Watts Onan Portable Generator - 4000 , Model# 5500 Logo
Posted on Sep 05, 2010
Hi ive been given a wolf 800 generator but i cant get it to work i have checked the plug wich is getting a spark and i can smell petrol in the cylinder head. what im wondering dose petrol go off i dont no how long its been in the tank so could it be this thats the problem
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 07, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
663
Points
I have a Wolf 800 that was difficult and would not start.
1. The fuel hose was kinked and fuel was not flowing to carburettor, hose unkinked and fuel flowed.
2. Check the push-on connectors at rear of on/off switch, one had come off. Easiest way to replace is to remove fuel tank bolts (4) and angle tank out of the way.
3. If a Chinese F5TC spark plug is fitted, throw it away even if a spark is apparent, and replace with a equivalent such as NGK BP5ES or Champion N14YC
rlev_7
Level 1:
New Friend:
  • Contributor 47 Answers
  • Posted on Sep 09, 2010
rlev_7
Contributor
Level 1:
New Friend:
Answers
47
Questions
0
Helped
24366
Points
56
Yes fuel goes bad drain fuel and clean carberater and put some seafoam in gas or small engine tuneup
Hi my generator wolf 950 petrol does not have a spark
you troubleshoot it like any small engine.
Clarke 2200kw generator will not start Have changed spark plug checked flters put in fresh petrol
are you getting spark , is the on switch on , some people forget to do this
2helpful
Hi we have a wolf 950 generator that wont start,cleaned plug,is there anything else i can try,HELP!
are you getting spark. pull out your plug and with the wire connected. hold the plug about an 1/8 of an inch away from any metal on the motor and ensure your getting spark. also check to ensure your fuel is not bad..
2answers
Hi recieved my atomik radier250 brand new yesterday and put it all together but now after ive charged the battery i cant get the thing started ive done everytging to the poorly descriped so called manual...
If it doesn't fire right up do not keep trying you will burn up the starter Change something
1.Fuel on
2 kill switch to run
3 side stand up
4 petcock in prime position if it has one
5 Spark?
6 choke on?
7 check the spark plug to see if it smells like gas or is wet with fuel
20 seconds at a time on the starter or it will burn out
1helpful
Hi Please can you confirm what fuel the Ryobi rg6700k generator takes?
Hi. I've been looking online and there's no information about this model. However this is how to tell which fuel it uses. If it has a spark-plug it burns petrol. Diesel engines don't have spark-plugs they use glow plugs which are different. Spark-plugs have a spark gap which the spark jumps across while glow plugs do not.
If it has a separate place for putting oil, and a dipstick for checking the oil level, then the fuel is petrol only. If it doesn't have a place for oil then the fuel is petrol mixed with 2 stroke oil. I hope this answers your question.
Jan 19, 2011 • Garden
3helpful
2answers
Hi, Honda HRG465C Petrol Mower running problem
The first thing to check is the spark plug, is it clean and properly "Gapped" next is are we actually getting spark, does the spark plug actually "Spark". Check. Check Spark Plug lead., Check connections. Do we have Fuel, Check .and Is the fuel getting to the Carburettor? Check. Check the battery. alternator, generator, is providing power. Check the Mixture.
No spark at plug
I have a coleman pm 2200 about 12 yrs. old. No spark
Ihave a g900 clarke generator that runs perfect,smells of petrol
Hi i have the same unit, i believe that this is just after fumes that actually smell very much like petrol. As this happens to mine as well and the cap is a very tight seal. Its very much like the smell of an old petrol lawn mower.
Do you know which way round the 240v plugs go.... for instance, which pin is positive (live) and which pin is ment to be negitive (neutral).
As you can put the plug in either way it just seems wrong??
POST SOLUTION HERE THANX
Top Watts Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
