Question about Linksys EtherFast 10/100 5-Port Auto Sensing Switch [ EZXS55W ] (104835)
I have 2 computers (Vista and XP). I am using Linksys 10/100 hub. The problem is I can not use the internet both computers at the same time. I can only use one computer at time. Please help me. Thank you.
    President:
  • 1,851 Answers
There are 2 options; either both the computers are trying to use the same local ip addresor your linksys is narrowed down to assign just on ip address. The 1st case is more possible. So follow this procedure.
First of all let's check the ip address that each computer use. With one of the computer in power off state in order to be the other one connected, go at start and click on run of the working and connected computer. At the white line type "cmd" without the quotes and hit enter. At the new black window type "ip config" without the quotes and hit enter. The system will reply with the ip adresses for the local machine connection at the fist line (indicated as IP adress) and the ip addresses for subnet mask (at the second line) and for the gateway (at the third line). Write down on a paper these numbers. Shut down the computer. Start the other one. After finished and connected do the same as before. Write down the new results. The first line for the ip address that each computer uses in order to connect at the network is the same, that's why both of the computers can not connect at the same time. Let's fix the problem.
Go to start - settings - control panel - network connections - local connection. At the new window you will see some kind of protocols for network connections. Near the top down at the list is "Internet Protocol TCP/IP". Click on it (not at the box with the check-mark in front of it, just on it). Click on the "properties" button (just bellow). The upcoming screen will show in ip address format details for the connection. At each one of the 2 sets it's an auto setting and a manual one. I suggest that your systems are now in the manual mode. Write down the 5 numbers of this screen (we will need these in case of bad luck) and change the settings to auto (both of them). Click OK, close all the windows and restart the system. Now one of the computers uses auto settings and the case of conflict is minimized. My suggestion is to do the same procedure at the the other computer too in order to get both the computers auto ip settings.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Sep 05, 2010
    President:
  • 2,571 Answers
Then both computers are trying to use the same IP address.
Have you tryed to plug both computers in and rebooting the modem and the router, this should force it to assign new IP addresses and both should work.
2 Suggested Answers
samuelseno
  • 103 Answers
SOURCE: Linksys NH1005 V2.2 Ethernet 10/100
Hello!
I will just illustrate on how to configure or to set the correct IP addressing;
Assuming that we will manually put IP address on each computer:
PC1:
IP Address: 192.168.1.13
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1
Preffered DNS server: 192.168.1.1
***note that 192.168.1.1 is the IP Address that your ISP gives to you, so on the other computer (see below)
PC2:
IP Address: 192.168.1.18
Hope I was able to help.
Posted on Oct 09, 2010
I cant get my home computer and lap top to both go on line at the same time
A "hub" just "splits" the Internet connection.
Each computer connected to the hub gets an IP-address from your ISP (Internet Service Provider).
However, some ISPs only allow each customer to use _one_ IP-address.
Ask your ISP for the capability to obtain a second IP-address.
Mar 18, 2011 | Linksys (NH1005) 5x10/100 Mbps Networking...
How do you connect a Linksys NH1005 v2 hub and whats the difference between a hub and a router?
A router takes an Internet connection, routes it to several other computers and provides each of these computers with their own IP address.
A Hub, on the other hand, will split the Internet, but the various ports on the hub will all have a single IP address. Makes it hard to use a computer for much of anything, if it is the second computer, you'll have trouble getting access.
Nov 13, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
Cannot connect both XP computer and Vista to Internet
A lot of cable modems will store the MAC address of the first device connected to them and will only talk to this particular device/MAC address. If this is the case, you will need to power down the modem and the router for some period of time. If you also get phone service through your cable company then there may even be an internal battery backup that you have to exhaust. Unplug it and wait at least one minute after all lights are off and then turn it on first followed by the router. The router should then register its MAC address with the modem and then all will be good.
If your modem or some other equipment owned by the cable company permanently stores the MAC address then you will need to one of two things. The easiest is to call the cable company's tech support and ask them to change the MAC address for your account to match your router. The seoond option is to configure the router to clone the MAC address of your XP box. Here is a link to a thread on linksys' web site with step by step directions:
http://forums.linksys.com/linksys/board/message?board.id=Wireless_Routers&message.id=108261
Note: If you want to implement security, do not use WEP as indicated in these directions, use WPA. WEP is hardly better than no security.
Jul 14, 2009 | Linksys WRT54G2 Wireless Router
I just need to connect 2 PCs via the Linksys 8-port switch, no internet connection. One is running XP & the other is running Vista. Both plugged into the numbered ports but I can't get the PCs to see...
If you are not connected to the Internet and both PC's are trusted and you want to network them. The easiest solution would be to disable the firewall on both machines since there's no need to block anything. You may also need to enable file sharing on the Vista machine under networking.If this is going to be a permanent setup and you don't plan on adding any other devices I would exchange the Switch w/ a crossover cable connected into each other to save on electricity.
Jun 14, 2009 | Linksys 8-Port (SD208) 8x10/100 Mbps...
Slow internet.
Your hub can support more that fiber optic puts out. Problem might be a slow computer. Run a internet speed test see what it gets through hub and then straight to the computer bypassing the hub. If possible. If there is a big difference either way what ever is slower is most likley the issue.
Feb 22, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
Switching from Linksys 5 port switch to Netgear 8 Port Gigabit
Kindly check the Gateway used in the computer where internet is working.....
to find gateway follow this
start menu >>> RUN>> CMD>>>> Ipconfig
then configure this gateway in all other systems and ask for DNS from you isp as well..to provide DNS manulay.
If still dont work ...
tell me the all information you get by useing ipconfig command in the PC where internet is working.
like IP address
Gateway
DNS
i will make you a map to follow.
best regards,
Dec 02, 2008 | NetGear ProSafe GS108 8-Port Gigabit...
Local access only
hmmm... with those settings, the Vista machine SHOULD be working...
when you open internet explorer on the vista machine, can you go to tools, internet options, and then the connections tab?
along the bottom there should be an option for lan settings. click on that, and then make certain that 'automatically detect settings' is checked, and that everything else is blank.
then restart internet explorer.
what sort of error message do you get now, if you try to go to, say, www.cnn.com?
Mar 26, 2008 | Linksys WRT300N Wireless Router
Linksys EtherFast 10/100 5-Port Auto Sensing Switch [ EZXS55W ] (104835) Logo
199 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
