Question about LG LDF6810 Built-in Dishwasher
Door won't latch to LG LDF6810ST
The latch broke last night when I shut the door & started the dishwasher. Now the door just falls open. Will not latch. The racks are not the problem. The latch appears to be broken in the "latched" position, because if you turn on the dishwasher, it will start to run with the door open. The machine is less than 6 months old.
I have a call in to service, but can someone tell me how time intensive this might be and how to keep it shut in the meantime? I have two small children (one is a crawler) who now think this is a very fun toy...and it's hazardous! I need help!
Thanks so much!
  • kb62mo Nov 28, 2008
    Is is the top latch, or the mechanism in the door, that is at fault?
  • Anonymous Dec 27, 2008
    I have a 7810ST model that also will not close. We've had it for about 3 years, never had a problem until now. Now that it's full of dishes from Christmas day and leftovers it's decided to go on strike. We've put in all the calls, but noone appears to be open on weekends.
    I appears that the latch just one close, can we reset the mechanism somehow?
    An expert whose answer gotĀ voted for 100 times.
  • 210 Answers
You have to pull out your unit about 3 inches to get to where the latch is screwed in. It is a phillips screw. The part number is 4026DD3001A. In the meantime to keep it closed you are going to have to get creative..
Sgt 48
Posted on Jun 02, 2008
Why does door open too far and is not horizontal to the floor when open?
Besides spring streaches out over time or one rope breaks. Their are like three spots to hook spring to get tension for door. I just replaces both ropes as one broke and hooked springs in middle hole. Takes more time to pull washer out then to replace the ropes
Oct 31, 2015 | LG LDF6810ST Stainless Steel Built-in...
Lg tromm washer
The DE or DOE (Door open error) error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
Aug 22, 2014 | LG 4681EA2001D Original Water Pump Drain...
Asko d3251 randomly stopping during cycle.
The thing that immediately comes to mind is a faulty door switch or latch. The door switch can be replaced and you might be ok. But the latch would be more tricky to check. Sometimes if dishwasher is not level or if the door springs are misalinged the door tends to slip and release the latch due to pressure. It works when you open and shut. But not sure about the night time cycle. That sounds a bit creepy if it starts again by itself. Why not put a tape around the door and then start. That will help eliminate the obvious ones. The other thing that exends dishwasher cycle time is the lack of adequate water temperature. Could be heater or thermostat or both.
You should be able to stroll through the parts by selecting categories on this site.
May 01, 2014 | Asko 24 in. D3250 Built-in Dishwasher
How to replace door springs on lg model LDF6810ST
Found advice from another post for same prob..not tried yet says its not springs but spring cable, part #4933DD 3001B and 2 needed. Poster seem to know what he was talking about
Mar 02, 2013 | LG LDF6810ST Stainless Steel Built-in...
LG LDF6810st dishwasher door spring seems to be broken so door falls open. Can this be fixed easily?
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend
Aug 10, 2011 | LG LDF6810ST Stainless Steel Built-in...
KitchenAid KUDI10FL dishwasher- The door spring system broke and I repaired it, but now all of the sudden the dishwasher will not start. The door may have been dropped a couple of time before the spring...
Hi- It is possible that the door latch is not completely engaging. If the door dropped the hinges may have bent a little thus preventing a good contact with door switch. Try pressing and holding the door shut, hard, and pressing start. If that works then replace the latch assembly. It is also possible the membrane switch got rattled with the door falling, or a wire is grounding out somewhere. Hopefully it is just the latch. Hope this helps, good luck.
Sep 24, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Detergent dispenser will not stay shut so the soap power falls out before washing starts. Last time use I opened the door by mistake part way through the cycle. Could this have messed up the latch...
Opening the door did not affect the latch on the dispenser. The catch does wear out and can be replaced. This involves disassembling the door and a small jigsaw puzzle of springs and levers. If you are attempting I would advise taking pictures to refer to before taking apart.
Jan 11, 2010 | Kenmore Dishwashers
Door won't latchet
Start my using a bubble level to make sure the unit is squarely mounted. Even small amounts of offset or tilt in the unit can eventually cause the latching mechanism to fail to work properly.
Jan 27, 2008 | LG LDF6810ST Stainless Steel Built-in...
LG LDF6810 Built-in Dishwasher Logo
539 people viewed this question
Top LG Dishwashers Experts
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
