My Zanussi/electrolux zwf14280w washing machine is malfunctioning and showing error code E2O. What does this mean? Thanks
It means a blockage in the drainage pipes
Posted on Feb 03, 2011
What does error E40 mean
Zanussi Washing Machine E40 Error Fault Code
Electrolux Time Manager How to Fix Error E40
E40 indicates a problem with the door lock circuit in the appliance.
It could be as simple as a faulty door lock or it can be a faulty main control board.
Jul 16, 2017 | Washing Machines
Hi my Electrolux EWF1074 isn't working. The timer is counting down but there is no water in the machine. I tried resetting it but it didn't work. Could someone please help me. Regards Matt.
Rapid reading of alarms:
Press the START/PAUSE button and the nearest option button (4) simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
ewf1074-2rgnvy5j4oifscmshudmmeh4-3-0.jpg After reading error code (look display) will be a lot clearer in which phase of the washing cycle has occurred or is happening malfunction.
New washing machine (electronic) compared to the old models (electromechanical) consume much less water, so it looks that your washing machine is working properly, otherwise it would be stopped. This will be confirmed if the display show E00 which means there is no any malfunction. Any other error code, for exp. E10,E20,E30, E40, E50...... means some malfunction.
Dado
Mar 11, 2017 | Electrolux Washing Machines
Zanussi zwn 6120 l washing machine Error code 5 red 1 green
Your washing machine show the error code E51 what means faulty electronic (triac short circuited). Replace PCB.
A good idea is to check the motor, which in practice can cause this failure (shor circuit motor winding) and sometimes is necessary to replace the electronics and motor and than is question profitability of repair.
Dado
May 07, 2015 | Zanussi Washing Machines
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Error E145
the ecb ( electronic control board ) has detected a malfunction.
check all wiring to the ecb and replace if needed.
also try unplugging the machine for no less than 5 minutes to clear all codes to see if the problem is intermitent or not, hope this helps....
Oct 25, 2009 | Electrolux EW1000i Front Load Washer
RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Dec 11, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
