Question about Dryers
Electrolux edi96150 - error e50 few minutes after start of drying
5 Suggested Answers
jan mczeal
  • 632 Answers
SOURCE: AEG Lavatherm 57800 error E50
The problem is a worn motor carbon brush which connects power to the motor commutator. The carbon brushes are worn if the motor runs intermittently, if sparks are coming from the brushes, or if the motor doesn't run at all. This video should help you know more about motor carbon brushes and how they work. The video features a washing machine but the carbon brushes are basically the same.
Posted on Jun 24, 2011
E50, This is often a motor problem usually, check the capacitor attached to the motor as this starts the motor rotating. if not that then the motor itself, if the motor cap are OK, then it must be the controller board.
below is your manual.
http://www.espares.co.uk/datastore/ProductManuals/286050.pdf
see blow for some more info.
http://myreader.co.uk/msg/1391141964.aspx
ZJLimited
  • 17970 Answers
SOURCE: dryer works for few minutes
E50 code is for a motor issue or main PCB fault on the motor output side (also called E51 when the triac that is on the main control board normally shorts out due to a faulty motor).
Not easy to diagnose as a diy job, but you need to find out if the drum rotates correctly when fully loaded. Could check this CODE LIST
Hope this helps.
Posted on Jul 01, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Electrolux EDC77550 drum dryer starts normally but stop after running couple of minutes.
    If motor runs continuously with power applied, check for short circuit across motor relay (RL2), or L1 applied to motor relay output (J3-1) with cycle stopped. If motor does not start when Start key is pressed, check for open circuit between L1 and motor relay connection (J3-2). If no wiring problems found, replace Main Control Board.
    Posted on Aug 17, 2012
    Error E50 an electrolux edh3786gdw dryer
    E50 is a motor related error on this model...check to be sure the belt and idler pulley are in proper position, make sure a sock or other garment has not fallen into the filter housing and jammed in the blower fan...
    Jun 29, 2016 | Electrolux Dryers
    SOURCE: E50 what does it mean, Hello & Welcome to FixYa E50 in your Electrolux is a motor error and is displayed due to a bad motor or a bad motor capacitor. Check if the motor brushes are ok
    Hello Baldur Thor, thanks for your inquiry!
    From what you have described your Electrolux air conditioner is displaying an "E50" error code. I do not show an "E50" has a valid error code. Could you please verify which appliance you are having issues with? Additionally, you could perform a reset on your air conditioner which is disconnecting the power from it for ten minutes. If you continue to have issues please reconnect. -Matt
    Dec 21, 2014 | Electrolux Heating & Cooling
    Electrolux front loader E50 error
    Hello Friend, thank you for your post!
    I see you are receiving an error code E50 on your Electrolux dishwasher. Is it possible that the code is missing characters? Could it possibly be an E50? May I please have your model number? The serial tag, which lists your model number, is typically located on the right side as you open the door. With this information I can further address the issue at hand. In the meantime, I suggest resetting your dishwasher. You can do this by flipping the household circuit breaker off for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display E50. Thank you - Z.
    Apr 12, 2014 | Zanussi ZWF1640 Front Load Washer
    Aug 14, 2012 | Electrolux Dryers
    Dryer works for few minutes then stop and E50 error code is appeared
    Hope this helps.
    Jul 01, 2011 | Electrolux AEQ8700F Electric Dryer
    Front loader washing machine EWF1087 stopped half way and did not drain, E50 was displayed. Emergency emptying out the water was done and try to restart. Could not start, still displaying E50. What to do?
    the error code E50 indicates that the motor has become overheated, you should give it an hour to cool then try running the washing machine again. I'm also including a link to pdf below with the common error codes for your brand of washer in case you have any other problems
    http://www.applianceblog.com/mainforums/attachments/frigidaire-electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwashers.pdf
    Jun 17, 2011 | Electrolux Washing Machines
    Electrolux EWF1090 front laod washer not starting cycle? Error E50 is dusplayed on panel, however product manual has no reference to error E50? - NEED HELP
    e50 is a motor error code,, this could be the motor itself of the wiring harness or the main computer board
    Jan 26, 2011 | Washing Machines
    A washing machine Electrolux EWF 1025 does not start up.
    E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
    Jul 24, 2010 | Electrolux Washing Machines
    Electrolux ewf 1435 washing machine
    i can not find e50 in any of my servive manuals, are you sure it is e50 ?
    Feb 16, 2008 | Electrolux EW1000i Front Load Washer
    Dryers Logo
    1,431 people viewed this question
    Top Dryers Experts
