Question about Toshiba Satellite A135-S2386 Notebook (PSAD6U-01D00D) PC Notebook
Hi , when i turn on my laptop the screen shows up as usaul "toshiba leading innovation" then asks for my password which i put in and press enter.. screen goes black as usual but stays that way and nothing else happens at all, i have tried unplugging it and removeing the battery etc even left it on for a couple of hours hopeing something might reboot but nothing ! help ?
  • Derek Kane
    Derek Kane Sep 05, 2010
    Thanks for the quick reply. The password is entered in a blue box with 8 charachters which is done with numbers in my case. they only thing i have done lately is transfer lots of pics and videos to an external hard drive because the disc was almost full but that was 3 days ago and this seems to have happened yesterday... the other thing i did was change the power mode as in the laptop would turn itself off afetr say 30 mins... i changed the setting so it had to be turned off manually.. would this have caused the problem?
  • Toshiba Master
  • 4,737 Answers
This must be the Bios Password asking you to enter. But did you do anything with it? Sometimes this happens itself when the Bios is bad or the motherboard is old.
If you haven't changed or if you haven't done anything with the bios settings and messed up, then the password should "toshiba" (without quotes and small letters only).
If this doesn't work, you'll have to go a long way to reset the bios password. Will need to disassemble the laptop and remove the bios the battery or to short two small contacts.
First try with the default generic password and let me know if you need further help.
Good luck.
Thanks for using FixYa.
Posted on Sep 05, 2010
  • Lebanon Raingam
    Lebanon Raingam Sep 05, 2010
    I don't think those changes are the cause, but it's indefinite, and I can't make it sure since many laptop used to ask for password without any reason and in most cases, they'd automatically reset or would not ask on the next start up or after unplugging/remove/uninstalling power chord/rams/hard disk respectively. The only last option is to disassemble it and take out the bios battery and again reinstall it after it's left outside for few minutes.
    With old toshiba laptops, it was possible to work with wires on the Parallel port, but it's no longer applicable on newer models.
    There a small bios reset tool called keydisk for toshiba laptops, but honestly, i haven't tried it as I just open apart and work with the motherboard to reset it. If you wanna try, with keydisk (click here to download). I don't have the tutorial on how to use this, but i found this while googling and have saved it on my pc for several years if in case it's badly needed. If I am right, it's installed on a usb drive or flopping drive and boot from the drive. Let me try to find a tutorial or instructions about this tool.
    Good luck.
Toshiba laptop c660d-152 showing black screen asking for password
check whwther you have set password while booting if so enter bios pw
Dec 09, 2012 | Toshiba Satellite L455-S5009 laptop
When I turn the laptop on I see the Toshiba screen for just a second and then it instantly goes to this lovely black screen that says password= How this got there I have know idea. Can anyone help?
Dear beanbean,
This "lovely black screen" is a BIOS password screen. This shows up because somebody has set a boot-up password in the BIOS Setup. If you're lucky, the BIOS Setup is still unprotected, and you can access it as follows:
When you turn it on, look for something that says "Press [button] to enter Setup" or "Press [button] to enter Setup Utilities." Press the corresponding button on your keyboard, and you should enter BIOS Setup.
Now two things can happen. Either you are permitted to access Setup, or you are prompted for the password.
If you can access Setup, navigate to the Security tab and clear all set passwords.If not... then you can either reset BIOS by unplugging the computer, taking off the back, and removing the CMOS Battery (unrecommended), or you can call Toshiba support and ask for the master password (Most manufacturers have a master password, which will allow you to access Setup and remove the boot-up password)
Hope this helps,Ericthecmh
Sep 13, 2011 | Toshiba Satellite A105 Notebook
Remove toshiba password from bios satellite 3000-x4
The Basic Input/Output System (BIOS) password is not set by default on Toshiba laptops. When set, the BIOS password must be entered every time you turn on your Toshiba or wake your system from Standby mode. If you forget the password, you cannot boot your system. Prevent having to enter a password or the results of forgetting the password by removing the BIOS password from your Toshiba laptop. Other types of passwords can be set, such as a Windows password, to prevent unauthorized access to your machine.
1. Turn off your Toshiba laptop.
2. Wait 30 seconds and turn your laptop back on.
3. Press "F2" repeatedly as soon your Toshiba laptop begins booting until the BIOS menu screen appears.
4. Enter your existing BIOS password and press "Enter."
5. Press "F2" again to enter the BIOS, if prompted.
6. Use your arrow keys to select the "Security" tab in the BIOS menu.
7. Use the arrow keys to select "Set User Password."
8. Press either "F5" or "F6," depending on your Toshiba laptop model, to open the Password section.
9. Enter the current password into the "Old Password" prompt and press "Enter."
10. Press "Enter" when the "New Password" prompt appears. Do not enter any text in this box.
11. Press "Enter" again to confirm the new password.
12. Press "F10" to save your changes and exit.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Computers & Internet
Turn on my laptop, screen thatv says Toshiba innovations pops up, cannot bypass by pressing anyb of the f1, f2, f3, ect...... goes to a black screen with a blue box asking for a password, after a few...
Oh be care full here some systems will only allow you a certain trys at entering the password then they will just stop functioning.Try moving on without entering a password at all(blank box etc)'
Good luck
Davey Snake!!!
Jul 20, 2011 | Toshiba Satellite C655-S5068 Notebook
My laptop will not turn on when I press the power button. There is a screen that says toshiba leading innovations with the options of pressing f-2 or f12 for setup or boot selection menus but then the...
AFTER YOU ON THE SYSTEM BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 15, 2011 | Computers & Internet
Toshiba satellite laptop lockout
is it a windows password or poweron password? you must be wondering what are they?
windows password is when you have to enter the password to get into windows and before that you get to see the windows loading screen.
poweron password is hard to crack, it will ask a password on a black screen saying Enter a Password, and the background will be completely black in color.
if its a windows password, press the "Alt+Ctrl+Del" twice, you'll get a screen which will ask you a username and password. in the username and password type in, "Administrator" and password will be blank. hit enter. if it works, then for the rest of the steps, mail me at L2support.hp@gmail.com
Apr 29, 2010 | Toshiba Satellite Pro L300-EZ1501 Notebook
Locked out of Toshiba laptop, Help!
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Some Toshiba bios passwords can be reset using the Key Disk.exe utility, to do this you need a 1.44Mb floppy disk.
Format the disk to be BOOTABLE using Windows and then with a hex editor, change the first five bytes of the second sector to 4B 45 59 00 00.
Then put the floppy into your machine and boot it up, you’ll be asked for a password, just press Enter. Then when you’re asked to set the password, type Y then Enter, this will get you into the bios configuration where you can then type in a new password.
Mar 26, 2009 | Toshiba Satellite A135 Notebook
BIOS PASSWORD
take out the bettery, take out the CMOS battery. unplg the AC
hold down the start buttom for 2 min.
reisntall all power try again.
Jan 29, 2009 | Toshiba Satellite A205-S5823 Notebook
Tecra 8100
I'm not clear on your description, so here goes:
If it showed the Toshiba start screen, then asked for a password, then your hard drive is password protected.
If it showed the Toshiba screen, then asked for password, and you entered it, and then it goes "insert disk", then your hard drive is passworded and wiped.
If the first thing it does is ask for a password, then the password is in the BIOS.
Aug 16, 2008 | Toshiba Tecra 8100 Notebook
Toshiba Satellite A135-S2386 Notebook (PSAD6U-01D00D) PC Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
