Question about Electrolux Washing Machines
Hi, I have an Electrolux Eco Valve 7kg front loader washing machine which I bought 6 months ago and has been working fine, just recently it has stopped working. We select the spin cycle and press the start button, the water fills up and the washing machine starts to spin (2or3 revolutions) then stops, the washing machine still goes through the different stages of cleaning and the timer still counts down buts stops at the rinse cycle till timer finishes at 00. We have no error message on the display, I have cleaned the water inlet filter, drained the emergency pump and cleaned the drain pump, I have also switched off the washing machine for half an hour to see if that resets everything and still the same problem. Is there anything else I can do pls Help.
  • Electrolux Master
  • 909 Answers
Im taking it that you have a squirrel cage motor.(motor without bruhes) Locate the capacitor and replace it. Most of the time its the capacitor that has malfunctioned and that will stop the spin cycle. If you have a soft start.(an electronic control), then check the brushes. Possibly need someone to help as the motor will need to be removed to gain access to the brushes. Check length. must be at least 25 mm.(otherwise not enough tension). Make sure power is pulled out when doing this repair.
Posted on Sep 05, 2010
Constant beeping
Check to see if the electrical outlet is grounded. There is a little three pronged tester for that.
Nov 26, 2013 | Electrolux Washing Machines
Electrolux Eco Valve EWF1087 washing machine,will not programme?Won't accept Quick wash cycle, then stops halfway through
8 November, Today I picked this model off the footpath, yet to set it up I hope it works LeonZ -Reservoir, Vic.
Nov 05, 2011 | Electrolux EW1000i Front Load Washer
Heater wiring diagram 7kg front loader electrolux
IN MY IFB WASHING MACHINE SENATOR TWO WHITE CABLES CAME OUT I DONT KNOW WHEATHER TO JOIN THEM AND FIX TO HEATER
WHAT IS THIS WHITE CABLE. AT CONNECTING POINT THEIR INSULATION ALSO GOT BURNED THAT IS WHY THEY CAME OUT
Jun 01, 2011 | Electrolux Washing Machines
Hi! My 7kg Samsung J843 Front Loader Washing Machine is not spinning at all. Makes a whirring sound but no movement. Any tips?
Hi, I've had this problem before. It was a while ago but it was either a broken belt or the belt had slipped from the correct position and needed to be put back on. It was under warranty and a service tech fixed it.
May 08, 2011 | Samsung WF337AA Front Load Washer
Drum wobbles front and back so on spin it goes out of control and shakes up and down electolux eco valve 6.5 kg front loader
Hi
Washing machines usualy have springs on the front and back which can sometimes snap or come loose. you can usualy see these by looking at it from beneath.
Also they have a ballast which is usualy a small piece of concrete attached to the bottom of the drum. This is to stop it from bouncing around as well. these also have a tendancy to either snap their fixings (Bolts) or split and fall off.
In either sutuation it should be fairly easy to repair. I have had both of these situations on a BEKO. got the parts from the NET.
Hope this helps.
Jun 06, 2009 | Electrolux EW1000i Front Load Washer
I have a mastermind 708 7kg front loader and SE is flashing and maching won't work can you help please
Ihave a mastermind 708 7kg front loader and the SE is flashing and machine wont work can you help please? Thankyou
Aug 03, 2008 | Washing Machines
Washing Machines Logo
424 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
