Question about Whirlpool Refrigerators
S20B RSB21-A/G serial of my whirpool fridge freezer no manual came with fridge so I don't know how to connect it to a water supply and also theres a long plastic tube behind one compartment and I am not sure wt it is for, so need to know how to conncet water supply to the fridge so I can use the water.
3 Suggested Answers
SOURCE: whirlpool S20B RSB21
If you look on e-bay, there is a chap in the UK selling repair kits. If you are reasonably mechanically minded and handy with a soldering iron, and happy to remove components on a PCB and replace them you can fix all of your issues in about an hour. The kit costs £35 with full instructions and also you can phone him for advice. It consists of a number of capacitors (as per solution #1 plus several others). I fixed mine over the weekend and am delighted with the results, no need to pay hundreds for the the boards from whirlpool!!
Posted on Feb 08, 2010
heatman101
  • 43501 Answers
SOURCE: The icemaker in the freezer compartment stopped
The first thing that I would do is to clean the coils...if it has stopped in hot weather it is often because the freezing compartment is no longer getting cold enough... dirt blocking the air over the coils is the most common thing that causes this...
Here is a tip that best explains the procedure for cleaning...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Posted on Jul 29, 2011
Jfd2589kes
Locate and check the valve that feeds water to the icemaker.
Jul 04, 2017 | Refrigerators
Fridge not getting cold...but freezer is working
the fridge gets its cold air from the freezer fan blowing it through small air passages between the freezer and fridge. when you adjust the temperature in the fridge you are increasing/decreasing the amount of air being let into the fridge. Two common problems that could cause the freezer to freeze but not the fridge getting cool is the freezer coil is frooze like a ice cube blocking the air going to the fridge or freezer fan is not working could be bad or froze up due to too much ice. If fan works after manually defrosting problem could be in the auto defrost mechanism. If fan don't work after manual defrost replace fan. Manual defrost by putting a pot of very hot water in freezer with door closed change water foten until defrosted.
Jan 02, 2012 | Westinghouse Avalon Refrigerators
S20b rsb21 whirlpool
Your freezer section has a defrost system problem. A device (Timer) schedules defrosts, energizes electric heaters which melt the frost, when the temperature of the coil gets above the point where all ice is melted a thermostat opens cutting the electrical circuit for the heater(s). The defrost cycle continues until the time expires (18-22 minutes). Therefore your problem could be any one of the three elements. Timer, heater, or thermostat.
May 29, 2008 | Refrigerators
Fridge Freezer Ice maker problem
We have an Whirlpool side by side America fridge freezer. Water is not flowing into the ice-maker
Mar 31, 2008 | Refrigerators
Whirlpool s20b fridge/freezer
858615215011 temp. indicators and night light flash continuously.
Mar 27, 2008 | Refrigerators
Whirlpool S20B RSB21
Feb 12, 2008 | Whirlpool GS6NBEXR Side by Side...
Water supply
Hi Don,
Cold water supply at Fridge location. Run 1/4" tubing and connectors to match the supply valve and solenoid valve on the Fridge. Should be just one tubing connection.
If you do not have a supply at your Fridge, you can shut off your main supply and tap into the cold water line and run you a supply over to the fridge. use 1/2" PVC pipe and fittings to route over to the fridge. Get a Threaded adapter to connect a shutoff Valve. This way you have a way to keep the main supply on and hook up the Tubing from the fridge to the supply.
Nov 28, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
