sep 06, 2009 | Pentair Minimax NT Heater
No display lights
Make sure you have 24 volts coming from the transformer...Alot cheaper part.
Jun 01, 2009 | Pentair Minimax NT Heater
Pentair Minimax NT Heater Logo
114 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
