I have just brought a second hand simpson eziset 750, it worked at the shop and now only goes halfway through the cycle. The water level lights are all flashing and beeping like crazy. i have tryed to re-balance but that not the problem . please help!!!!
There is a magnet in/under the lid on the left hand side inside a plastic housing. I also got a second hand machine in which the magnet had totally broken down due to corrosion. You can test if this is the problem by placing a magnet where this magnet would be positioned when lid closed. Replace magnet
Posted on Mar 04, 2011
Hello, hope you can help, I have a eziset 550 simpson when I put the water on it starts filling but won't stop I have to listen & try to change settings so the water that won't stop running doesn't...
there is a small hose from the bottom of the tub to the water level switch
that gets air pressure to activate a switch when the level selected overcomes the switch spring
At that point the water solenoid is turned off and the wash cycle begins
over flowing indicates that the level sensor is not working or the inlet solenoid and diaphragm is faulty
if it doesn't progress the wash cycle , that indicates a program board problem so call the technician for a proper diagnosis
Sep 13, 2017 | Simpson Washing Machines
Is there a reset button on a Simpson Eziset 750?
no
what is the problem
if it is on pause press the start button and hold for a few seconds
May 14, 2017 | Simpson Washing Machines
My Simpson eziset 750 will keep pumping even after water is gone and wont go onto next stage which i think is spin etc, can any one help me with what might be wrong thank you
the program is empty , then spin in stages and rinse, at the same time pumping then stop rinse water then spin up to speed while pumping right to stop at end of cycle
If it doesn't get to full spin then there is a problem in the program board not progressing
call a technician for a proper diagnosis
oh and for your future information , if you have a balance problem , it will be the suspension rod ends broken off and not allowing the pneumatic motion absorbers to work correctly Replacement cost is $88.00 aud and you can do it yourself one rod at a time
there are 3 blue ones and one white one so make sure that you replace color for color then sure that the bowl is level by pulling out the agitator strainer unit and using a short level across the top of the agitator
just done the repair myself , took about 1/2 hour by myself
Apr 23, 2017 | Simpson Washing Machines
Simpson Eziset 750 top loader washing machine won't fill with water.
might be the inlet valve has failed or the main controller
Dec 03, 2016 | Simpson Washing Machines
My simpson eziset 750 is leaving grease marks on clothes after wash. Whats wrong?
Do you use fabric softener? Too much softener & too many cold water washes results in a build up of black soap residue on the outside of the inner bowl. You could try a hot wash with some white vinegar in the water (No clothes just the water) If that doesn;t work then you will need a service person to come & take the bowl out for cleaning.
Jan 02, 2016 | Simpson Washing Machines
My simpson eziset 7.5 washing maching does not hold water
Be sure that the drain line is above tub level.
Dec 04, 2012 | Simpson Washing Machines
Eziset 550 Drains as it fills
Replace the fuse inside the control panel make sure you turn if off.
depending on where you are the fuse is more than likly a "4amp slow blow" fuse
hope this helps
Dec 02, 2012 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Simpson eziset 605 wont turn on-totally dead
Possible that the mains program controller unit is faulty. It is not ideal to buy a second haand one unless there is warranty as you could end up with a unreasonable bill. Check the main power to the prgram controller unit.
Jun 26, 2012 | Simpson Washing Machines
Simpson eziset 750 manual
Hi our eziset 750 simpson washing machine has stopped working. It randomly just turns off and then will start again few days later. Cheers
Aug 28, 2010 | Washing Machines
Washing Machines Logo
427 people viewed this question
Top Washing Machines Experts
