Question about Peg Perego John Deere Gator HPX
John deere tractor, think it a 6 volt bought 2005, wont work, is it likely to be battery, charger or vehicle
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Check the battery and the charger and make sure that they are putting out the correct volts
Posted on Jun 08, 2012
  • 60 Answers
SOURCE: old john deere gator and battery new charger still will not move
Could be several things.  Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger.  You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
Posted on Mar 11, 2009
  • 156 Answers
SOURCE: john deer push pull tractor won,t work.
If you have a clicking problem, I would check the wiring on the foot pedal. something is not connected right, which is making the fuse click.
You can contact J&L at this link or call there toll free number. http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html.
They have switches and other parts for these peg perego gators, but I would talk to them to make sure.
Posted on Apr 08, 2009
  • 850 Answers
SOURCE: Peg Perego John Deere tractor 12volt will only
check all wre connections are not dirty or loose!
lift out pedal swith to check there too!
Cheeers Rob
Posted on Aug 17, 2009
  • 156 Answers
SOURCE: Please let me know how I can change the rear tires
My Grandkids go through these wheels every few years.
They love their Gator.
You take the center black cap off and use a socket to remove the attachment on the axle.
Here is the replacement wheels
http://www.shopjandl.com/sarp8115kny.html
They can also help you with the repair, I call them all the time..very friendly people.
hope this helps
Posted on Sep 14, 2009
Testimonial: "Thank you so much for the info. "
SOURCE: Where can I find rubber tires
I was wondering the same thing, can't find any rubber replacements and came up with a solution- use a rubberized undercoating for automobiles. It sprays on thick and provides more grip than the plastic wheels do.
There is more info on modifications here:
http://kidsbatteryrideontoys.com/gearheads-only/
Posted on May 28, 2010
Peg perego john deere tractor charger indicator light does not light up and tractor does not take a charge - brand new
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
Hubby went to charge the gator and the plug part that goes into the wall outlet became very hot to the touch. What could it be? Could it be the charger or the battery?
If the battery is completey drained or very low the charger will get hot to the touch, The charger put out 14.6 volts and then trickle down to 13.8 volts once charged, i would check the charger with a multimeter and check and see what kind of volts its putting out. if the battery is bad the charger wont think that it has completely charged it and will continue to push 14.6 volts into it
Apr 16, 2012 | Peg Perego John Deere Gator HPX Ride on...
I bought a new battery. ran it down and try to charge it but it wont take the charge.
check your charger with a multimeter and make sure that its putting out at least 12 volts
Sep 01, 2011 | Peg Perego John Deere Farm Tractor and...
With new battery john deere toy tractor wont work. Any ideas for an trouble shoot?
check tha battery and charger with a multimeter and make sure they are showing at least 12 volts
Aug 30, 2011 | Peg Perego 12 Volt Rechargeable Battery
I have a john deere tractor that is 6v. The charger says the battery is ready but the tractor is not working.
does the charger indicator light ever turn amber in color? I might be that the batteries cables are loose under the plastic housing, check the battery with a multimeter and make sure that its showing at least 6 volts
Aug 25, 2011 | Peg Perego John Deere Turf Tractor
John deere turf tractor has no power, recharged battery for 24 hours but still zero power. Checked all connections, everything is connected. Tractor is approximately 6 months old
check the battery with a multimeter and see if its showing 12 volts or more, if its not showing any volts the connectors on the battery under the plastic housing have probably come disconnected, you'll then have to pry off one side of the battery and reconnect them, if it is showing volts but not 12 or more then put it on the charger for about 8 hours, then check the battery again if it still hasn't went up check the voltage of the charger with the multimeter and make sure that the charger is putting out 13.8 volts or more, iif it isn't then you need a new charger, if it is then you need a new battery
Apr 26, 2011 | Peg Perego IGOR0040 John Deere Turf...
Peg perego turf tractor not working
check the battery and charger with a multimeter and make sure that they are showing at leaast 12 volts
May 19, 2010 | Peg Perego John Deere Turf Tractor
Peg Perego John Deere Gator HPX Logo
75 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
