Question about One For All URC-4330 Remote Control
Volume on remote does not work - One For All URC-4330 Remote Control
Many times this is caused by debris on the carbon pads associated with the specific buttons, in your case the volume buttons, although if this is the cause I suspect other buttons to be in similar condition. The volume is likely used more than the other buttons thus failing first. The control must be disassembled and the specific pads cleaned with a Q tip and isopropyl alcohol and the mating surfaces on the circuit board. If this still does not solve the problem the carbon pads can be resurfaced with a chemical sold at electronic suppliers such as MCM electronics (can be found online using Google).
Posted on Sep 05, 2010
My audio remote control stopped working on only the volume. It works to power the receiver up or off, etc., and the volume control works perfect when operated by hand, but no longer with remote.
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
https://youtu.be/wUpnETSm6_k
Sep 26, 2016 | Universal Televison & Video
Why doesnt the volume on my remote control work?
The wrong code on the remote has been used. Though some codes will work parts of the system only the right code will operate all.
If you don't know the code for the TV, then you will have to try ALL the codes until you find one that operates all the controls.
Aug 09, 2017 | Charter Ltd Ocap-4 C4000 & S4000 4-device...
After switching off and on last night the volume and mute on stopped responding on Humax remote. IT is PVR9150T and remote RT531B. TV Remote works fine with volume. Humax remote works fine on all exce
Note that this type of device is designed to be left on at all times, so should not be switched off each night. I suspect that it has some slight corruption in the user-settings, so a factory reset may be required.
Apr 03, 2014 | Humax Televison & Video
Volume control does not work using the TV's remote, the cable remote or the actual volume control button on the front of the set - the volume that comes out of the TV's speakers is constant - about 33% of...
SO YOU JUST GOT A NEW TV ...BUT...THE VOLUME CONTROL IS NOT WORKING FROM YOUR CABLE BOX.
EASY! BRING UP THE IMAGE OF YOUR REMOTE FOR
YOUR CABLE (MORE THAN LIKELY, IT'S A UNIVERSAL).
CLICK ON THE REMOTE FOR INSTRUCTIONS FOR VOLUME LOCK.
IF IT'S A UNIVERSAL REMOTE, CLICK SETUP (TWO BLINKING LIGHTS) TYPE 993, AND HIT CABLE BUTTON.
VOILA! YOU CAN NOW CONTROL VOLUME FROM YOUR CABLE REMOTE!
Jul 03, 2010 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Im trying to get my sky controls volume to work on my sharp tv but need a code
On the Sky remote Press the Following.
TV,
RED + SELECT (blinks twice)
TV,
0093
try the VOLUME if this does not work. Press TV then VOLUME again repeat until Volume works.
Once the volume works press SELECT on the remote to store.
Hope this helps
Little Dish Fitter
Aug 26, 2009 | Sharp Televison & Video
Volume controls do not work on remote, batteries have been chang
is that from remote no volume try tv volume if ok
your remote volume buttons are wornout push
button harder ??ok no i can fix remotes
need help call 0403960527
Feb 16, 2009 | Samsung TV Remote Control
Directv AV1 switch Volume Problem
Did you try all the codes listed. Some work certain functions such as power but not volume. Did the installer leave a phone number where he could be reached other than directv toll free number? Did you receive the same remote as the original. Directv has two remote that are identical in appearance but one is rf capable and the other is infared. The RF remote has backlit keys and is compatible with just about any device.
Aug 03, 2008 | Universal Remote Control DIRECTV Universal...
Comcast remote
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jul 05, 2008 | Yamaha RX-V1400 Receiver
Volume controls dont work when using remote
I would start by trying other codes on the universal remote. Sometimes codes will only work part of the remote such as the numbers or channels but not volume. Your motorola cable remote sounds like it may only need a good cleaning. sometimes when you take remotes apart it will look like somthing got spilt in it. I would start there first.
Mar 17, 2008 | Sanyo DS27910 27" TV
Volume not working on remote
Just get a universal remote like i did but i also had another technics remote from another unit.
Feb 23, 2007 | Technics SA-AX730 Receiver
One For All URC-4330 Remote Control Logo
99 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
