Question about Sony Cyber-shot DSC-W170 Digital Camera
Message: 'Turn the power off and on again' appears on screen but when this is done nothing happens except same message again; Camera will not go into photo taking mode - this message just keeps popping up Any help welcome..
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 05, 2010
The lenses were stuck and on the screen it says "lens error".I do not know how it happened. We were just taking photos and when we are about to view them, it vibrated then turned itself off.
This message appears when the lens performs some unexpected operation.If the same message appears after you turn power back on please check that if there is something which blocks the motorized movement of the lens.If so clean it with cotton swabs or soft cloth.After cleaning power off and on again repeatedly two three times.
Jun 04, 2011 | Casio Exilim Zoom EXZ33 Digital Camera
When the camera is switched on the lens goes in and out twice and then the message that appears on the screen is 'turn the power off and on again'
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
May 09, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Message turn power off and on again
your lens may be jamed thats why it tells you to turn off then on its tring to cycle the lens so i would check that first! good luck!
Sep 02, 2009 | Sony Cyber-shot DSC-M2 Digital Camera
Message turn power on and off... Lens stuck as well.
u may as well kill urself. its broken. go get it checked out. i took apart my camera and tried to fix it myself... i shocked the **** out of my hand. best buy or something
May 25, 2009 | Sony Cyber-Shot DSC-P31 Digital Camera
Panasonic dmc fx-10 digital camera -
The lens may be broken(barrel)replacing kost you about 175,00 euro
May 11, 2009 | Panasonic Lumix DMC-FX10 Digital Camera
"turn camera off then on again" message
There could be a short in the battery contacts in your camera. You should inspect them for corrosion or oxidation.
Jul 16, 2008 | Panasonic Lumix DMC-LC80 Digital Camera
Malfunction -turns on and message to return on
the camera has a lens fault and needs to be checked by a panasonic repair technician.
Apr 23, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Error message
my camera did the same thing, lens retracts 3 or 4 times, and then proceeded with an error message "turn off and on again". I pressed the power button probably about 10 times, didn't work, so then i gave it a good smack on the top of the frame a few times while repeatedly pressing the power button and it did the trick. Hasn't gave me problems since...hope it helps
Mar 29, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Bonnie
I was getting the Lens Error message on my A730, even though my lens seemed to be working fine. I'd had the camera in my pocket, and apparently it tried to open but jammed. But it seemed to be OK except for the cursed Lens Error message when I'd power it on. The way I found to fix it is press and hold the "func/OK" button on the back, then turn the camera on. Now it's working again. Note that this may not work for you if your lens is actually screwed up. Mine wasn't.
Dec 12, 2007 | Cameras
Problem with a sony s600
This indicades the lens motor/gearing is damaged or worn. Nothing for you to do except contact Sony Chances are when you see the price of a 'repair' you will opt for a new camera.
Sep 11, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Sony Cyber-shot DSC-W170 Digital Camera Logo
62 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
