Question about Williams 2509612 Ceramic Mid-Size Heater
We have a memphis patio heater and the pilot light will not stay on how do we fix this ?
Buffalo12980
  • 625 Answers
SOURCE: Patio heater won't stay lit
make/model??
Posted on Oct 15, 2007
hotuna
  • 288 Answers
SOURCE: windchaser patio heater
You have to hold the button down for 30 seconds at least before turning the knob to ON. If you are doing this and it still goes out after you let up on the knob, then it needs a new flame sensor, or thermocouple. Same thing different names.
Posted on Mar 06, 2008
  • 8 Answers
SOURCE: Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
Posted on Jun 18, 2008
AZSTALZ
SOURCE: charmglow patio heater
Well, I just went out this morning and worked on the heater after it would not light last night. Turns out that a spider or moth set up camp in the pilot light intake housing and plugged up the two small mixer holes that pull in air for the pilot light. This would explain the 'yellow-flame'. I took a punch awl and some compressed air and cleaned out the hole, then re-installed the cover and knob. Lastly, I turned and depressed the knob and the pilot light ignited almost instantly, stayed on when I let the knob up, and the heater turned on normally after that. Good luck, I hope this helps.
Posted on Nov 09, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: model SRPH02 BURNER WILL NOT FIRE
Bad flame sensor. Try to clean it with some steel wool
Posted on Apr 24, 2009
Why won't my patio heater light
The thermocouple has to be in contact with the flame at all times when pilot is lit, this heats up and sends mill-volts back to the safety valve to keep the gas on, if not it won't let the gas through, otherwise you need to clean the pilot or replace the thermocouple if everything else is ok..
Aug 29, 2014 | Patio Heaters
I have a nexgrill propane patio heater the pilot light works but when i turn it to lo or high after a minute or so the pilot light stays on but the burner wont light
Propane Patio Heater Troubleshooting - YouTube
? 6:54
www.youtube.com/watch?v=BqYIWuDUZOUDec 12, 2008 - Uploaded by PatioShoppers Great tips about troubleshooting your outdoor patio heater. ...Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace ...
May 12, 2014 | Williams 2509612 Ceramic Mid-Size Heater
Pilot light will light and stay lit, but will go out when you turn on the burner.
The most likley cause for patio heaters that light but go out when turned up is a worn thermocouple. These are consumable items that need changing when the patio heaters fails to light. Found this site very useful:
patio heater problem solving
Dec 31, 2012 | Stainless Garden Sun Steel Propane Patio...
I have a Kirkland patio heater model # PTH-106SS-3G the pilot will not stay lit. Do I need to replace the whole pilot assembly
Hi, If the pilot light goes out when you turn the gas knob to full power on lighting them the most likely cause will be a worn thermocouple, these usually last between 2 years up to 6 years. Found this site very helpful, patio heater problem solving. They have a few solutions to checking patio heaters.
Oct 12, 2011 | Williams 2509612 Ceramic Mid-Size Heater
Pilot on my patio heater will not stay lit. goes out when i release the knob
If the heater is the same as this type of patio heater and it lights on pilot and goes out it is generally a worn thermocouple. These are designed to switch off the patio heater when something is wrong, changing one fixed 90% of the problems. Sometimes it can also be caused by a worn tilt switch but always start with the most likley and work backwards. Found this site very useful, patio heater problem solving page.
Jan 04, 2011 | Stainless Garden Sun Steel Propane Patio...
Patio Heater
The pilot light has to heat up the thermocouple. Is the thermocouple in the flame? If so, the them. could be bad. Replace
Jun 28, 2009 | Endless Summer 1501 Patio Heater
Charmglow Patio Heater
The yhernocoupler would snuff the pilot if bad. What ignites the overhead burners? and what regulates the overhead gas supply? Look into this. Too much gas will not light as easily as proper balance gas and air. Even more so in a tower type heater.. Turn the gas on low and the pilot should grab it. Good luck
Jun 05, 2009 | Coleman (5040B750) Patio Heater
May 30, 2008 | Coleman (5040B750) Patio Heater
Williams 2509612 Ceramic Mid-Size Heater Logo
631 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
