Question about Philips Avent® Scd510 Dect Baby Monitor
Battery in parents monitor won't hold a battery charge. worked for 18 months now just beeps constantly or just turns off.
We had the same exact problem, tried replacing the rechargeable batteries but to no effect. We called Phillips directly and they were very nice and are shipping us a replacement unit (they discontinued this model and I suspect this is a known issue).
Posted on Nov 17, 2010
I request information about angel care AC401 We have build this product but we are not able to work it. When we turn on the unit parent the digital screen shown "--" and the nursery unit icon...
turn both the nursery and parent units off.
turn on the parent unit.
hold menu for 5 secs until it beeps.
turn on the nursery unit.
press and hold the little round blue light at the top for about 5 second until it beeps.
the parent unit waits for the signal then pairs.
Nov 08, 2010 | Angelcare Baby Movement and Sound Monitor...
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
My brand new summer infant slim and secure baby monitor parent unit will not hold a charge. It only works when plugged in. Customer support sent a replacement battery but the same thing happens. Does...
Keeping the LED monitor portion on the entire time sucks the battery pretty quickly on mine. It has an automatic shut off button but if you're like me, you probably check it constantly. I found that when I'm not turning on the LED portion and also turning it off when he's awake and with me, it keeps the charge MUCH better.
Aug 03, 2010 | Summer Infant Slim Secure Handheld Video...
Red light and beeping as if its not charged but green charge light turns on when i charge it. no sound from babys room
I just fixed my unit that had this same problem. You have to re-pair the two units... Turn the parent unit off. Hold the "volume down" button while you turn the parent unit back on. The unit should beep and flash all volume lights. Release the volume button and the press again for ~2 seconds. The volume lights will light up and stay on. Next, turn the nursery unit off and then back on. This should re-pair the two. I hope it fixes your problem!
Aug 03, 2010 | Graco Digital Deluxe Imonitor Baby Monitor
Both units are switched on but the parents' unit doesn't want to connect with the nursery unit. I clearly see the nursery unit's green light that flashed to detect movement and don't understand why my...
I have the same problem. I'm guessing mine is broken and will need to be replaced. However i did read a possible solution on a site with slightly different instructions to the ones in the box that describes how to pair the two devices together.
if the nursery unit just waits 20 seconds then beep beep beeps and turns off i guess yours is broken too. I think its probably the nursery unit has stopped transmitting.
they will replace or repair a unit that less than 12 months from date of purchase with a supporting receipt.
the help line is 0845 009 1789 mon-fri 11-3pm
May 20, 2010 | Angelcare Baby Movement and Sound Monitor...
Hand held monitor not working
Sounds like the units need to be paired. Start with all units off. Then turn on one of the parent units. Press and hold the menu button until it beeps. Quickly turn on the nursery unit and press and hold the button on the nursery unit that has the parent unit icon below it. After a couple of seconds the units will pair. Repeat this process with the other parent unit.
Dec 12, 2009 | Angelcare Baby Care
Base unit appears to be working, but neither of the charged handsets will work. Both are showing red and beeping, but will occasionally go green for a second before going back to red and beeping.
The units aren't paired. Call Graco at 800-345-4109 to have them walk you through pairing it. I'll try to explain what they just walked me through:
-Turn off all units. Make sure nursery and 1st parent unit is plugged directly into wall.
-Hold negative volume down on 1st parent unit. Keep holding it down.
-Press on button on 1st parent unit and let go.
-When you hear a beep, let go of negative volume button on 1st parent unit and then press it again.
-When you hear the second beep, let go of the negative volume button.
-If you have done it correctly, the 1st parent unit should have one red light at the bottom and the rest of the lights should be green.
-Turn on nursery unit and the 1st parent unit should pair with it.
-Repeat the above with the 2nd parent unit.
Nov 18, 2009 | Graco Imonitor Digital Baby Monitor
The parent unit does not recognize that the nursery unit is on. all the correct lights are displayed on the nursery unit for normal function, but the parent unit display indicates that the nursery unit is...
Oct 10, 2009 | Bebesounds Ac401 2p Angelcare Deluxe...
My parent unit is not working. All it does is flash when it's supposed to show me the pendulum swinging, room temp etc. I have forgotten how to reset it. Help please
Manuals here: http://www.angelcare-monitor.com/Canada/en/help#tabs-2
Had same problem - here's what worked for AC401 (from manual):
CONNECTING THE PARENTS UNIT TO THE NURSERY UNIT: If you lose the connection between the 2 units,turn them both off. Turn ON the parents unit and press and hold the MENU button ,the "out of range"indicator will flash and you will hear a beep.Turn ON the nursery unit and press and hold the top button of the nursery unit to reconnect. The Tic light flashes.This normally happens within a few seconds and you will hear a bleep to confirm it. If successful, the parents unit display will first show the channel of transmission (C1 to C8), which will be replaced by the room temperature and icons for all activated functions.
Oct 02, 2009 | Angelcare Deluxe Movement Sensor & Sound...
The base unit is turning on and operating, but the parent's unit all of a sudden just won't connect. I know the base unit is working because it is still detecting movement and the alarm goes off when...
Try the manuals: http://www.angelcare-monitor.com/Canada/en/help#tabs-2
The picture showing looks like the AC201 which has a hard switch for the channel selection, but you describe a menu screen which sounds like the AC401 or similar. If it is the AC201 - ensure both units are on the same channel. If it is the AC401 or other unit where there is an LCD, then try the following:
Sep 19, 2009 | Angelcare 2009 Movement Sensor Baby...
Philips Avent® Scd510 Dect Baby Monitor Logo
1,352 people viewed this question
Top Philips Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Philips Baby Gear Expert? Answer questions, earn points and help others
