Question about Garden
I have a sanli mulcher lawnmower about 3years old, always ervicedand looked after. last few uses its been gutless. today it was running but stopped. when I went to restart it, it made ratchetting sounds, and backfiring thru the carb and wouldnt start. cleaned plug etc and eventually pulled off rocker cover - inlet valve jammed open. took head off, cleaned valve etc reassembled. still wants to backfire thru carb. Now I'm wondering if its possible that the cam has jumped/stripped a couple of teeth, putting the valve timing out? Anyone know if they have metal or fibre gears for the valvetrain, A copy of a workshop manual would be helpfull!!
  • Kelly
    Kelly Sep 05, 2010
    What is the engine number and brand so we can get the right service manual.
    Kelly
    President:
  • 1,545 Answers
Never heard of a sanli. If the engine is backfiring, indeed it could be out of time. One sure way to check if it is out, is to see if the flywheel key is sheared.
Please vote on this solution.
Posted on Sep 05, 2010
Engine stop cord on lawnmower
need more info....
Jul 13, 2014 | Garden
Kia rio 2003 alternators burning up?
Check Alternator Voltage regulator if it fails it can send up to 18volts to the battery and make sure your battery is not too old usually most batterys will fail after around 2-3years causing the alternator to work harder . Also check your fuses someone may have put a wrong fuse somewhere. Don't buy a used alternator. Good luck.Student Mechanic LWIT Kirkland
Sep 01, 2012 | 2003 Kia Rio
I have an older Black & Decker electric lawnmower
Does the mower sound like it is running at full speed? Have you double checked that the blade was not installed upside down?
Aug 06, 2011 | Black & Decker Garden
Can you please find the frequencies for the san diego county, like san diego police 856.500,escondido police 861.000.and maybe fire 154.325 this is what i;m looking for. thank you
Hello dan,
Welcome to FixYa.
My name is John and I will be assisting you with your issue today.
You can get the frequency's you need for your state here www.RadioReference.com .
You can also get them here www.RadioFreq.com .
I hope this was helpful to what you were looking for!
Thanks for choosing FixYa today and in the future.
Comments are always welcomed here!
John
Feb 23, 2011 | Radio Communications
Craftsman 22hp 7500 zero turn mower 3years old.
Be careful - running ungoverned will quickly destroy the engine. Look at the carburetor throttle lever. There should be two linkages attached -- one from the manual throttle lever, another from the governor. The linkage to the governor is usually a spring. Perhaps that came off or broke, or a foreign object is wedged in there.
Jul 15, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Is my Craftsman Mulcher lawnmower a 4 stroke or 2 stroke engine??
It should be a 4 stroke, the only thing I can find on it is the mulcher blades, set up called a side discharge mower. It has a 5.5 HP ,22 inch, briggs and stratton engine. Hope this helps.
May 05, 2010 | Craftsman Garden
Snapper push lawnmower worked fine last summer thru Sept. took it out today and can't get it to crank. Any suggestions to crank lawnmower after it sit up for 6 months?
Your carburator has old fuel that has turned to "varnish" essentially. It must be removed and cleaned. Next year, run the fuel all the way out so there is none left in it to turn to varnish.
Apr 15, 2010 | Garden
My craftsman 6.75hp mrs lawnmower dies out after a few seconds. I've changed the spark plug, added oil and gas, and cleaned the filter. Any other suggestions? I don't know much about lawnmowers or...
You will have check the carburettor. If you cleaned the air filter, the carb.is right under it. Or if you follow the fuel pipe from the fuel tank it will run straight to the carb. Remove the round bowl at the base, it is held on with a small screw at the bottom. Clean this out and blow out the carb. with air. You may have to remove the whole carb. to clean it right. Good luck, Stephen.
Sep 29, 2009 | Craftsman Garden
Carby problem
The problem with it, is it's a tecumseh, The damn things run great, WHEN they run. Once they start to break down on you, you may as well use them as a boat anchor.
Apr 26, 2009 | Honda Accord Cars & Trucks
Garden Logo
355 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
