Question about Samsung SyncMaster 204B 20.1" LCD Monitor
How to clean surface - Samsung SyncMaster 204B 20.1" LCD Monitor
  • 11,361 Answers
Microfibre cloth and lightly warm soapy water, light damp the microfibre cloth and wipe the screen then use another dry microfibre the dry the screen.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Sep 06, 2010
How many Categories of Shot Blasting Machines?
There are five categories of China shot blasting machines: road surface shot blasting machines, tumble shot blasting machines, hook type shot blasting machines, table shot blasting machines, internal steel tube shot blasting machines.
Here's a detailed introduction of the characteristics of various kinds of shot blasting machines.
1. Road surface shot blasting machines
Shot blasting machines for road surface are mainly used to solve the defects of the concrete surface treatment. It can remove laitance and impurities of concrete surfaces at one time, and can have the coarsen treatment of the concrete surface, which brings the uniform roughness of surface. This greatly improves the adhesive strength of waterproof layers and concrete base layers, so that the waterproof layer and the bridge deck can be combined better and the crack of the concrete can be fully exposed at the same time, which is a prevention solution. Automatic reverse blowing dust collectors can clean each filter element through air blew back by the compressor at regular intervals. Then, it will be cleaned through the airflow of the assorted cleaner inside the machine. The abrasive material and the cleaned impurity will be recycled respectively, and the abrasive material can be reused. Each shot blasting machine is equipped with a dust collector so that the construction can be dust-free and pollution-free, which can both improve efficiency and protect the environment.
Advantages:
Shot blasting machines for road surface can be used in the surface treatment of the waterproof base of concrete bridges, the surface coarsen treatment of the pavement overlay, cleaning of the sign line of road, bridge and the steel box girder, improvements of anti-slide performance. Also, it can greatly improve the roughness and texture depth. The uniform roughness will not destroy the original surface structure and integrity. The entire process of construction is dust-free and impurities are completely recycled.
2. Tumble shot blasting machines
Tumble shot blasting machines are is applied for surface cleaning and strengthening of large and medium sized production parts. When the parts to be cleaned is less than 200kg, this machine can be used alone or used as a supporting facility. Applied ranges: die castings, precision castings, the cleaning of precision forgings, mass finishing, removing heat treatment parts, castings, surface oxidation of castings, and intensification of spring, rust removal and pretreatment of fasteners.
Advantages:
Tumble shot blasting machines can be applied for various productions such as large and medium-sized workpieces, rust cleaning or shot blasting of the surface. The workpieces to be cleaned usually are the main parts and heat treatment parts with weight of less than 150kg. The machine can be used alone or used as a supporting facility. It is suitable for the cleaning, rust removal, scale removal and surface strengthening of small castings, forgings, stamping parts, gears, springs and other parts, especially of fragile parts.
3. Hook type shot blasting machines
As the standard mode of shot blasting machines, the maximum carrying capacity of the hook type shot blasting machine is 10000 kg. A hook type shot blasting machine has very high efficiency and good flexibility. It is an ideal cleaning and strengthening facility, which is mainly used for surface treatment of various media, large castings, forgings, weldments, and heat treatment parts, including fragile and irregularly shaped workpieces.
Advantages:
With the advantages of large shot blasting, high cleaning efficiency, large space, compact structures and no special requirements on the shape and structure of the cleaning piece, a hook shot blasting machine can serve several purposes. It is applied for sand cleaning, rust removal, scale removal and surface reinforcement of the castings and forgings less than 15kg of various industries. This machine is equipped with a special set of dust device, so the place of installation is free from the ventilation pipe workshop and it has good sanitary conditions.
4. Table shot blasting machines
The table shot blasting machine is mainly used for volume surface cleaning of small and medium sized workpieces. It is suitable for the engine connecting rod, gear, diaphragm spring , etc. It is widely used in the casting and automobile manufacturing industries. It has several characteristics of high production efficiency, good sealing performance, compact structure, convenient loading and unloading parts, high technical content, etc.
Advantages:
The table shot blasting machine is mainly used for the removal of surfaces' sand, rust, oxide skin, dirt, etc., which can restore the surface color of the metal workpiece, eliminate the internal stress, improve the anti-fatigue performance, increase the film adhesion, and ultimately achieve the goal of improving the surface and internal quality.
5. Internal and External steel tube shot blasting machines
An internal and external steel tube shot blasting machine is a new type of net wall shot blast cleaning machine combined with the shot blasting technology to clean the inner wall of the cylinder.
It uses compressed air as its power and utilizes the kinetic energy of accelerating projectile to shoot the cylinder wall. When the cylinder located in the gun room, the gun will automatically insert into the respective bottle and the spray gun will move up and down in the cavity. Then it will complete the full range of cleaning. Inside and outside wall shot blasting machine is the selected type of the cylinder industry.
Advantages:
An internal and external steel tube shot blasting machine is mainly used for architecture, bridge and other industries. It is used for rust removal of the large I-shaped steel, H beam and surface. It has advantages of large shot blasting, high efficiency, rapid blade replacement, overall replacement performance and easy maintenance. Shot Blasting Machine Manufacturer China Shot Blast Machine
Aug 04, 2017 | Heavy Machinery
For Nd:YVO4 crystal, do we have anything to note for?
When you receive crystals from FOCTEK, please make sure that only qualified personnel are able to open inner packing at clean environment. Please prevent finger print, oil and other substances from adhering to the polished or coated surfaces.
If the surfaces are contaminated, please blow the surfaces with air ball. If there is still pollution on the crystal surfaces, please clean the surfaces with cleaning liquid and soft silk. The mixing liquid of 50% high purity alcohol and 50% high purity ether is recommended as cleaning liquid. Please notify that the contaminated surfaces are very easy to be damaged. When polished surfaces are fogged or damaged, please ask FOCTEK for repolishing and coating service.
For more: http://antyco.com/
Sep 20, 2016 | Microsoft Office Professional 2007 Full...
How to clean T-FAL toaster
Hi Anonymous
The toaster has a removable tray that unclips at the botton for easy cleaning. If you have a stainless steel toaster and are enquiring about cleaning the surface use a soft clean cloth dampened with water and wipe it down regularly ONLY WHEN THE SURFACE IS COLD. If the surface is scratched you can try a stainless steel cleaner.
Hope this helps
Kind regards
Aug 15, 2014 | Dualit 20247 2-Slice Toaster
Can I use Sprayway 360* multi surface cleaner on carpet
I highly recommend that you don't. Most multi-surface sprays are not made for carpets, but hard surface materials. They may contain disinfectants that could actually bleach or harm the carpet. I recommend using only carpet cleaning spray or a water-Lysol combination.
Elisa Jed ' http://www.floorcleantoowoomba.com.au/services
Mar 14, 2014 | sprayway"" 360 degree all- around...
Looking through viewfinder i see dirt & black specks
It depends where the dirt is. Following the light path, look at the rear surface of the lens. A dirty rear lens surface will have the most affect on picture quality or what you see in the viewfinder of any position in the light path. Like all optical cleaning procedures, hold the lens with the rear lens surface facing the ground so gravity will work with you. Start by blowing clean air on it using canned air or a blower such as a Rocket blower or ear syringe. If that is sufficient, do not continue the sequence. This holds true at the conclusion of each step because the more aggressive your cleaning becomes, the more risk there is of damage. If it is still dirty, gently brush it with a sable or camel hair brush. If that is not sufficient, gently wipe it with a dry lens photograph lens tissue (do not use coated tissues) or a microfiber cloth. Finally, as a last resort, dampen a corner of a lens tissue or microfiber cloth (do not put the wet solution directly on the lens) and gently wipe with a circular motion. Finish by wiping with a dry section of the tissue or cloth. Although the front surface of the lens is not as important, repeat the process for the front surface.
If you still see the dirt in the viewfinder, are two possible remaining locations; the bottom surface of the prism located above the mirror or the mirror.
Clean the prism first and avoid cleaning the mirror if possible, or any contact with the mirror. The prism can be cleaned following the sequence outlined above. If that doesn't work, the problem is the mirror.
CAUTION! The mirror is front surfaced and is very susceptible to scratches and other damage unlike a conventional mirror which is rear surfaced with the glass protecting the coating. Aggressive cleaning should be avoided.
Carefully follow step 1 of the lens cleaning procedure (air) and step 2 (brushing) if necessary. As far as the third and fourth steps, I would not use them myself because of the risk of mirror coating damage. It would be better to take your camera to a qualified repairman.
remove the lens and look above the mirror at the bottom of the viewfinder prism. If it is dirty, clean it as you would clean a lens surface. The next place to look is the mirror.
CAUTION! The mirror, unlike the mirror over your bathroom sink, is front surfaced and there is no glass between you and the delicate and easily damaged coating. Hold the camera with the mirror facing down so that gravity will work in your favor. If that does not work, I would stop and take it to a camera repairman because you do not want to risk scratching the surface by using lens tissue or cleaner.
Feb 05, 2013 | Nikon F100 35mm SLR Camera
I need to know how to clean the inside and outside of the croc crocasally boots. I have a potty training toddler who had an accident on her shoes.
As a general rule when cleaning boot, you only want to use products specifically designed for boot fabric. Avoid using a product designed for cleaning leather. It's also important to do a patch test before cleaning any fabric to make sure the color or integrity of the fabric won't be damaged. To do this, apply your cleaning product to an area of the shoe or boot that doesn't show to see what the effect will be.Here's how to clean shoes and boots at home.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Instructions Things You'll Need:
  • pencil eraser
  • A metal brush
  • A soft, dry washcloth.
  1. Prepare Your boot for Cleaning
    Start by gently rubbing the surface of your shoe or boot with a soft, dry washcloth. This helps to restore the surface of your shoe.
  2. Remove Dry and Ground In Stains.
    Use your pencil eraser to rub any areas of dry staining. The eraser helps to life out any dried dirt and debris from beneath the surface of the shoe.
  3. Smooth the Surface of Your Shoe.
    Using your metal brush, to brush the surface of your shoe or boot using a circular motion. This helps to smooth the surface that's been roughened by using the eraser. It's also good for removing scuff marks from shoes
If you are happy with my answer please vote four thumbs up. Thank you
Dec 26, 2010 | Crocs Crocasally Boot Shoes for Babies
We have a whirlpool fridge Model No. ED5HGXKQo3 and are enjoying its features, be we do not seem to be bale to keep the outer surfaces clean from various dirt inspite of cleaning. Are there any special...
Use a light coat of mineral oil on surface after cleaning . The oil will soak into the pores and keep fingerprints , dirt etc.. off or easily wipe offable .
Aug 12, 2009 | Refrigerators
2006 PRIUS GPS CAN'T READ DVD MAP
Have you tried cleaning the disk? Also inspect it for deterioration. The surface should be clean and scratch free. The reflective surface should be uniform. Nothing that looks like water marks or deterioration. Also you might want to try putting a cleaning disk as is used for CD/DVD players in there to clean the lens surface.
Apr 05, 2009 | 2008 Toyota Prius
Nikkor Lens Fix
The fading (flare) you see could simply be a finger smudge or other stuff. One little scratch won't do it, you'd have to take sandpaper to the lens to see obvious flare.
It's actually harder to scratch a modern lens than most people think. When it happens, it's usually during cleaning when a tiny piece of grit is on the surface and gets rubbed in by the cleaning cloth/lens tissue.
So the first step in cleaning a lens surface is to be sure you remove all dust and dirt without rubbing. The lens cleaning kit you can find in any camera store is a start -- it contains a blower brush. With the lens surface to be cleaned facing down (so dust falls away), brush gently with the tips of the bristles to dislodge stuff. Then use the blower to blow it away. Repeat as needed.
If you still see dust and dirt which seems to be stuck on the surface, take a piece of the lens tissue from the kit and put several drops of the cleaning solution on it, enough to get it pretty damp. (Always apply cleaning solution to the tissue or cloth, never drop directly on the lens surface.) Cover the lens surface with the damp tissue, pressing it into the corners, but do not slide the tissue across the surface. Just lift it away. Repeat with another section of tissue.
Then take a full sheet, wad it lightly, and wet it. You are going to rub lightly, using a roll-up motion as you move the tissue so that dust/dirt is lifted away from the surface and fresh tissue is always coming in contact with the surface. Repeat as needed until there isn't any visible stuff.
Final cleaning can be done with a fresh piece of tissue and a bit of mist from your breath. Mist the surface, and lightly polish with the tissue to remove any remaining cleaner residue.
Dec 08, 2008 | Nikon Normal AF Nikkor 50mm f/1.8D...
Cleaning the black surface
try the mr clean magic eraser ,i have cleaned alot of different things with this and it works great.
Dec 06, 2008 | Samsung 18.8 Cu. Ft. Bottom-Mount...
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
56 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
