Question about RCA 35V432T 35" TV
Horizontal/Vertical Adjustment Recently has this set repaired. Works fine but when my kids started playing the XBox I noticed the picture extends beyond the top, bottom and sides of the TV. How do I adjust the horizontal and vertical picture? I don't want to call the repair man back out id I don't have to.
    Sergeant:
    Champion:
  • 221 Answers
Your XBox's User Manual should have details on this Settings & if you can't find it, you'll have to contact Customer Care.
Posted on May 12, 2008
Where do I find the horizontal adjuster?
MAKEandMODEL needed to help you .
Nov 26, 2015 | Cars & Trucks
My monitor does not display full screen though all the settings are OK. This problem has just emerged recently. The vertical size is fine and the horizontal size is the affected size.REMEMBER ALL THE...
The Horizontal power supply voltage is low. This is provided as a "sawtooth" waveform via the CRT flyback transformer.
Some flybacks offer a voltage adjustment via a potentiometer ("pot") on the side of the unit. I do not have a schematic for your monitor, so I cannot tell you for certain if this is an option. This adjustment should only be made by a trained technician. If you are not familiar with high voltage electronics, DO NOT OPEN THE SET!
I recommend replacing the monitor. When they age, you can only buy some time before it goes for good, and prices are so low now that repairs are not usually cost effective.
Feb 01, 2011 | Daewoo Business 526X (White) 15 in.CRT...
KV36XBR400 fragmented picture horizontal overlapping lines
this will continue to degrade, almost any failure that can be affected or temporarily cleared up by hitting the set is caused by bad solder joints.
A good shop should be able to find and fix the bad solder connections for probably a little under $100
if you bring it to them and pick it up.
Feb 10, 2009 | Sony KV-36XBR400 36" TV
Samsung HLN4365W picture not centered
turn the tv off, hit mute 1 8 2 power, the tv will come on in the service menue, look in that menue for vertival and horizontal adjust, after you adjust it, just turn the tv back off, it will save your changes
Jan 07, 2009 | Samsung HLN4365W 43" Rear Projection...
Picture horizontal problems
There is a sevice menu but it is something a repair man has to adjust. Even to get to that menu is a matter of procedure. If the picture is not always squeezed down then adjustment is not the problem. If it is intermitant it could be a bad solder connection on the main board.Sometimes a bad vertical ic and leakey capacitors can be the problem..
Bottom line is there is not much you can do to correct the problem. You are going to need a service man
Nov 14, 2008 | RCA F36650 36" TV
Picture Blown Up
Hello jasalf,
This problem is called blooming, and it is caused by poor High Voltage Regulation. It usually denotes a problem in the HV section of the TV. More then likely the problem is in the IHVT (Integrated High Voltage Transformer).
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Aug 21, 2008 | Proscan PS27123 TV
Are there internal picture controls for the WS-55315?
Good Day; OPTION MENU "MENU 0370" SERVICE MENU. CAUTION document settings before any adjustments are made. V = vertical, H = Horizontal. Good Luck, big IRISH.
May 11, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Distorted picture
i was just working on a set with the same problem .. i found a east west correction curicit with a falty transistor. something in that cuircit has failed.
Jan 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen Size is Too Big
There should be a vertical height adjustment control potentiometer near the vertical output IC on the right side of the PC board near the front section of the TV that can be adjusted to shrink the picture vertically. Be careful not to short anything out or getting yourself shocked in the process if you decide to try to adjust it yourself. Good luck. This chassis has also been known to have bad solder connections in that area also, so don't man-handle the printed circuit board roughly.
May 23, 2007 | Zenith D32D51 32" TV
Top of screen is stretched
There are capacitors in the vertical circuit that can cause this problem. You may be able to find these capacitors by using a hair dryer pointed to the suspected bad cap and then when the problem happens you can spry a little cooling spray on it to see if the problem clears up. The vertical output IC could be going bad but this can be checked the same way. if you have no TV solid state repair experience, play it safe and take this set into a local repair depot. Good Luck
Mar 17, 2007 | Toshiba MW24FN1 24 in. TV/VCR/DVD Combo
RCA 35V432T 35" TV Logo
101 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
