Copy count How do i get the copy count/ meter reading on a konica 7022
  • olekat12 Feb 10, 2009
    Does someone have instructions on how to obtain meter reads from Xerox printers/copiers?
    Problem Solver:
  • 7 Answers
You should be able to get the meter reading on a 7022 by pressing the star key (*) on the numeric keypad.
Hope this Helps
Posted on May 21, 2008
How do i get an event log on bizhub250?
No such item. must use the meter count meter. if so some one use the machine. did you use the had count meter or the one on the screen hard count is inside toner cover
Mar 07, 2016 | Konica Minolta bizhub 250 All-In-One Laser...
I have a konica 7020 machine, the first copy comes with horizontal black lines but not the others (when copying e.g more than one copy)
1 look to the drum surface for scratch if their is replaced it. 2 the write unit might already defective. Damage drum will cause sparks to charging unit and Horizontal lines produce.
Dec 02, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Error code F 26-3 on Konica 7022
Sir/mam, you might have a bad drum density sensor or it was not cleaned or was destroyed by static electricity, if a vacuum cleaner was use to remove the old developer, NEVER use a vacuum cleaner for that procedure. Remove the drum and will see a small sensor near where the cleaning blade sits need to clean it replace it. Worse case the main control board is bad that what sensor talks to .Was the L Detect procedure run after the developer was replaced, and before you replaced the developer did you clear the developer counter, to let machine know it has new developer, because clearing the counter is the only way the copier has new developer, did you clear the counter for the new drum? The machine use the counters to determine voltages for certain assemblies. If L detect was not run and copies or prints where made get new developer and start over.
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7022 26-3
Yes I stated what I recommended to do in your last post!
Copy of konica 7135 is unclear while running. at first is copy is clear, later the copy is not clear... blurred
try to make some copies from your pc if the results is ok that simply means something with your scanner unit, for exaple the pnnel needs to be lubricated and the ccd unit needs to be cleaned.
Mar 20, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
How to get meter read for konica magicolor2490
Push the Display button
This will show the toner levels.
Push the down arrow to toggle through the copy counts (B/W & colour, copies, faxes, scans etc).
If you are looking for the instructions in a PDF manual search for "counter" instead of "meter".
Jan 10, 2014 | Konica Minolta magicolor 2490MF Laser...
I have a Konica Minolta 7022 printer, scanner, fax, and copier machine. How do I get it to scan?
Please see this website complete manual for Konica MInolta 7022 printer I think i can help your problem
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Thanks
May 10, 2011 | Konica Minolta Office Equipment & Supplies
Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Mar 21, 2009 | Toshiba 2060 Copier
858 people viewed this question
jasbo
jasbo
