I am looking for a repair manual for a bosch v637 washing machine. The belt broke and caused damage to the wiring loom wrapping part round the motor. This pulled off terminals. I can repair the loom but I am unsure as to the wiring diagram.
  • 62 Answers
SOURCE: Bosch Model WFB 1605 washing Machine
Try online...you'll need the full model from the machine. Try general search or go to bosch's web
Posted on Jan 03, 2008
yalmer
  • 552 Answers
SOURCE: Washing Machine Belt Replacement
Here is the web link to a drawing wwhich I hope will help.
http://www.us1internet.com/AW300KW2_147217.htm
It is not the best drawoing but I hope it helps.
The tension wheel rides on the outside of the belt.
Posted on Feb 04, 2008
  • 8 Answers
SOURCE: remove carbon brushes from bosch washing machine
bad news im affraid mackem , depending on what motor your bosch has there is no way to change the carbons without removing the motor .
Posted on Feb 25, 2008
IFIXALL
  • 868 Answers
SOURCE: Wiring Diagram
Have you looked under the main control panel for this??The other way is to contact Hotpoint(GE) support,they will have this information.Just have model & Serial number ready.
Posted on Jun 03, 2008
  • 223 Answers
SOURCE: LOOKING FOR USER MANUAL FOR WFT2400 BOSCH FRONT LOADING WASHING MACHINE
Try this website: www.bshappliancecare.com and I think you might find what you are looking for. Good luck.
Posted on Sep 26, 2008
Washine machine not spinning
It sounds like a snapped belt or a broken motor. Can you here the motor run? You can access the motor and the belt from the back of the machine. If it is the belt snapped, this is easy to replace yourself. If it is the motor, you will need a repair man.
Jul 17, 2010 | Bosch Washing Machines
Can't fit a belt to the Bosch washing machine. Is
There is no provision made for adjusting belt.
With the rear panel removed, fit the belt round the motor pulley first, and slowly feed it round the drum pulley, at the same time turning the pulley by hand..
Watch your fingers, it will be tight.
You will find it easier to do if you lean the washer away from you, this will give you more room to get your hands in..
Hope this helps you.
Dec 03, 2009 | Bosch Washing Machines
THERE IS POWER TO MY BOSCH 1200 W/MACHINE AND IT TAKES IN WATER BUT NO DRUM ROTATION. CAN MANUALLY MOVE TO DRAIN AND DRAINAGE IS FINE, BUT IF I SET TO SPIN IT DOES NOT SPIN. IT TICKS DOWN THE MINUTES AS IF...
Sounds like a selector switch problem. It is common. Do make sure the belt is not off the pulleys. You can check power to motor with a voltmeter. Can you manually spin the tub with your hand or is it frozen up?
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Nov 16, 2009 | Bosch Classixx WFC 2465 Front Load Washer
Bosch washing machine wont spin or empty
PAV2300 Top Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 20, 2009 | Maytag PAV2300 Top Load Washer
Belt broken on my wdt1085 washing machine.
take off back plate to washer, wrap belt round motor and spider (6 legged wheel above the motor) and turn the spider thats it
Jun 23, 2009 | Zanussi F1045W Front Load Washer
Wiring Details
if you have just two wire on thermostat then it is
immaterial where you connect on thermostat.
ONLY IF HAVE TWO WIRE THERMOSTAT.
Feb 16, 2009 | Zanussi FJS1225W Front Load Washer
Bosch washing machine frozen
Try heating them with a hair dryer or wrapping cloths round them that have been soaked in hot water, this should do the job.
Plz rate my solution
Thanks.
Jan 07, 2009 | Washing Machines
My bosch washing machine wfo2865 exxcel is not spinning. Every thing else works. The engineer said it could be the brushes. How do I take the motor out to replace the brushes
remove back panel.remove motor wiring undo two bolts in front. remove belt. motor will pull out.
my experience of these is that often the commutator is damaged hence brushes worn
Aug 07, 2008 | Bosch Washing Machines
Bosch WFMC3200
Click on Bosch (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Plug off the wall, open up behind, you will see things.
Pl rate if helped.........
Jan 02, 2008 | Bosch WFMC 3200 Front Load Washer
Earth fault
the wiring loom from the motor to the control board is cable-tied too tight against the motor. this causes the wiring insulation to weaken and short against the motor causing the constant earth fault./ cut the cable ties on the motor loom and refit new ones BUT not too tight
Sep 12, 2006 | Hotpoint WD62 Front Load Washer / Dryer
Washing Machines Logo
Top Washing Machines Experts
