Question about Sharp AL 1631 Copier
Why do my copies have stripes on them? Cleaned the visable rollers with alcohol wipes. How can I get to the other rollers.
  • Lucas Bester
    Lucas Bester May 11, 2010
    Thick bands or thin stripes ?
    Problem Solver:
  • 5 Answers
Run a copy through the document proccesor run another copy direstly from the contact glass if the one ran through the document proccessor has lines lift the document proccessor and you will see a small approx. 1inch wide **** glass on the left side of the contact glass it is dirty thats all it is
Posted on May 29, 2008
How do I fix the copier?
Sometimes getting a alcohol wipe and cleaning the rollers with it will do the trick, sounds like the whole thing just needs cleaned and maintained, have to do that you know.
Sep 15, 2014 | HP Officejet Pro 8600 Premium e-All-in-One...
How do you clean the print heads on the UPDR 150
RESOLUTION Clean the Thermal Head, black rollers, and gray roller with 99% pure Isopropyl Alcohol to remove any visible debris.
The Rollers should be cleaned with a lens cloth and Isopropyl alcohol as needed, or every other Print Pack
TechSpray Wipes may also be used.
  1. Remove the print media and protect it from contamination from any tabletop grime.
  2. Use "Canned" air such as Dust Off or other similar products should be used to clear out any dirt and dust within the printer.
  3. Gently rub from left to right while rotating the grey roller and larger black roller to remove any remaining dust.
  4. Use more air to clear away any remaining particles.
see this link:
http://imagingspectrum.com/blog/2010/09/updr150-roller-and-head-cleaning-procedure/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 10, 2011 | Sony UPDR150 Thermal Photo Printer
I am getting a one-inch gray stripe at the top of each copy, and a half-inch stripe at the bottom of each. I think I've cleaned everything ... platen, narrow glass, rollers, etc. ... and it's lightened,...
there is no corona wire but a primary charging roller pls clean it if both ends of the roller looks rough or cracky try replacing it and clean transfer roller as well.
Jan 01, 2011 | Canon imageRUNNER 2200
I have a savin 2522 and it has a few lines running down my copies
few fine lines is due dirty optics mirrors and lamp, and it may also came from dirty charge rollers due to dirty/worn out charge roller cleaner, worn out cleaning blade and seal blade. to check this, clean/wipe off toner or dirt from charge roller with cloth wet from alcohol or water. then run some test copy.
Mar 03, 2010 | Savin Office Equipment & Supplies
Savin 2545 document feeder gives a gray band on the copies
Yes - surprisingly - we had the same problem, the gray stripe along the side of the page only showed up when the original was fed through the document feeder on top. Cleaned the small area of glass under the feeder repeatedly with no change to the resulting stripe, but then while cleaning the upper roller, above the area of glass where the scan lamp illuminates during the copying from the ADF, we found a small piece of paper adhering to the top roller in the paper path, cleaned it off, and no more band. We didn't see the bit of paper on the upper roller until we rolled it while cleaning. Still can't figure how that made a stripe....but hope this helps you.
Feb 22, 2010 | Savin 2545DP Black and White Copier
Copies are dark
No. It would most likely be the opposite.
The stripes could be caused by contamination of the dev roller, fixing rollers or marks on the drum.
You could also clean the laser ****-glass.
Apr 10, 2009 | Canon IMAGERUNNER 6570 Copier
When making a copy we get an ink stripe down the center
open up the document feeder and clean the scanner glass.
Jan 21, 2009 | HP 1040 Plain Paper Inkjet Fax
Oki C5500 printing a yellow stripe
1) clean LED heads with Alcohol swab.
2) Check fuser rollers for dirt, smudges. Clean with swab.
3) Remove all toners/drums and check for spilled toner. Vacuum or wipe clean.
4) Check tansfer belt for marks, stray toner, creases.
4) Re-seat toner and drum cartridges.
Nov 23, 2008 | OKI C5200n Laser Printer
Lines on copies
The lines are caused by some debris that is on the platen (the glass where you normally place the copies). The usual culprit is white-out smudges from a copy that wasn't completely dried yet. When you make copies using the feeder, the roller passes the paper being copied over a little section of the platen (if you pull up the feeder "lid", it'll be on the right-hand side of the big glass... it might even be marked with 2 green arrow stickers, but if not, it's the part of the glass directly under the roller of the feeder). You can just take an alcohol wipe or soak a cotton ball with alcohol or windex and wipe down that strip of glass under the roller.
Jul 01, 2008 | Canon ImageClass D861 Printer
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
