Potterton statesman oil central heating boiler the household oil ran out and i had it refilled and now the lock out button is illuminated i believe i have to press the burner reset button but not sure where to find it and i do not have the original handbook thankyou
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. You will have to push and hold the reset in on the side of the control for 15 seconds. But you will also have to bleed the air from the system from the 3/8 nipple on the lower left side once the lockout has been released and the motor starts.
Posted on Sep 05, 2010
Hi, I have a drayton lp522 programmer with a
go to boiler Disconnect red line and jump out White and red line at boiler if the fires reconnect red line and replace thermostat
Sep 23, 2013 | Heating & Cooling
Puma 80 potterton hot water on and off
Boiler compartment ventilation will not stop you getting hot water . Its sounds like you have problems with a sensor or the water section on the boiler .
Apr 20, 2017 | Water Heaters
Potterton statesman utility boiler making screaching noise for 20 mins on start up then stops screaching and runs quietly!!!
Hi my boiler has just started to do the same. Have you had yours fixed and do you know what the cause was and how the problem was solved?
Thanks for a reply
Feb 18, 2010 | Heating & Cooling
Fitting room stat
take the link out and fit stat wires in its place,will work then.
Dec 18, 2009 | Desa International CBN30T Central Heating...
Hi. We recently moved to a rented property. We have a ST7100 Central heating and a Potterton Profile 50e boiler. However even though I have set the times on the ST7100, the heating ligth comes on, but the...
You definetly have a control issue. However trying to diagnose the exact problems that you have would be very difficult without actually seeing the wiring. You defintely have a wiring/control issue but I cannot tell you exactly what it is without more info. Sorry, I would love to help you more...
Nov 13, 2009 | Honeywell Electronic Programmable...
Potterton Suprema status light.
Are you getting Hot water and Heating?
The reason i ask is because I don't think you have a problem.
On this boiler it has a 'pump over run' thermostat incorporated into it, this ensures heat escapes from the boiler by using the pump to cool it down.
If you are getting hot water and heating, leave it well alone, if you reset the boiler this can have adverse effects on the boiler and evenually cause malfunction.
However, if you find that you are not getting Hot Water or Heating, then the most common fault on this boiler is the PCB (Printed Circuit Board) it is the 'brain' of the boiler and the most common fault on this make. (£160 + vat)
I hope this helps,
Steve
Jul 06, 2009 | Broan-NuTone 658 Central Heating System...
I need to restart my boiler after running out of oil
Try a website called www.repairclinic.com and see if that will answer your problem.
Jan 19, 2009 | Water Heaters
Heating & Cooling Logo
526 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
