Question about Maytag Kitchen Ranges
My maytag 24 in. double wall oven (electric)shows a service code #7. What is it.
The touch pad was the problem. I am replacing it. Thanks
Posted on May 13, 2008
I am trying to find a replacement part for a 24 Maytag Wall Oven, model CWG3100AAB. I am getting an F5 code, and I believe that means it is the ERC electronic control board.
Single/Double Wall Oven - Error Code/Message - F5 Error ...
MaytagHave a Maytag product question? Maytag's product help articles give answers to your frequently asked questions (FAQs).
Sep 30, 2015 | Maytag CWG3100AAB Wall Oven gas
I got a GE double wall oven and when I turn the oven on code F1 comes on
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Aug 06, 2011 | GE Built-In 24" Double Electric Wall Oven
I have not had any problems with the double oven till today. after the oven reached the temperature set & the dish was put into the oven, after 10 minutes it began to beep & F-3 flashed along with...
Hello Kathi,
The F3 code means the oven sensor(electronic thermostat has shorted out) if it happened using the upper the uppen oven sensor is bad and if the lower oven that one is bad,it only affects that oven and the other one can be used, if it something you think that you could repalce the part number is 74010385, seeing the new one you would know where it goes if you chose it to repair yourself a google search using the part number should be very easy to find the part
Jul 25, 2011 | Maytag 24" Built-In Double Electric Wall...
White maytag gas and broiler wall oven is flashing F 7, what does it mean?
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Mar 12, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
F7 alarm
EVERY failure code schematic i look at on maytag states that if your getting a f7 code then your keppad has failed or is stuck... make sure you turn breaker off for approx. 30 seconds and run your hand across touch pad firmly pressing down on all the keys... reset breaker and try again... if it still faults then you are going to have a bad touch pad... be warned though the touch pad does have a ribbon cable that connects to the control coard and it is possible it has shorted control/display board as well... hope this helps you out ...appliance servicer for 18 years
good luck
Jan 05, 2011 | Maytag 24" Built-In Double Electric Wall...
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Jun 26, 2010 | Maytag 24" Built-In Double Electric Wall...
Bosch oven function error e124
Can you provide a model number for your oven. Is it a single oven or double ? Wall oven or free standing range ?(conventional with cooking surface)
Unfortunately the error codes for Bosch are different depending on the model of the unit.
Thank you, I`ll look for your reply.
macmarkus :)
Jan 09, 2010 | Bosch Ovens
I need to know which kind of plug is used on this oven so that the electricians can install the right kind of receptacle. Maytag cwe5800acs 24 Double electric wall oven
Your oven needs to be hard wired to a junction box. No plugs on a oven that pulls 30 or more amps 220v Read your install book that came with the oven.
Dec 01, 2009 | Maytag CWE5800A Electric Double Oven
I have an in the maytag gas oven that keeps beep and show f-1 when its shut off
This simple test will help determine whether the ERC (Electronic Range/oven Control or Clock) or the touch pad is defective when this error code is present.
1. Disconnect power to the range/oven (unplug the range/oven power cord or turn the power off to the range/oven at the circuit breaker). It is very important that the power to the range/oven has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC/EOC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back (usually accompanied by a beeping sound).
7. If the code comes back and the beeping as well, replace the ERC(control board). If it does not, replace the touch pad.
Nov 02, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Kitchen Ranges Logo
49 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
