Question about Gateway FPD2275W LCD Monitor
New 19" flat screen monitor only shows analog on the screen
Just bought a LG 19" flat screen monitor. Running windows XP home addition. The screen came up OK initially but now only shows analog when the computer is started, the rest of the screen is black. Any suggestions?
I have a problem a wire came out from the my high def widescreen computer and i put it back in but it goes on then turns right back on and i have 2 screens but it one works and the one when i put in the wire back doesnt
Posted on Sep 20, 2008
  • 655 Answers
Finwiz,
When you on your computer, does any thing appear on the screen, some text display/logo etc.?
If yes then:
  • After making power on your computer start pressing F8 till boot option menu appears.
  • Then select safe mode and if it works, then goto device manager and re-install driver for your display.
If no then:
  • Check out the connection from monitor to computer and try. If still no luck then post comment whats you did and what was the result.
Thanks
Iqbal
Posted on May 12, 2008
When i on my pc then the lg screen show me message analog power saving mode and then screen turns black. how can i overcome this problem
I would say that it doesn't see any signal coming from the computer. Check your output. Check the video drivers. Try another video display.
Aug 10, 2011 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Installed RAM and now monitor has no display. I
The splash screen with the LG Flatron logo is the monitor's splash screen not the PCs.
The machine is NOT booting up the splash screen is the monitor coming on.
Remove the 1Gb stick an see if the machine performs normally.
If it does then power it off, remove the power cord and CAREFULLY reinstall the new stick.
If it fails to boot you may have a defective memory module.
If the machine fails to boot with the new stick removed make sure you have the original memory seated properly and all cables securely attached
Jan 03, 2011 | EliteGroup Computers & Internet
My L G 19 "LCD Monitor showing analog power savings mode . How to solve it ? diliprakshit71@rediffmail.com
i think the problem is not the monitor but the inputs like the cpu where the video card or the rams are the culprit
Sep 03, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Can't get monitor out of energy save mode
you talk about a dell monitor but categorised under LG monitor... if it's a Dell monitor, and its recent, it's possible you've put it in analog/digital mode when you need the other mode. push the left button on te front of your screen that should switch your screen from digital to analog or vice versa
Dec 28, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Analog- out of range
boot PC into safe mode, (pressing f8 on startup) then go to display settings and switch resolution to 640x480 (basic setting)
then reboot into normal mode, and then go to display settings and then choose an appropriate display resolution
this is caused when you replace a monitor as the old monitor ma have had different capabilities from the new
Feb 25, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Analoge power saving mode
My friend left computer on,as it wouldn't turn off, after several minutes it came back on, and told her to check some sort of box on the other computer .
As she knows nothing about computers ,and its her friends she is leaving till they get home.
Nov 22, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Analoge safe mode
Go the desktop, right click with mouse and select properties (if it is XP) then it will open Display properties -->
There you need to go to Screen saver and then to Power option
Disable any power off mode on/ Sleep mode. It will solve your problem.
Please rate the solution. Otherwise let me know for further assistance.
Mar 19, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Analor out of range
lower refresh rate to 60hz
Oct 28, 2006 | LG L1722P 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
166 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
