Question about iRiver X20 MP3 Player
X20 dust under the screen is spoiling the picture
    Problem Solver:
  • 5 Answers
If you open up the battery cover, you should see 6 tiny philips screws to undo, as well as two on the side of the player, opposite the headphone jack, underneath two little gray cover discs. Don't worry about opening up the player, it stays in relatively one piece besides the screws and the case. Once you undo the screws, you should be able to carefully pry open the case down the sides of the player, opening it up will expose you to the backside of the screen cover, as well as the screen itself. Just wipe it all down, and when you're satisfied, pop the cover back together, and throw those screws right back in! Pretty easy! I did have your same problem. This is what I know to do about it.
Posted on Jun 01, 2008
When capturing picture in open-air at time of night.... my dmc f3 cam shows spots in picture spots if dust particles present in the air which spoil the look of picture :( plz help
If these are flash pictures, you are experiencing dust particles in the air reflecting the flash back into the camera lens. This is a problem with point and shoot cameras because the flash is so close to the lens.
Mar 13, 2011 | Panasonic Lumix DMC F3 Digital Camera
Have a JVC HD-Z886 61inch, there appears to be some black spots behind the screen. Looks like dust, most at top of screen, not a big problem. Is there any way to clean behind the screen? When new the TV...
  • The most severe problem dust can cause in an LCD TV is a short circuit. This occurs when dust enters the television's casing and settles on one or more of the internal circuit boards. Enough dust can cause a short circuit, which will prevent the TV from working at all. In other cases, it will damage picture quality or prevent certain features from working properly.
    Because a short circuit can only occur when enough dust is present inside the TV, this problem happens after the TV has been in use for a number of years, meaning that it will not be covered under the manufacturer's warranty. In many cases of short circuits, repair is expensive, and you are better off buying a new set.
  • Image Quality
  • Dust can also have an effect on an LCD TV's picture quality without entering the LCD's casing. Dust that settles on the surface can distort the picture and decrease its brightness. While it's easy to wipe the dust away, use only a soft cloth and mild cleaning solution to avoid scratching the screen or causing permanent damage with caustic cleansers.
    Dust under the screen can be more difficult to clean. Using compressed air to blow the dust out is the best option, short of disassembling the set to clean the screen from the inside. Keeping the surface of the screen free of dust is usually sufficient to prevent dust from getting under the screen.
  • Control Problems
  • Another effect dust can have on a an LCD TV occurs when it enters the space around buttons, making it difficult to control the television. On certain sets, dust will cause buttons to stick or prevent them from engaging when pressed. Using compressed air to blow the dust out, or resorting to using only the remote control, will solve this problem.
  • Jan 24, 2011 | Televison & Video
    Viewfinder screen is black when trying to take a picture
    The black screen problem means the lens sensor is spoiled due to over exposure to heat. Its better to give it to Kodak service centre. If your camera is under warranty period its well and good they will replace the lens sensor for free of cost.
    Thank you
    Aug 06, 2010 | Kodak Easyshare CD82 Digital Camera
    Screen black, but with all menu options visible. Black screen after taking a picture
    The black screen problem means the lens sensor is spoiled due to over exposure to heat. Its better to give it to Nikon service center. If your camera is under warranty period its well and good they will replace the lens sensor for free of cost.
    Thank you
    Jul 20, 2010 | Nikon Coolpix 5700 Digital Camera
    When i turn my camera on to take a picture the
    The black screen problem means the lens sensor is spoiled due to over exposure to heat. Its better to give it to Sony service center. If your camera is under warranty period its well and good they will replace the lens sensor for free of cost.
    Thank you
    Jul 19, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
    Iriver mp3 player
    Same problem on a 2GB x20 I just bought. Easy to get things into the device, but nothing recognized as playlist either using iriver plus3 or Media Player.
    Feb 05, 2008 | iRiver X20 MP3 Player
    Konica minolta dimage x20 cmaera
    This sounds like a defective Sony CCD issue. If so, Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so get going! See this link:
    http://camerarepair.blogspot.com/2007/11/sony-konica-minolta-cameras.html
    The Dimage models that Sony is accepting for the recall repair are:
    Dimage 7HI, 7I, A1, Xi, F300, XT, X20, S414.
    Dec 29, 2007 | Konica Minolta DiMAGE X20 Digital Camera
    Minolta Dimage X20
    Check out the manual it needs a little setting up I guess. There should be a more comprehensive manual on the CD in PDF format.
    Sep 22, 2007 | Konica Minolta DiMAGE X20 Digital Camera
    DIMAGE X20 Digital Camera
    http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131#
    May 01, 2007 | Konica Minolta DiMAGE X20 Digital Camera
    iRiver X20 MP3 Player Logo
    Top iRiver Audio Players & Recorders Experts
    Steven Wander
    Steven Wander
    Mohamed Ismail
    Mohamed Ismail
    Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
