Question about Garden
My qualcast classic 35s is "hunting" ideas on how to cure it would be much appreciated. Have no manual for it bit apprehensive about messing with it myself in case I make it worse! Thanks
5 Suggested Answers
braintrust
  • 62 Answers
SOURCE: need instruction manual for a Qualcast Classic
you can go to qualcast.com and down load any manuel you need, must have serial number or part number
Posted on Oct 28, 2009
Testimonial: "Thank You I will try to obtain a manual . "
  • 6 Answers
SOURCE: what oil and petrol do i use for my qualcast
is it a two cycle or 4cycle do you mix your gas and oil or is it stright gas.
Posted on Jul 08, 2009
  • 16 Answers
SOURCE: i have a qualcast 35s petrol lawnmower and i cant
Hi, first of all I would check that the cutting cylinder is correctly adjusted, i,e, just kissing the bottom blade.dont forget to re-adjust the chain. next i would remove the four engine mounting bolts and slide the engine away from the clutch drum so that you can check if the clutch shoes are binding on the spindles, if the spindles are rusty centrifugal force will throw the shoes outward to engage the drum but the springs wont be able pull the shoes back.try wd40 on the pins while trying GENTLY to revolve the shoe round the pin, hope this helps
Posted on Sep 12, 2009
mowerman1857
  • 389 Answers
SOURCE: lawn mower not quite starting
Sounds like you have dirt and/or moisture in the carburetor float bowl. Remove the bowl and clean it out. place a small pan or bowl under it when you start to remove it to catch the fuel and look for water. It will look like a "bubble" floating at the bottom of the fuel. Get a can of areosol carburetor cleaner with a long tube on it, stick the tube up in the hole where the bowl nut goes and spray it out to remove and fine dirt that may be in there. The following is in CAPS because I cannot stress enough, the safety and hazards of using the carb cleaner:
USE SAFETY GLASSES/GOGGLES AND BE VERY CAREFUL USING THE SPRAY - - IT WILL BURN YOUR EYES AND IF YOU HAVE SENSITIVE SKIN IT WILL BURN THAT TOO
Posted on Sep 15, 2009
I need a user guide for a qualcast classic 35S mower
thats quite an old machine now s could be difficult to find a user manual. is there anything in particular you want to know?
Mar 14, 2015 | Garden
Qualcast 35s manual
go to ereplacementparts.com look up your model and see it a replacement muffler is available,,,there are a couple of universal model designs and are available at Home Depot or Lowes
Aug 12, 2014 | Garden
Qualcast classic petrol 35s
Hello david I think you need to check the air filter is clean. This should sort it.
Aug 31, 2013 | Garden
Replacing Tap on Qualcast petrol tank
It should just screw out, there is a thread on the plastic fuel tap, they can be pretty tight.
Jun 09, 2013 | Garden
Looking for a manual for 3.5qt. platinum classic model #pchc-35s
Try Googling (platinum)(pchc-35s)(manual) without parens.
Jan 05, 2012 | Crock Pots & Slow Cookers
I have a Qualcast Classic 35s there is no spark at the plug (new plug fitted) still no spark when held against cylinder head. What is the cause. It was working fine when I put it away last year. What is...
hi there
suspect engine is briggs and stratton 3.5 hp vertical
pull the wire at the kill switch and retest for spark -if still none
remove starter cover , pull wire off at magnetron unit retest
if still none replace magnetron coil and reset air gap to 0.010 "
assemble up and connect kill wires of course and let er rip
cheers pauly46
dont forget the thumbs rating
Jun 02, 2011 | Garden
Qualcast Suffolk Punch 35s lawnmower running problems
There is a small idling mixture screw on the side of the carburettor.
As the engine is not well suited to the carb. it mainly runs on the idle setting!
As long as you are not leaving the choke on. This is a little tab on the top of the carb. You start with it set on C then soon set it on the middle position, and after about 3 mins turn it off.
Jul 12, 2010 | York Yankees Bedding MLB Comforter
Need instruction manual for a Qualcast Classic Record 35s
Oct 06, 2009 | Garden
Engine cut out!
could have water in fuel bowl or tank,coil could be heating up and stop firing or the plug
Sep 09, 2009 | Garden
What oil and petrol do i use for my qualcast classic 35s lawnmower
Jul 08, 2009 | Garden
Garden Logo
443 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
