Question about U-Line Échelon 2075CSS Built-In 48 Bottle SS Wine Refrigerator
U-Line BC75DT Beer Cooler
I have a U-Line BC75DT beer dispenser. It is keeping a temp of 40F right now. The thermostat shows a setting of 9.0 as coldest but the knob only goes to 6.5. I pulled the knob off, it is pin indexed so it only goes on one way. I tried to turn the metal pin under the plastic knob but it won't go any farther either. The compresser is drawing 1.7 amps when it's running. It kicks in about every 10-15 mins for a couple minutes. I checked the condensor and cleaned it, it had a liitle dust, not much though. Is there a trick to turning this thing colder. I'm sure if it ran more it would get much colder. Any ideas??
    New Friend:
If the fans work and the thing is cooling, make sure you have a sealed conditioned space, and that should do it. If the gas had leaked out, it wouldn't work at all. Don't mess with the compressor if it's running, at least exhaust the other possibilities first. Just put a good faith effort into being certain the entire conditioned space is thoroughly sealed. I recently did one of this exact same model; due to water damage, the seal was open for about 3" on the top edge of the door. I added a lever latch to pull the door home that last tiny bit, achieving a perfect door seal every time. Also: where the wiring harness passes through to the compressor compartment needs to be insulated/sealed, and this is no minor thing because all the heat that is removed from the keg is released into said vented compartment. Once your certain of a sealed space, put a pitcher of hot tap water in there with the thermostat turned all the way down...forget the dial, just forget that...and with the door left closed, in a room-temp room, it should cause ice to form at the top of the pitcher in about 12-24 hrs. Achieve this, you've achieved a successful functionality-based restoration. Continue to the point of making it shiny and pretty all over, you've done a FULL restore.
Posted on Nov 28, 2017
  • Taylor Ginther
    Taylor Ginther Nov 28, 2017
I neds parts for beer master u-line
Posted on Jul 17, 2013
2 Suggested Answers
tech master
  • 120 Answers
SOURCE: True TDD-1 beer kegerator condensor fan not running
cenck for volatge at wire harness and if you get the right volatge then repl condenser motor you can use a small portable fan just face it at compressor while you look for part and tha will kepp compressor from over heating and tripping the relay on it ok
Posted on Oct 15, 2008
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
If the dial is labled 0-9 what nimber is the coldest?
0 is warmwst,9 is the coldest.set it at +2C so that wine/beer dont freeze.beer is best served at 2c.
Dec 31, 2010 | True TBB-2 Beverage Cooler
It has a temp control knob. but wich way is to
9 is usually the COLDEST setting on fridges. Place a thermometer in there, try different settings, give the unit 24 hours of closed-door operation to get an accurate reading.
Nov 25, 2009 | True GDM-12 Refrigerator Commercial
Fridge keeps freezing up
Then replace the thermostat. It's cheaper that wasting all that beer. Seriously I think your thermostat is broken and stuck on coldest setting. Sea Breeze
Aug 21, 2009 | Kenmore 564-91179400 / 564-911714001
Thermostat setting on frigidaire bar fridge 1 - 10
10 is the coldest. Hope this helps you:) I keep mine at 6 and its great.
Mar 16, 2009 | Refrigerators
Refrigerator side is freezing contents
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
If your settings are right then the cold control switch is the problem
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigerator is freezing.
Now, why is too much cold air getting over to the Ref side?
1. The little door is open too much.
check your control setting. You should be able to feel air coming through the channel on the Ref side
2. The cold control is bad causing the compressor to run too much.
Nov 13, 2008 | Frigidaire FRS26R4A Side by Side...
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Which way do you turn the temp. knob
loper the number on the thermostat dial, warmer the fridge. higher the number, colder the fridge. normal setting is about "3"
Apr 19, 2007 | Magic Chef MCBR170 Compact Refrigerator
Cooler is freezing my Beer!!
Could be the thermostat isn't working and the unit is just running and running all the time. To me that seems the most simple explanation right now. Can you check the temp inside when on the lowest setting for a day, then turn it up to the highest for a day and see if there is a huge difference in temps? Does the compressor motor ever turn off or does it run continuously? Suspect that t-stat...
Nov 20, 2006 | True 3 Keg Direct Draw Beer Dispenser,...
Refrigerators Logo
929 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
