I have several neighbors using my 2wire100 Gateway modem from their homes. This is slowing my internet experience and sometimes locks me up on the internet. How can I put a security password on this modem, so only myself and my family can use this modem?
    President:
  • 1,851 Answers
You have to log on at the router's settings page and go under wi-fi (or wireless) section. Here locate the security tab, enable it and set a password for this connection. I suggest you when doing all the above settings to be connected with cable connection. This is to prevent you to be locked out of your wi-fi in case of an error at password.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Sep 05, 2010
Very slow on net am using a modem
Greetings Charles,
When you say "Using a modem" that could be several different devices. Is it a Telephone Modem that is connected to a telephone line and then to your computer such as a 56k? Or a modem that is connected to a Cable or Router as a gateway? If its a old style modem over the phone line such as a US Robtics etc. then there is several things we can check. If its a Modem connected to a router as such for a Gateway router like a Linksys etc. Then let me know by just responding to this post.
Thanks
Chadman
Mar 16, 2015 | Computers & Internet
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Tip
Slow browse/ optimize ie
when you experience slow browsing on the net using 4100 modem... just optimize your ie by clicking on tools = int options = reset all settings to lo or default on internet properties...a modem may not be the cause of slow browse... as long as there are 4 solid lites on the modem...
on Feb 11, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
NetGear Gateway Access Problem
No to warner's locking the modem. 192.168.0.1 is the correct address for accessing the options within the modem. incidentally the Motorola wireless modem works better. Go on line to Netgear technical service and they will guide you through the task of setting up the system.
Feb 27, 2014 | NetGear WG602 802.11g/b Wireless Access...
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
I have a D-Link wireless router DIR-655 with 4 computers on a home-based network. Everything worked fine for 9 months at good speed. All of a sudden the internet is extremely slow. My test between my cable...
Get your router a security key(password) just in case your neighbors are use it.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Feb 11, 2011 | D-Link Xtreme N DIR-655 Wireless Router
I use an AT&T 2Wire 2701HG-B Gateway Modem and whenever I use the laptop wireless option, the modem tends to repeatedly reset itself, affecting internet use both on the laptop and a home computer which...
http://www.fixya.com/support/t4987959-att_2wire_wireless_router_keeps
Here is a solution I posted today for a similar issue. Might fix your problem.
Jan 13, 2011 | Computers & Internet
My internet connects slows (211kbps) and drops off completely. AT&T says it's inside the home. Anyway to check the modem? I have unplugged and restarted it several times
More likely your telephone junction box outside your house has a bad wire connection - I've experienced the same problem before for my DSL. In addition, sometimes my phone line would go out as well - no dial tone. Listen to your phone and check if you have a dial tone when the Internet connection drops out - they may be associated.
Dec 22, 2010 | 2wire (1000-400108-001) Router
Computer disconnects from Internet when my neighbor is using his computer
the Lock means that he has a secure network or he has the WAP enabled.. Can the two networks interfere? Yes. The two networks will "fight" over which one will your computer use to connect.. and sometimes you will connect to his network and therefore get no internet or limited connectivity.. You can make sure that your computer only connects to your network by permanently removing his SSID from your settings.
Mar 25, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Security question
You can set up your WIRELESS SECURITY SETTINGS.
Open DOS Prompt, on the black screen type ipconfig, then click enter. Look for default gateway(it will look like this----192.168.1.x
Open your Internet Explorer, type the 192.168.1.x then click enter. This will take you to the configuration page. Click on CONFIGURATION, then click WIRELESS. Set up your security. Make sure you take note of your settings OR ELSE YOU WILL NOT BE ABLE TO CONNECT TO YOUR WIRELESS NETWORK ALSO BECAUSE OF THE SECURITY THAT YOU SET UP.
Mar 12, 2008 | Westell Wirespeed VersaLink...
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
