Question about Craftsman 25cc Gas Line Trimmer
What is the fuel ratio for a craftsman 17"/25cc weedeater
    President:
  • Craftsman Master
  • 1,545 Answers
40:1 (3.2 ounces oil per gallon of gas) Use synthetic oil and Stabil gas stabilizer for best results.
Please vote on this solution.
Posted on Sep 05, 2010
  • 1 more comment
  • Havn Fun Here
    Havn Fun Here Jul 28, 2011
    Should be 4Oz. of Two Stroke Oil per ONE "1" Gallon of Reg-Unleaded Fuel.
  • Roy Cagle
    Roy Cagle Jul 30, 2011
    OK, then why are the single serving bottles of 2 stroke oil that they sell 3.2 ounces ? I feel that you are mistaken....want to see proof...look here!
    http://support.mtdproducts.com/app/answe...
    Most all machines now are 50:1. Older Poulan's (Sears, etc) are 40:1. Your ratio you have stated is 32:1....too much oil per the modern EPA emission standards.
  • Havn Fun Here
    Havn Fun Here Jul 30, 2011
    No I am right on as that is the mix that it says to use on my 25cc unit. It is a 24 year old Poulan "Weed Eater SST45 Model" It has never needed work as most likely to having used the correct mix for 24 years. Please know what it is you are talking about before you jump on your soap box. ;-)
What is gas to oil mix ratio on weedeater string trimmer
The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
Sep 19, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
How do the fuel lines in a weedeater trimmer pe550 hook up inside the gas tank
I have an older model that has a weighted filter in the tank. The filter flops around and can 'fall' into the fuel no matter which way you tilt the trimmer/tank. You should have one in your tank. Feed in the new line and make the end come out the gas cap. Push the filter/weight into the end of the fuel line. Pull the extra fuel line out of the tank to match the original position. You should have cut the new line to approximately the proper or same length as the old fuel line with an angle cut so you could push it into the tank.
Jul 23, 2014 | Poulan Craftsman/poulan/weedeater Fuel...
Ratio for oil and gas on a ryobio weedeater
if you are using stihl oil the ratio is 50:1
Jul 03, 2010 | Ryobi Three Trimmer Combo
Need to know the gas:oil ratio for weedeater FL1500
100 ml of 2cycle oil to 4000 ml of fuel..Which is 40/1 ratio
100 ml of 2cycle oil to 5000 ml of fuel.. which is 50/1 ratio
4 o/z is 118.29411875006815 ml to 1 gallon of fuel (3.79 litres or 3790 ml) Which means 32/1 ratio...I find that to confusing,so it is easier to say 100 ml of oil to 3200 ml of fuel ===32/1.
Oct 27, 2009 | Poulan Featherlite Gas Blower, with Low...
Craftsman weedeater model # 358.796090
I would first clean the air filter, check fuel lines for cracks and check the fuel filter inside the tank, if those look good try adjusting then if necessary rebuilding the carburetor.
Also you might move your post to another section; it is under timers not trimmers. ;)
May 21, 2009 | Hardware & Accessories
Craftsman weedeater wont start
The problem that I had with my craftsman was that I found that there was a tube in the fuel tank that goes to the carb, & at the other end - inside the tank, there was a small screen with maybe a weight on it (to keep it in the gas no matter what position the weedeater is in). Mine was plugged up and i went to the saw shop and got a generic hose & end with the screen deal & changed them out. Solved my problem. Rick
Mar 24, 2009 | Poulan Genuine Weedeater Part # 36006-128
Gas to oil ratio
this mixture for this weedeater is 40:1 or 40 to 1
Hope this helps You
please rate me
Jul 19, 2008 | Electrical Supplies
Craftsman 25cc Gas Line Trimmer Logo
271 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
