Question about Winco 5500 Watt TriFuel Power System w/ Electric Start Honda - PSS6H
A friend living in the country bought a Ryobi RG-950 generator. She wants to run 1 of her 2 computers or a TV 1 light at night and asked my advice. I told her that running any electronic equipment off a generator could be problematic but without seeing the specifications, as to whether it has an AVR or a pure sign wave output I couldn't say. I searched the internet and the main Ryobi website for specifications but found nothing. The Ryobi site returns nothing for "generators"!!! In the interim I advised her to only use the TV and computer with a UPS (if it will work with the generator supply) Can you comment and/or point me to the specifications, user manual or data sheet for this generator please? Much appreciated & sorry this was a long story! Mike Cape Town South Africa
  • Mike Berryman Dec 04, 2011
    Hi thanks for your answer. Also interesting. However could you clarify the following extract as I don't quite follow what you are saying here:
    "A little advice on any ryobi, even a 4 stroke motor, use sthill two stroke only, do a 1:100 mix on a 4 stroke"
    I know my friend has had starting problems which seem to be related to the oil-fule mixture and has to have something cleaned by a mechanic from time to time to get it to start. Sounds temperamental to me.
It's best to run all electronics through a UPS and surge protector. Small generators like the RG-950 are really for small power tools and lighting. The Ryobi RG-950 is only rated 650 watts which really means about 450 watts (70%) for continuous use. In general, a basic desktop or a laptop should be OK. A TV up to 25 inches and a 100w lamp, should be OK. If you try doing both at the same time, expect smoke followed by lights out. A UPS and Surge Protector are a must on small generators due to their poor voltage and frequency regulation. The UPS should be a good quality one that deals with Brownout, Overvoltage, and frequency deviation. ALWAYS USE A SURGE PROTECTOR!
Posted on Oct 25, 2010
    New Friend:
    Problem Solver:
Hi, While browsing the net for a answer to my Ryobi 950 Generator problem i came across this site, hope you can help.
I tried running my Ice making machine (400 watt on specs tag) of this 950 generator....it runs the water pump BUT as soon as the freezing cycle kicks in the generator increases in revs which is quite normal...but then the ice machine "kicks out" ...stops the freezing cycle. I don't understand as the gen is suppose to effectively supply 650 watt and the ice machine is marked well below that.
Any explination?
Posted on Dec 27, 2014
Hi there.
We live on a farm without power. We use ryobi generators bought from game, warranty is excellent with game. We've had 5 so far, 2 currently broken, they last about 3 months with continual use (7 till 11 every day).
We run our pc's, tv, hi fi, lights and washing machine off a RG-950, alternately as to not go over the max wattage. We haven't had anything blow up or break due to it, 2 years now... The problem with a ups is the power it requires to charge, so make sure its fully charged if it has a battery fitted. A little advice on any ryobi, even a 4 stroke motor, use sthill two stroke only, do a 1:100 mix on a 4 stroke, we squeeze 5 months out of a 950 doing that.
Posted on Dec 03, 2011
How strong is the spark at the plug on a Ryobi CG 950 generator? I do have spark but it seems to be very weak and the generator does not start.
When in doubt, clean or replace the plug first. Then, if I get spark of any kind, I'll call it good for now and verify three other things. 1) pull the spark plug, ground the plug wire and turn the engine over to verify compression. Put your thumb over the hole and you'll feel it. 2) fuel - is it fresh and clean? not more than 6 months old with no water, and a clean filter. 3) Be sure you have clean and unrestricted air filter and passageways. If it all looks good, start looking at electrical wiring back to the magneto (things that might drain current to the plug). Keep in mind that a slight nick in a flywheel key can affect timing enough to keep a small engine from running.
Jun 21, 2018 | Ryobi Garden
Ryobi Generator RG-2700A MANUAL DOWNLOAD
hi Gerrie.
this is all i could find.see if this link helps you out.
Ryobi Generator RG 2700 MANUAL DOWNLOAD Google Search
Nov 19, 2017 | Ryobi Garden
Hi, While browsing the net for a answer to my Ryobi 950 Generator problem i came across this site, hope you can help. I tried running my Ice making machine (400 watt on specs tag) of this 950...
A compressor (which the ice machine uses), draws a considerably large amount of power upon start-up. Many generators cannot handle these transient loads effectively, as their regulators are not designed for those kinds of loads.
Dec 28, 2014 | Refrigerators
Power loss
950 watt is very small. Most electrical appliances need 1000watt to operate so if the vacuum cleaner is 1000watt then the gen set will trip. Check the drill as it is possibly 850watt which the gen set can handle. It all has to do with the wattage of the equipment you intend to run from the gen set
May 09, 2013 | Winco 5500 Watt TriFuel Power System w/...
What type of oil to use in RYOBI RG-6900K
Good day
Can you tell me what kind the oil using the generator
ryobi rg7900k.
Thanks
Oct 23, 2012 | Electrical Supplies
I have a Ryobi RG6900 Generator,how do i connect it from the generator to the distribution board.
I use a COBRA. It is a lead with a plug at either end. Plug one end into the generator (output) and the other into any household plug outlet. (Set to the ON position)
Before doing so ensure that no outside power can enter through your DB board (switch the Mains Switch to the "off" position) Also switch off (at the DB board) any circuits that may cause a demand of more than 21 Amps (Stove, Geyser, Swimming Pool Pump etc)
Start the 6900 and wha-la you have power to all circuits not switched off at the DB Board.
I typically leave the light circuits, one of the plug circuits (to run the TV, Decoder etc) Security Circuit,and Garage Door opener switched on.
When mains power returns First stop & disconnect the 6900, remove the COBRA and then switch on the Mains and other circuits.
Dec 29, 2011 | Motorcycles
I just puechased a ryobi rg 6900 generator and it does not hahe a battery or operators manual. I need to know how to operate it and what size battery to buy
The RG-6900 Ryobi generator does not have (or need) a battery. It is a manual type with cord start. Voltages and specifications may differ slightly depending on which country the unit is intended for (110V vs 220V). The same applies to warranty and servicing agents.
Send your email address to eggie-at-scheffler-dot-co-dot-za and I will mail you the manual in pdf format (820kb). Substitute "at" and "dot" with the usual symbols to mail me.
i just puechased a ryobi rg 6900 generator and it does not hahe a battery or operators manual. I need to know how to operate it and what size battery to buy
Feb 27, 2011 | Garden
Winco 5500 Watt TriFuel Power System w/ Electric Start Honda - PSS6H Logo
2,017 people viewed this question
Top Winco Electrical Supplies Experts
John Trevino
Tom Chichester
Dave Glabb
Are you a Winco Electrical Supply Expert? Answer questions, earn points and help others
