Question about Husqvarna 160 CC Honda OHC Engine 21 in
I have a honda o h c push lawnmower it starts easy but cuts out in about 30 secs
  • 4 Answers
I have the GVC160 motor....same problems....just found this info (see link),...and it turned out that Honda used a NGK spark plug that was defective,....I couldn't believe that is all it was...after changing the carb (new),...adjusting valves....etc.. I just went down and bought a new spark plug.....and it runs great!!
BEFORE go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers - http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
Posted on Sep 25, 2010
Can u send me the Honda gcv 160 cc and 21 lawnmower engine start video step by step in my mail id
1 - make sure ignition switch is on
2 - make sure that gas switch to motor is in "on" position
3 - Set choke to start position
4 - fill with gas
5 - Pull on starter till starts then push choke back in.
Jun 10, 2017 | Honda Garden
Honda 125 innova kick start problem
Picture a lawnmower. Pull the starter cable with the lawnmower on its side. Envision the movement being the same on the kick start. Removal of the cylinder housing requires removal of the starter arm. Many scenarios the arm connects to a gear with a bolt. Recommend bike shop. So as not to damage gear.
Aug 27, 2015 | Honda Motorcycles
My mantis tiller with a honda gx22 engine starts then shuts off after approx. 30 sec.
If your unit has a primer bulb, start your engine . When it starts to die push your primer, if the engine comes back to life you have a carb issue.
Aug 09, 2014 | Mantis Tiller 4-Cycle Engine Handy Item...
Honda easy start
Replace coil assembly or cord. Available any lawnmower parts place/repair shop.
May 26, 2013 | Honda Garden
Lawnmower keeps cutting out
drain out the fuel and try fresh fuel gas is only good for 30 days in small engines
Mar 27, 2012 | Garden
I have a Honda GCV 160 LAWNMOWER IT WILL ONLY RUN WHEN FULLY CHOKED
BEFORE you go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, runs for 10-30 seconds, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers ---- http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
Mar 31, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Honda gx120 starts runs for 45 secs, cut out then will restart 45
Sounds like fuel starvation. there is a small filter insde the tank. if you take the tank off you will see that where the fuel hose attaches to the tank. this spigot unscrews from the take to reveil the filter.
Hope This helps
Oct 01, 2009 | Karcher 2500 PSI Pressure Washer
Lawnmower cuts out on fast idle + runs rough
REBUIld carb it is dirty jet is clogged
May 25, 2009 | Echo Garden
Husqvarna 160 CC Honda OHC Engine 21 in Logo
524 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
