Question about Lucent A2011-2 Corded Phone
Just installed an a2011-2 phone everything works but when I dial a number it brings up number then changes to dn= the number and does not dial.
  • 1 more comment
  • Ronald Cilenti Sep 05, 2010
    Connections are fine. Notice two things as you are dialing you do not hear it dial the number
    in your ear and then led screen will still read dn=234-3333 area code in in system. Mute is not on. Have ring tone. When call comes in led reads dn=88
    I would like my problem solved that is what I paid for, not a another pay site. Please are you
    in charge of OBAMA CARE.
  • Ronald Cilenti Sep 06, 2010
    The phone is an a 2011-2 I use line one only.
    New phone. Have checked and recheck settings.
    Can not hear dialing in phone. Number is dialed
    and led screen reads DN= dial number 567-6777
    etc. But number is not dialed. Have set proper
    area code time etc. It has to be some setting I'm missing I would think. Also it does have dial tone when reciever is lifted up.
  • 10,865 Answers
Hello. Definietly return this phone as it has an internal fault which you will not be able to repair. J.
Posted on Sep 11, 2010
  • 944 Answers
Dont worry.
DN means Dialed Number it always shows up.No problem in that check for phone connections are correct.Because when ever you dial you get this DN=the number dialed.
If you have the manual see the connection and set it properly.
Note:Your phone is ok set the connection properly.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 05, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 05, 2010
    Is this is a new phone or old phone?If new phone please refer the manual properly and set the settings in the phone.If it is old phone the headphone soldering is needed.
    Thank you.
    Natarajan Ramasamy Sep 06, 2010
    Yes the setting is the problem...But i couldn't find what settings could be wrong.Normally when you connect
    the phone every phone has dial tone and we could dial the no..But your problem is very strange.Have you tried
    Lucent customer care help.
How to assign a dn number to M7324
press Feature *0 (button inquiry) then press the intercom key.
When a set is installed it automatically gets an intercom #
Mar 19, 2014 | NorStar M7324 Telephone
I am trying to change my display name what does dn mean in the instuction dn+#621
Hold the DN key while pressing # then 6 then 2 then 1 would be my guess.
do yo mean DND - that would be the Do Not Disturb button - not sure what just DN would be
Feb 16, 2010 | Toshiba DKT3020SD Corded Phone
I have a new ds 3111 model, why do I need to dial my own area code do dial other numbers in my area code, even to dial my own number
You need not dial your area code within your code.
You can change the number of digits dialed, in this case seven digits, from the call log.
Press menu/select; Press up/dn to select call log; Then press menu/select; When in call log press up/dn to scroll through the records. All incoming calls are displayed on the screen. Although the call log entries you receive have ten digits, you only need to dial seven digits (within your zone). This is where you change the number of digits you dial within your zone. While reviewing the call log, press # repeatedly to display these dialing options.
Do you have a user guide for the ds 3111? if you do this info is on page 29. If you do not have a user guide you can download one for free at the following link; www.vtechphones.com/docMgt/public/art/309491/ds3111-2_manual_i4.pdf
Let me know if this solves you problem.
FixYa....WIZ.....saailer@att.net
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Dec 05, 2009 | Vtech Cordless 6041 Phone
Trying to change the display name on a DKT
DN just stands for "Directory Number", which is also another name for an extension number. That button should either say EXT______, ot DN______ or Intercom.
So, just push any of those buttons, and dial #621
Nov 03, 2009 | Toshiba DKT3020SD Corded Phone
How to transfer a call on Nortel Networks M3904
Use the Transfer feature to redirect a call to the appropriate person.
To use the Transfer feature to direct a call to a third party:
To return to the original call, if the transfer is incomplete:
1. Press the Transfer soft key. The other
party is on hold and a dial tone sounds.
The LCD indicator light flashes steadily.
2. Dial the DN to which the call is to be
transferred or use Personal Directory,
Redial List
, or Callers List to select a
number to dial.
3. When that number rings or a person
answers, press the Transfer soft key to
connect the calling party.
If the person called is not available,
press the line (DN) key (next to the LCD
indicator) to reconnect to the original
call.
Jun 23, 2009 | Nortel 2002 IP Phone
Need to turn off transfer callback on Norstar Meridian
Ok, well I can explain most of the programming template, but I cannot give you the exact buttons to push since each phone IS programmed differently.
-> first dial FEATURE 985 this will give you the DN(Extn) for the voicemail (record this number) and then RLS
-> now I need you to dial FEATURE 0 on your set, and press the Intercom key to ensure the extension of your set you want to change and then hit RLS.
To get into programming press FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will see 3 arrows on your LCD
<- Heading Enter->
<- Back Next->
-> you will now see TERMINALS&SETS and press Enter (the top right arrow key) now put in the extn that you want to change.
-> you should now see the extension of the set and the name that is associated with it, press Enter (the top right arrow key) again
-> now you will see LINE ACCESS and press Next (the bottom right arrow)
-> then you will see CAPABILITIES and press Enter. now you will see FWD NO ANSWER and press Enter, and put in the DN of the voicemail you saw with the Feature 985
-> hit Next for the number of rings you want to ring at the set before going to voicemail.
-> hit next and you can now RLS to back out of programming.
Voila, that set once called will now goto voicemail.
-OR-
You can get the receptionist to dial FEATURE 9 8 6 and the extension to transfer directly to someone's voicemail.
Apr 13, 2009 | NorStar Meridian M7310 Phone
Attempting to change greeting, m7310 - password trouble
ok then the log in should be something like 1020000...
there is a way to reset the system password...
Ok there are a coupleof steps:
1. feature 985
2. The Call Pilot DN is displayed... now dial 9
3. Pswrd: RESETSMPSWD (73738767793)
4. RESET PSWD? Press YES. Login will be changed to default (1020000)
Mar 20, 2009 | NorStar Meridian M7310 Phone
Change extension number on Nortel T7316E model
Well ~ eagleeigh731 has it mostly correct, do what he said to do and get into the programming --> find SYSTEM PRGRAMMING --> hit next until you find CHANGE DNs--> OLD DNs (this is the old extn#) 222 then type in NEW DN 431--> then hit the end or release button.
Voila your new extension is now there... to check dial FEATURE 0 then press the intercom button, the new extension should be there.
Mar 17, 2009 | Nortel T7316E 2-Line Corded Phone
Re-setting the clock
Most Toshiba phone systems require the Date and Time be changed from port 000 or the receptionist phone. You can verify the port of the Recpt. phone by pressing the DN key and dialing # 402, the display should give you the logical and physical port of the phone you are using. After finding port 000 then press DN and dial # 652 ( for time ) and enter time in a 24 hr format including seconds, HH:MM:SS then press SDS, REDIAL. Good Luck, .....Mitelmike
Aug 21, 2008 | Toshiba DKT2010SD Phone
Lands Phones Logo
113 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
