Question about Philips 190WV
I have an philips 190WV monitor. From times to times the "brightness option shows up and changes to zero without pressing any button on the monitor. Any ideas ?
I got the same opposite problem. my contrast goes up 100 and i can't change any thing.
have you figured out your problem? if yes, how?
Posted on Nov 14, 2010
    Problem Solver:
  • 7 Answers
This is a mechanical and not software/driver problem
I had the same problem. It was due to the right button being stuck.
I was sure it had to do with the contact and was dismayed to find ot you need special equipment to unscrew the back of the monitor off...
But luckily i solved it by flipping the button with my nail at the edge of the button.
The sudden press&release got it unstuck...
Hope this helps :)
Posted on Oct 18, 2011
  • GeorgeM Oct 20, 2011
    ,,, unfortunately the problem returned and it seems to be related to the microcircuit board of the OSD buttons. After selecting the OSD option from the menu: reset>menu>yes pressing the menu button for 10 secs locks the controls and then there is the annoying "attention monitor controls locked" message popping up all the time which then boils down to service or disposal...
  • GeorgeM Oct 21, 2011
    update: After opening the cover I poured some ethyl alcohol on the faulty OSD button next to the menu and fingers crossed it works fine now for more than an hour (without any of the annoying pop ups or auto increases of the contrast....) Fingers crossed this will last or else I read that you can completely remove the connection of the buttons microcircuit board provided the settings are good - I didnt try it since it works well with the cleaning. See what I did:
    Unplug all cables from the monitor so as not to get an electric shock!
    Lay it on a flat surface and remove the 3+1 screws from the back. Remove carefully the back cover. There are 7 clips up and down and 5 clips left and right every 4 cm or so, they are tricky to take them apart but if you use a flat screwdriver and put it between the front and back cover press inside a little bit and twist it you can make it.
    Take off the buttons board after unscrewing the two screws and pour generously ethyl alcohol on the button(s) contacts. Let it dry and assemble again. If it works fine say thanks to God and me and drink a beer :)
Desktop Stand ,any ideas ?
  • You can get a universal wall mount if the stand is no longer available or you cant find one
May 10, 2014 | Philips 190WV
I have a Phillips 190wv pc monitor and I am looking for a desktop stand for same as the original broke. Any ideas ?
got wood I would just build my own...cheaper and you can customize it to your like..
Philips monitor osd locked
you have to carefully force open the clipped back case of the monitor and disconnect completely the cable to the front control buttons, then the monitor works fine though no adjustments can be made
Jan 12, 2014 | Philips 190WV
Brightness set to all the down
There should be a menu button on the monitor. Press this button, it has it's own brightness settings. Press the "factory settings" button; monitor should return to normal brightness.
Sep 19, 2013 | Dell Dimension™ B110 PC Desktop
No light in Philips lcd 190WV
Has it got power? Is it turned on? Is the PC attached to it? First check all your cables & power outlet.
Feb 06, 2013 | Philips 190WV
I don't know how to adjust the bright and dark for the screen.
To adjust the brightness and contrast, do the following:
1. Press the either the Minus button and highlight the option you wish to change.
2. Press the Menu button to select the highlighted option.
3. Press the - or + buttons to adjust the brightness/contrast settings.
4. Press the Menu button again to accept the changes.
Click the link below for the documentation on this monitor:
http://support.dell.com/support/edocs/monitors/e156fp/En/about.htm
May 23, 2011 | Dell E156FP 15 inch LCD Monitor
My acer AC713 monitor's brightness value gets reduced to zero.
Dear sir,
This is common problem arises mainly due to moisture,especially in rainy season,Monitor front panel control buttons remain pressed,due to deposition of ferric oxide and moisture in between monitor botton panel and circuit board.So you can dry this moisture by hanging a bulb of 60 watt nearer a monitor about 4-5 hrs,(too near may damage the internal heat sensitive parts.).It solves your problem.....and also you may clean the inner monitor button contacting circuit by means of PCB cleaner to wipe out ferric oxide deposition.
if you had any query regarding this issue leave a feedback we glad to assist you.
good luck.
Sep 10, 2009 | Acer AC713 17" CRT Monitor
Computers & Internet Logo
1,570 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
