Question about Shop Vac 925-13 Canister Wet/Dry Vacuum
Sulfur and rusty water in my well how can i clear it up
  • 15,935 Answers
Usually this is from a compromised liner.
Have the well pipe re-lined.
They usually just put as smaller O.D. pipe in.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 05, 2010
My Hoover 2X PetPlus Pet Stain & Odor Remover (64 oz) turned my off white carpet rusty orange! The liquid itself was orange brown. Is this the normal color?
I don't believe this is normal. I would contact the company. I would use 1 part white vinegar to 2 parts water and put it in a spray bottle. Use that to clean pet stains.
Sep 19, 2016 | Hoover Vacuums
MY IRON IS NOT THAT OLD AND IS LEAKING RUST, WHAT CAN I DO?
You must always use Distilled Water in the iron. Try running a few cups of the distilled water through the iron. Iron on something you don't mind being ruined from the rust. It sometimes will flush the rusty out. If it is old and you've been using tap water the whole duration of using it you may need to purchase a new one. Good Luck!
Feb 14, 2011 | Vacuums
The brushes won't turn. I have turned the switch
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Hoover Steam vac.
http://www.usavacuum.com/Hoover-F5903-F5904-F5905-F5910-F5912-F5914-F5915-s/138.htm
It is part # 43191008
Mar 22, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brushes do not move any more how can I access the belt area to replace or inspect
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Please give positive feedback.
Mar 04, 2010 | Hoover STEAMVAC VACUUM Vacuum
New Hoover Steam Vac's brushes do not spin
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced. You can find a genuine hoover replacement part by following the link below.
Turbine Brush Gear Part # 43191008
F5914 Parts Link
Feb 28, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brushes donot turn when asked to shampoo
Hoover SteamVac Replacement Turbine Brush Gear Part # 91001097
F7425 Parts Link
http://www.usavacuum.com/Hoover-Steamvac-s/109.htm
Feb 09, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes do not turn
F7425 Parts Link
Dec 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The brush won't spin on my hoover shampooer
This machine has an airdriven turbine that drives the brushes. The turbine needs to be replace because it is spinning on a steel bushing which gets rusty from all the water going through it.
Nov 26, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Leaking rusty water
Ensure the black "duckbill" gasket is mounted on the bottom of the dirty water tank. This gasket is removeable, and resembles a duck bill.
When i purchased mine at Target, new - it was missing the gasket, causing loss of suction. Interestingly it worked for a week or 2 then started leaking. Now, with the gasket in place, it works like a charm.
Gasket is about 2 bucks available from Bissell.
Aug 14, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell proheat
Where the lip of the tank sits on the clear window, is the gasket there? If it is missing, it won't suck up the water. It is black, oblong (#24)and sits in a slot on the clear window providing a seal for the tank. Is the filter clean(#62), should be sitting in the square opening on the bottom of the lid, it sits right over the sucking opening.
Feb 25, 2008 | Bissell 1699 ProHeat Clear View Upright...
Shop Vac 925-13 Canister Wet/Dry Vacuum Logo
Top Shop Vac Vacuums Experts
Jim Parker
Jim Parker
Mike
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
