Question about Philips 190B6CB/27 19" LCD
Hi i have philips 190s monitor and every 15 seconds i have a attention. security flag off how i can turned on?
  • Louis Ebert Sep 15, 2010
    vaicka, please tell me the brand name of the capacitors you find on the power-supply board inside your monitor. 12fixlouie
SOURCE: help with my 190S monitor
First you must remove stand
Beneith there is a five screws
After that pry with small screwdriver plastic all around the display
Posted on Sep 24, 2008
paulbtorrent
  • 34 Answers
SOURCE: Philips 190S monitor - Urgent!
The lcd has three parts the screen plate(windows)/the logic(vga)/the inverter(power plug). Parts that go are the backlight ccfl's, behind the plate, and parts of the inverter, ie capacitors, all three take a bit of power from the inverter. The self test check that all the lights are ok and the inverter is ok, else it switchs off, ie if 3/4 light work it will switch off(my own case), hence the on chech error then off, However sometime there are stages of on/off ie on/ but no screen display, if that is the case the following may be of help...if you put bright light at an angle close to lcd can you see a windows shadow, text icons etc, ie still logic power passing,then .... (from a.n. other) after two weeks searching I finally find doctor living stone http://www.aplusperfect.com/articles/lcd_capacitor_repair more fun with paulbtorrent
the takening the case bit off is like opening your wallet a second time after buying a new LCD, but you must! smallest two screw driver's flatheaded, practice using two pennies stuck together()with your finger after, one little () move and inch and {} again, with the case , it does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip inside!] also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new
one do go burst! you have to laugh really, what next , a new on/off
button, as you work though the whole inverter !
mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not
wellMMMMMMMMMMnnnnnnweek later land sight mmmmmMMMMMMMMMmmmmgggggggg(from
another a.n other)Generally, if the screen went out quickly, it was the inverter. If it went out over a slow period of time (flickering etc..) I would bet it is the lamp.replaceing the lamp should be pretty challenging. as that requires complete breakdown of your LCD, extraction of your dead lamp, and soldering in your new lamp... but I would like to say that I it did this after realizing it's 2 x kitchen strips inside [========] with wires that can connect back to the inverter with out any desoldering(ie kit assembly/dis) with the outter case remove (glass plate safe away) I could reconnect and see that 3/4 were working (i!i hardcard ) cause the inverter to switch off after a secound ! order bult and replace and going
to cheap and see if I can get away with fitting a 15" in my 19' as it a 1/3 of the price ! the market as drop out there, hope the inverter does not miss the length, or the screen out put.
Posted on Feb 08, 2010
I have Philips 19C monitor. From today, every 5 secs an attention message
"osd main controls locked and unlocked"
The AUTO(OK) bottons for 10 sec not give nothink
What i can to do with this?
Gregory
my mail - communar@agry.gov.il
Thanks
Posted on Oct 08, 2008
frcs68
  • 1605 Answers
SOURCE: monitor
sound like the power supply or the monitor bulb is going.
try the monitor on another PC if you can get one, if it works, then you have to find ou the manufature of the video card and get the driver.
Posted on Nov 05, 2008
SOURCE: i have a monitor philips 190S and the osd main
23 Oct 2008 ... There are a few things you can do to solve the problem, ... The menu should be reset and the flashing OSD control message should disappear. ... controls locked, then it comes up again saying OSD main controls unlocked. ... I have a Philips 190S monitor. I do have a button to enter the onscreen menu. ...
filetonic.com/blog/2008/10/23/osd-main-controls-blocked/
Posted on Dec 06, 2009
Attention MONITOR CONTROLS LOCKED
You need to press and hold the "OK" button for 10 seconds, This will clear the control lock..
Jan 09, 2015 | Philips 170s Hns7170t 170s7fb 17" Lcd...
My Philips 170C monitor does not work when I turn on. It only says "attention signal off".
it thinks this is no input signal. make sure your computer is on and the cables are secure, switch your screen with a known good one from a freind. this will rule out your computer. if the pc is fgood maybe go into the bad monitor menu settings and make sure the input mode is correct. if this is not the cause you may need to have it repair, your monitor video or display board maybe bad.
Dec 26, 2009 | Philips 170C4FS 17" LCD Monitor
I have a monitor philips 190S and the osd main control is locked. how i can unlock?
Dec 06, 2009 | Philips 190S7FB 19 inch LCD Monitor
Philips 190s turns itself on/off
Mine is a 190s Monitor and not a TV with any kind of remote unit controlling it. I had this issue about a year ago and it sorted it's self after a week or so left turned off. This makes me wonder if it has to do with heat and humidity affecting the micro switches located behind the push button controls on the removable screen surround.
Dec 01, 2009 | Philips 190S8FS 19 inch LCD Monitor
Theft Mode Enabled on Philips 190s9fb/27 monitor
The display may have been tasted on another pc from the store/company.. This message is activated after a while (or immediately) when connected to a new box. So far I have had this issue on a Philips 22" wide and HP.. both fixed after installing the little software that came with the displays. HP usually has a THEFT option within that installer. The philips one fixed itself upon restart.
Mar 16, 2009 | Philips 190S9FB Monitor
I purchased a Phillips monitor model no 190s when i turn on my computer a box comes up with attention for best results 1280x1024 @ 60, problem is I have already set the display. why is it coming up, how do...
You can get rid of this message by entering the monitor setup by pressing the MENU button. Then use the DOWN arrow button to go to 'setup'. MENU, then DOWN again to 'Resolution Notification'. MENU, then DOWN to choose the 'off' setting. Voila!
Cameron
Sep 03, 2008 | Computers & Internet
Help with my 190S monitor
Gregory
Thanks
Aug 22, 2008 | Computers & Internet
The OSD button has gone faulty.
The button will need to be replaced , or it might just need spraying with a contact cleaner like RP-7 or WD40.
Both solutions will require the removal of the front cover to access the button.
Jun 06, 2008 | Philips 190B6CB/27 19" LCD
Philips 190B6CB/27 19" LCD Logo
704 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
