Question about Sharp R-510HW Microwave Oven
Sharps microwave i have a sharps microwave model r-520 JKF when you put the time to cook in the time part is work but the microwave is doing anything inside
  • 2 more comments
  • voltext2000 Jul 22, 2008
    Hi supporter I have a sharp carousel microwave and the timer works. But no light nor is it heating. Could it be the fuse or the magnetron? Any info would be highly appreciated. Thank you......
    Me again just to be on the right side. you asked these questions and the answer is no for all. Except for the timer when I push start, the timer counts down till it reaches zero then the normal beep sound.
    Just to be sure, you press Start and what happens? the timer counts down till it reaches zero then you hear the normal beep sound.
    Does it count down? yes, work's great.
    Does the inside light come on? NO
    Does the fan inside come one? NO
    Does the turntable rotate? certainly NOT!
  • chuckmct Oct 20, 2008
    I have a Sharp 520-K echibiting the same symptoms. When I hit the start button I hear a click (like a relay clicking) and then the timer starts counting down to zero. No fan, no turntable, no light, no nothing. It is now a 5 cu. ft. egg timer.
  • William Miller
    William Miller May 11, 2010
    Does it count down?
  • 143 Answers
The door switches go bad...little micro-switches. Check them for switching on and off. Some are closed when the door is open, some are open when the door is open. It could even be that the catch has moved out of adjustment. If that isn't the problem, you have to consider the brain board which is usually so expensive that the microwave is not worth fixing.
Posted on Jul 23, 2008
What causes microwave to blow new fuse?
The only thing inside a microwave oven that draws enough current to blow a fuse is the magnetron that generates the microwaves to provide the cooking power. Based on the age of the unit (approx 15 years) it is most likely best to just replace it as repairs at that level are not cost effective. Newer units cook better and faster using less power these days.
Jul 02, 2015 | Sharp Microwave Ovens
How do I replace the inside light on my R-520 ks Sharp Microwave
I don't know the exact model but most MWs have a plastic panel that pops off easily. Some, however you must take the cover off the MW oven. Just a tad more difficult.
Dec 25, 2014 | Sharp Microwave Ovens
Auto Cook not working
If autocook is not working and everything else it, there is an issue with the sensor in the oven that detects the steam, The emission of steam is what triggers that unit to shut off. If it wont cook on any settings then the issue is with the microwave generator not putting out enough power. This could be from a lot of things.
Dec 16, 2013 | Sharp R959SLMA 900 Watts Convection /...
Arcing sharp carosel microwave when i put orville redenbacher mini popcorn bags in i found oil on outside of bag
Arcing will occur if you have any metal inside the microwave, or if the powder paint on the inside has been damaged. If the paint is damaged dispose of the microwave
Oct 24, 2013 | Sharp Microwave Ovens
Sharp R-520 JKF
No! The problem is one or two bad door switches, or possibily the keypad control board.
Apr 11, 2012 | Sharp Microwave Ovens
Sharps microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number (R-520JKF) here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
Aug 21, 2008 | Microwave Ovens
Sharp Carousel Microwave oven
Assuming the unit works ok other than the display, you have a problem common to many Sharp models.
Check with www.microwavedisplay.com - lots of info on this issue and they offer a repair service for the boards at a very reasonable price.
Jul 10, 2008 | Sharp Microwave Ovens
Cooking
I would say the high voltage diode blew.
If you or a friend decide to look into it, we have critical safety and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can get Sharp parts from Tritronics at http://www.wehaveparts.com
If it's not the high voltage diode, reply back for further help.
Oct 24, 2007 | Sharp R-1610 Microwave Oven
Sharp R-510HW Microwave Oven Logo
103 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
