Question about HP Pavilion Slimline S3123W Desktop PC - REFURBISHED
Sound system My problem is I have no sound and speakers are working fine and the manger device states that everything is working fine but I still can not get my sound to come on. Mute button is not on sound is at 100 percent and still no sound. Can I please get some help.
  • Anonymous Jan 21, 2009
    i have the hp pavilion slimeline s3123w and i install the windows xp after that i didnt have no sound. what can i do to get back sound on my computer
Try re-installing the audio drivers. i had that problem with my computer, all i did was search for Realtek AC97' sound drivers and sound was restored. if not, try SoundMax Digital Audio Drivers.
Posted on Nov 23, 2008
Why has my windows vista home premium system suddenly stopped the sound coming through when I want to play music from napster site through my pc? I have the pc connected to 2 speakerS.
this could be an issue with driver or service failure in the computer..
try restarting the computer in safe mode .. and see if the internal speakers work.. try running a driver update through device manger.. check the cables of course.
if that does not help .. then call 1-877-805-1027 for expert help
Jul 23, 2015 | Microsoft Windows Vista Home Premium...
Altec lansing imt620 no sound, everything else works fine (speakers are ok)
Pardon my question; but what do you mean everything works fine? Have you attempted to attach the speaker system to an other device, such as a Receiver, DVD player, TV, etc? First check and see if the System works on other electronics and if it is working, then you go back to your computer and start from there; and I assume "everything works fine" could be the computer. The Altec is one of the best systems out there and their quality superior. It is rare to get a new Altec in a defective state as they do a great job on quality control.
Dec 19, 2013 | Altec Lansing 4.1 140 WATTS SPEAKER SYSTEM...
Sound are not working
1: check the speaker wire. it should connect to a green port at the back of the computer.
2. In control panel open realtek audio device manager. it will tell you where its connected
3. If its a monitor speaker then do a factory reset for the monitor.
4. try to configure the speaker from audio device manager on the system tray volume icon
still doesnt work then uninstall the driver for sound card from device manger
restart the computer
still no then do a system recovery
Apr 01, 2011 | HP Computers & Internet
My speaker wont work when i play anytin on internet wit sound i dnt hear a sound from my speakers
3. try to configure the speaker from audio device manager on the system tray volume icon
Apr 01, 2011 | Computers & Internet
I have the Pulse 424 speakers and they are like 8 years old. The speaker with the power and volume knob is out. It works to turn on speakers and control volume but no sound. The woofer and the other...
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 31, 2011 | Labtec Pulse 424 Computer Speakers
My spekaer doesnt work.......it is properly connected to the cpu .............speaker problem or OS problem?
check to make sure you are getting power to the speaker system and that the audio jack is plugged into the green jack on your sound card. also open up volume control and make sure its not muted and that it recognizes it. when u turn the volume up if you dont see any green movement on the bar then you have a sound driver issue. go to device manger in xp right click on my computer properties then device manager and see if there is a red or yellow mark on your sound card on vista and win 7 go to my computer then system prop, then device manager.
Mar 14, 2011 | Creative Labs SBS 370 Computer Speakers
Hi, I re formated my computer and now my phillps sound system will not work? system says the sound card is busy but there is nothing esle running, pleaxsse help
Which operating system are you using?
Have you checked the device manager, what sign does Audio Device has on it?
Start->Run->devmgmt.msc (to open the Device Manger)
Feb 13, 2011 | Philips Audio Players & Recorders
No sound from Acer Aspire One AOA150
go to Start -> Settings -> Control Panel -> System -> Hardware -> Device Manger. Look in here and see if the audio device has a red X on it. If so, uninstall the driver and install the latest driver from the manufacturers website.
Or, try Function and one of the numbered buttons with a blue speaker icon over it. You may just have the volume low or off.
Jun 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
HP Pavilion Slimline S3123W Desktop PC - REFURBISHED Logo
194 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
